Question about Kitchen Ranges
Wolf built-in Wall Oven 762. Convection Fans stop turning intermitantly Oven shut down with F1 warning Later restarted ? meaning of F1 warning
  • Anonymous Mar 15, 2014
    wolf wall oven temperture
    Sergeant:
  • 399 Answers
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
http://www.applianceaid.com/fault_codes.html
click the link
Posted on Dec 06, 2008
Convection fan runs from start up , but when temp ia achieved , fan stops working and shows con on the display
Search Results
    Frustrated with new Samsung stove! - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWe purchased a smooth top, convection Samsung range , with delivery on ... I seem to have the same problem with my new samsung range FER700WX. ... That ovenwould not reach temperature and if it did, it would not keep the temperature. ..... 3) as the oven restart the convection fan or fans blow such hot air the food in ...
    Convection 101: A Guide to Cooking With Fans - Oven ...
    ovens.reviewed.com/.../convection-cooking-101-a-guide-to-cooking-ba...
    Apr 4, 2015 - Problem is, it uses a ton of water. 6.2 ..... Convection ovens use a fanand an extra heating element to correct ... it's best to reduce oven temperature first, before adjusting cook time. ... range or wall oven, there's simply no reason not to ponyup. ... From futuristic to freaky, these fixtures run the entire spectrum.
    New Bosch range convection fan not moving? - Home Forums
    ths.gardenweb.com > Home Forums > Appliances
    Oct 8, 2007 - On my range (the slide-in version) the cooling fan runs even when in ... I was the one with the Bosch fan problem and if there is a problem with ... Mine does stop turning when I open the door and starts again when I ... convection roast feature, and once the oven reached temperature, ... Sign Up to Comment.
    Troubleshooting Gas Range and Oven Problems ' Back ...
    blog.etundra.com > Tundra's Tech Talk
Jan 17, 2016 | Kitchen Ranges
How to reset error codes
Dual Fuel Range Error Code 07 ' FAQ ' Sub-Zero and Wolf
www.subzero-wolf.com/.../dual-fuel-range-error-code-07
Sub?ZeroCore Issue: Dual Fuel Range error code 7; ERR 07 displays on Dual Fuel; Error 07 on control panel of Dual Fuel ... Convection Steam Oven Error Code E75.
L Series Built-In Oven Error Code COMM ERR ' FAQ ' Sub ...
www.subzero-wolf.com/.../l-series-built-in-oven-error-code-co...
Sub?ZeroCOMM ERR displayed on an L Series Built-In Oven indicates a communication error.Reset the unit's power at the circuit breaker. Turn the unit back on to see if ...
WWD30 Warming Drawer Error Code 40 - Sub-Zero and Wolf
www.subzero-wolf.com/.../wwd30-warming-drawer-error-cod...
Sub?ZeroError 40 on a Wolf Warming Drawer. Steps to Verify Issue: With error 40 on WWD30 warming drawer try the following before calling service: ... x. PF Error Code on Warming Drawer ... Whether you're shopping for appliances or have questions about those you already own, we've got the resources you need. ... Wolf Cooking.
Wolf DF304 beeping after turning off the oven - The Kitchen ...
appliantology.org > ... > The Kitchen Appliance Repair Forum
Dec 25, 2015 | Wolf Range Kitchen Ranges
When trying to thermal/radiant bake, convection fan at the rear does not stop turning after the preheat. Why doesn't this happen? Isn't it then convection baking?
Most wall ovens have a cooling fan that comes on when the oven has been on for some time. It is separate from the convection operation. It should shut off after the oven has been off for a time.
Nov 12, 2013 | KitchenAid KEBS279BWH 27" Double Electric...
F1E1 error happened repeatedly, jenn air says cut
F1 - E1
EEPROM checksum error
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
called ERC or clock).
Note: Applies to all F1-E...
codes except F1-E3.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Jenn
Air Range / Stove / Oven Fault Codes#ixzz19GMNtS3r
Dec 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
What does F- mean on my jenn air expressions electric wall oven? If it means what I think, then this is the 4th failure in 10 years. This just can't be right!
Common fault codes:
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
May 22, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Beeping and displaying F1. Press stop and 30 seconds later it starts again.
too high temp F1 fault code its either the keypad, or the control board.if the thermostat or oven sensor is bad,it could have got the keypad or control board too hot, and caused the F1
Aug 30, 2009 | Jenn-Air 30 in. Pro-Style Electric Single...
Ge Profile built-in 27 inch wall oven -- When I
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
Jun 18, 2009 | GE Profile JT912 Electric Single Oven
Wolf Double Oven
I had the same problem with a Wolf L-Series double wall oven (Model DO30) and called for service (under extended warranty contract). The tech told me that the F1 error is a latch problem (you know the one that grabs and locks the door during self-clean cycles). He cleared the error using a series of "secret" button presses on the control panel and the problem cleared. Now, when it happens (which isn't very frequently), I do the same thing he did ... press "0" and "Temperature" for the oven causing the problem and hold them for about 5 seconds. The oven will ding and the display will show some diagnostics, including the error event. Press "Cook Time" and "Stop Time" while in this diagnostic mode to clear the error register, then press "Off". I've also tried to keep the area across the top of the oven opening clean (with a little degreaser), especially around the latch, and I've sprayed a bit of WD-40 into the latch periodically for lubrication and cleaning.
Mar 26, 2009 | Wolf Range WKGD-2 Gas Double Oven
Wolf oven e1 code
Ar you sure it isn't an F1? Taht would mean an error in the latch
Dec 17, 2008 | Wolf Range CHR-0-18-FT22 Gas Kitchen Range
Kitchen Ranges Logo
340 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
