Question about Indesit 24 in. D63 Free-standing Dishwasher
Indesit D63 Dishwasher - I need to know the order of positions of the wires onto the pressure switch. I took them off without noting the positions There are 3 connectors. A blue/black pair of wires goes to one connector, a single grey wire goes to another, and a pink/white pair of wires go to the third connector. As you look at the pressure switch, with the air-inlet to your right, what order of position are these 3 connections ? (Also, the same sort of question applies for the overflow float switch )
SOURCE: indesit D63
It sound that the problem is cause the water level switch (stuck in the "full" water position). The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with this specific machine, but if you will open the rear panel you will find it easily. Clear first any obstruction in the tube,In case it doesn't help, disconnect the wires from the unit (you should disconnect first machine's power cable !!!!!) and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it doesn't react, you should replace it. Good luck !
Posted on May 29, 2006
SOURCE: Water filling does not stop
Water supply to the dishwasher is done through an electromagnet valve,loocated at the water pipe's enterance to the machine. A defect in the valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it, and the valve may leak and drip water into the tub.You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from the machine before doing it !!!!! and as well to close water main tap to the machine. In case cleaning doesn't help, you should replace the valve. Good luck !!
Posted on Jun 24, 2006
SOURCE: Leaking Indesit D63 dishwasher
try pushing down firmly on inner door panel at the bottom with door fully open. You will feel it starting to bend. This moves seal closer together when door shut. it worked well for mine.
Posted on Jul 15, 2008
SOURCE: Replacing a DoOr Seal
as i remember it, you will have to take off the door front panel and slot in the seal from inside of the lower door. if im thinking of the wrong model and the advise is wrong i will get back to ya.
Posted on Mar 16, 2009
SOURCE: indesit d41 dishwasher overfilling, pressure
possible faulty pressure switch or a faulty drain pump
Posted on Dec 21, 2009
Testimonial: "cheers"
Nov 27, 2014 | Danby DDW611WLED
Feb 09, 2008 | Maytag MDBH945AWW / MDBH945AWQ /...
Nov 22, 2014 | Asko D1976 Built-in Dishwasher
Dec 06, 2010 | Indesit 24 in. D63 Free-standing...
Mar 09, 2010 | Indesit 24 in. D63 Free-standing...
Dec 20, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Sep 04, 2008 | Indesit 24 in. IDL700 Built-In Dishwasher
Dec 22, 2007 | Dishwashers
May 28, 2006 | Indesit 24 in. D63 Free-standing...
102 people viewed this question
