Question about Dell 3100cn Laser Printer
Is there a printer download for Dell 3000cn.
My desktop
    Sergeant:
    Champion:
  • 200 Answers
Hi
U can download it from the company website itself..
thank you
Posted on Dec 06, 2008
Installed new yelloe cartridge but printer keeps stating to reseat cartridge
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ...imaging drum cartridge. Turn the printer off using the power switch on the left side. Wait 10 seconds, turn the printer back on, and check if the error message...sensor solenoid nip. Turn the printer off using the power switch on the left... (English) 016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ... Press Select ( ) to clear the error on the printer. Reset the printer NVRAM: Press Menu. Press the...and then press Select ( ). When Restart Printer appears, turn the printer off and then back on... (English)
KB Article How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059 ...Troubleshooting Guide for My Dell 3000cn-series / 3100cn Laser Printer ...available online for your Dell 3000cn/3100cn laser printer. The troubleshooting...printing, refer to the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide... (English)
Dec 13, 2010 | Dell 3100cn Laser Printer
I need the Dell 3000cn printer service manual
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?c=us&l=en&s=gen&~ck=anavml
You can download the manual from the above link. If that doesn't work, go to support.dell.com and follow the links to the downloadable manual. Start on the left hand side by selecing Manuals (found under the "Product Support" heading)
Feb 19, 2010 | Dell 3000cn Color Laser Printer
Dell 3000cn color printer - black/grey line down right side of page. Is it the drum? How to check drum?
Sounds like the black drum. You can't get the part from anyone but Dell so be prepared for the cost. It also requires some disassembly to install on my Dell 5110cn so yours most likely will also.
Jan 27, 2010 | Dell 3000cn Color Laser Printer
My Dell 3000CN is out of yellow toner
located in your control center for the dell printer is an option to print in black and white onlhy. click that u should be able to print.:)
Sep 07, 2009 | Dell 3000cn Color Laser Printer
Dell 3000cn paper jam open reg cover
Don't take risk about your equipments. consult a enjineer.
Aug 06, 2009 | Dell 3000cn Laser Printer
Cd for dell 3000cn
Hi!
You can download the drivers from the link--
Dell Drivers
Select the operating system you are using and then download the printer driver and then install it.
Please rate the solution if you find it helpful.
Thanks
Rylee
Feb 08, 2009 | Dell 3000cn Color Laser Printer
I would like to be able to connect my lap top to my Dell 3000cn.
I lost my installation cd as well and I just figured out the solution to this problem. If you're trying to install the printer when it's attached to the network, this is how I did it. When you download the printer drivers from the Dell website, there isn't a setup.exe or similar file that will guide you through the installation setup. You still need this download, but what I did was go to the printer/faxes folder and clicked on "Add a printer". Select "Local printer attached to this computer and de-select "automatically detect and install...". On the next screen, select "create a new port" and select "standard TCP/IP port" from the drop down menu. At that point, another window will open for a wizard to add a tcp/ip port. Make sure you know the network address your printer is at and type it in. The next screen will probably say that it cannot find the device. Just select "custom" and finish configuring the port. Depending on your OS, there might not be any Dell printers. Click on Windows Update and it should update the manufacturer list. It will appear to freeze, but it's just updating the list. Click on Dell Inc. Select 3010cn. (I tried the 3100cn PCL6 and PS, but neither worked.) Make sure not to print a test page since this is not the driver for the printer and will print a million pages of junk. Click finish. Next, right click the printer you just added and select properties. Click on Advanced and click new driver. Click on "have disk", then browse. Look for the downloaded driver folder and open the PCL folder in the win_x32 folder. Select the dlxbrzi.inf file, then click on finish. Now you should be able to use the printer on your network. I don't know if there is a better way, but this is how I did it. I hope this helps.
Dec 06, 2008 | Dell 3100cn Laser Printer
Dell Printer 3000cn - Back Panel won't close
Hi. Try gently pulling the door up and out (away from the printer) and then bring it back to the closed position. It's something in the hinge that's off...
Nov 15, 2007 | Dell 3000cn Laser Printer
Dell 3100cn Laser Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
