Question about Air Tools & Compressors
Air compressor leaking
Stand up compressor 75gal. when compressor shuts off leaks air out of valve on side of diaphram
    President:
  • 1,388 Answers
The problem that you are having is caused by the in tank check valve not holding the tank pressure. Simple test is to carefully loosen air-hose that feeds air to tank and check for air leaking. Replace check valve if leaking. Generic parts may be used. Enjoy
Posted on Dec 07, 2008
    Problem Solver:
  • 10 Answers
Your regulator/cut off valve is bad they sell them at walmart lowes tractor supply etc.
Posted on Mar 25, 2012
My ingersoll rand compressor won't get up to set pressure
Hi bryon
Here are a few things to check, you may have already checked some of these.
Electricity...Compressors will run best with full 115Vot 15AMP/Or 220V electrical supply from a circuit, over the shortest electrical cord as possible.
Air Leaks..Place your ear close to the compressor and listen for air leaking, if you hear air that is not normal and means you have to locate and repair whatever it is that is leaking.
Check the air unloader valve... The air unloader valve will blown out air when you turned off the compressor, that is normal.
But it should not have air leaking out of it all of the time. If so then it is faulty and in need of repair/replacement.
Valves...If either the intake or exaust valves fail, breaks, or fails to seat, then your compressor will run 24 hours a day and never build up to the correct pressure for shut-off.
Gaskets...Check to see if your gaskets have failed.
You could have a gasket failure between the pistons and you will never know it because it shows no external air leak.
If this situation happens then the air will only cycle between cylinders and never build up the correct air pressure.
One way to check the gasket is remove the air filter, then put your hand over the intake.
Please take time to rate me
Bud
If correct then it will suck you hand against the intake.
If the valve or valves have failed then you will feel the air sucking in and blowing out.
Piston Rings and Cylinder...The piston rings could be stuck,broken, or worn and not allowing the correct pressure to build up in your tank.
A worn cylinder will also contribute to the problem of pressure build-up.
Pressure Switch...Check for air leaks at the pressure switch, it has a rubber diaphram that can fail and leak air out of the system.
Bud
Apr 05, 2013 | Air Tools & Compressors
I have a porter cable compressor, but the pump won't shut off, and the pressure won't build it
Hi
*Electricity...Compressors will run best with full 115Vot 15AMP/Or 220V electrical supply from a circuit, over the shortest electrical cord as possible.
*Air Leaks..Place your ear close to the compressor and listen for air leaking, if you hear air that is not normal and means you have to locate and repair whatever it is that is leaking.
*Check the air unloader valve... The air unloader valve will blown out air when you turned off the compressor, that is normal.
*Valves...If either the intake or exaust valves fail, breaks, or fails to seat, then your compressor will run 24 hours a day and never build up to the correct pressure for shut-off.
*Gaskets...Check to see if your gaskets have failed.
If correct then it will **** you hand against the intake.
*Piston Rings and Cylinder...The piston rings could be stuck,broken, or worn and not allowing the correct pressure to build up in your tank.
*Pressure Switch...Check for air leaks at the pressure switch, it has a rubber diaphram that can fail and leak air out of the system.
Bud
Nov 01, 2012 | Porter Cable Air Tools & Compressors
Pump is not shutting off, and pressure not building up
Hi Kendal
Bud
Nov 01, 2012 | Campbell Hausfeld 26 - Gallon Air...
Hi Kendal
Bud
Nov 01, 2012 | Campbell Hausfeld Air Tools & Compressors
Takes long time to pump up, then have to shut it down, compressor acts like it wants to stop, but if I remove small line and let the air out of that side where the line connects, it will run fine but of...
Hi dmream55...
Sep 22, 2011 | Campbell Hausfeld 5HP 20 Gallon Single...
Compressor reaches upper pressure limit of 120 psi but does not shut down or increase in pressure. When manually shut off at near 120 psi it will hold pressure for extended time.
Hi
It will contribute to not shutting off the compressor motor thru the use of the pressure switch.
Sep 21, 2011 | Stanley Air Tools & Compressors
Compressor does not shutoff
Hi leroy badger...
Sep 09, 2011 | Clarke Power Products Inc AC2001 2HP 4...
My air compressor with fill up to about 40 psi and then it just shuts itself off
Hi theyankees20...
Sounds like you have a pressure switch problem, it may have gotten out of calibration.
Check to see if your compressor has an adjustable pressure switch. If it does then adjust the screw/nut down (clockwise) to increase your shut off pressure...just go slowly on the adjustment.
I will include a few more things to check also...
Aug 29, 2011 | Pacific International Schwinn Hinge...
Compressor only pumps up to about 20 psi
Hi archermartin...
Aug 28, 2011 | Air Tools & Compressors
Compressor was airing up to pressure when it sounded like it blew out a pop off valve or diaphram. Now it sounds like it has a large leak and does not build up pressure at all.
Turn on the compressor and look for the air leak. It could be a relief valve or a connecting hose or tube. You must locate the leak then see if it is a part that can be replaced.
Gary
Mar 08, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
Air Tools & Compressors Logo
429 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
