Question about Bosch Washing Machines
Machine is completly locked
A key sign has appeared in the display none of the buttons will opperate
I just had the same problem! I put the dial to 6pm and held the start key down for about 20 seconds and it re-set itself!
I did clean the filter too!
Posted on Mar 23, 2009
  • Bosch Master
  • 3,463 Answers
Make sure that the door is shut properly
Posted on Dec 06, 2008
My bosch frontloading washing machine when turned on there is flashing of spin and pause/off butons. we can't turn on the washing machine can you please tell me what the problem might be
Try pressing these buttons for 5 seconds, it will unlock.
OR
Press the "menu" button until you see"CHILD LOCK: ON" appear in the display. (if nothing is pressed within 10 seconds following this the menu will close and it will default to program in the display)
Once you see what I just mentioned in the display press the "select" button until"CHILD LOCK : OFF" appears in the display.
Finally by pressing the"start/pause" button the key symbol should disappear confirming you have successfully unlocked..
Pl click if helped.
Apr 28, 2013 | Bosch Washing Machines
My machine show a 01 and a flashing key I try to do hold a button for 5 sec to deactivate but time tab it's not reacting with at is the prob
Your washer is in the "child lock" mode, hence it won't allow any program. Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. If nothing is pressed within 10 seconds.following this the menu will close and it will default to program in the display. Once you see that in the display, press the "select" button until "CHILD LOCK :OFF" appears in the display. Finally by pressing the start/pause button the key symbol should disappear - confirming you have successfully exited the child lock program.
Pl click if helped.
Mar 14, 2013 | Bosch Classixx WFL 2066 Front Load Washer
Comunication error
At first turn the machine off, and then press the start button, reverse button and auto lock button at the same time.
-Turn the machine back on while still pushing the three buttons. After the machine has powered on, release the buttons.
-Press the + sign at the bottom of the screen, continue pressing each + sign as it appears. The machine will display a "Test Complete" message, turn off your machine.
-Wait 5 to 10 seconds before powering your machine back on, your machine will run through a diagnostic test and repair any issues it finds.
If this doesn't work;
Have you set up communication is to the "COM Port" designation within Customizer/Digitizer.
Go to >ScanCard >Communication Settings > choose the COM Port you want to use (find out what COM port the cable's using by going to your Start/task Bar in Windows>Control Panel >System >Hardware >Device Manager >Ports (COM & LPT).
There, you should be able to see what port your cable's using.
Hope this helps
Nov 03, 2011 | Janome Memory Craft 9000 Computerized...
Washer Bosch Classixx 6 1200 Express. The machine is displaying a "key locked" sign in the timer countdown panel. As there is no button to press to lock/unlock, how do I getr rid of this sign. ...
You need to press 2 buttons simultaneously for 3 to 7 seconds. Look for a small child's face or a lock icon (Sometimes both) on the Facial panel, there will be arrows pointing from that icon towards 2 buttons, these are the 2 you need to press.
Hope it helps
* If you found this solution helpful, please vote positively.
Feb 18, 2011 | Bosch Washing Machines
I have a bosch clasixx machine there is a symbol like a key on timer and machine wont start how do i get rid of this
Hello, Welcome to fixya.
The Key symbol means the lock has been activated some how.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry and good luck going forward.
Regards,
Macmarkus :)
Oct 20, 2010 | Bosch Washing Machines
Washing machine shows key on the display and won't start
Regards,
Macmarkus :)
Oct 20, 2010 | Bosch Axxis WFL 2060 Front Load Washer
How can i turn off key symbol
Hello Lucy and welcome to Fixya.
As far as the "signal" activation or de-activation goes, it should be performed before starting a load of laundry and it is as follow's... 1) Turn the program selector to any program as you would doing laundry. Add your items... 2) When you close the door the "start/pause" light flashes... 3) Press the "menu" button until the signal indicator is displayed and flashes ( a small speaker symbol ) as does the start/pause light. If no buttons are pressed within 10 seconds, the current setting will be saved. 4) Press the "select" button until the desired volume or "off" is reached/displayed. 5) Press the "start/pause" button so the program starts and the setting is saved after the cycle has completed. As for the "key" symbol, your washer has a "child lock" program and the symbol indicates it has been activated.
Thank you for visiting "fixya" for your washer solution inquiry.
macmarkus :)
Jun 16, 2010 | Bosch Washing Machines
Key sign on appearing on digital display- tried to load and unload open close door but in all temperatures and programs the key sign appears and the machine is not starting
This is the child lock. It prevents the buttons working.
Press and hold the 'MENU' button for until the symbol disappears (about 5-6 seconds)
You can activate it the same way once the cycle is going thus preventing accidental changes to the programme.
Annoying until you know how, but useful when you do.
Regards
Blitzspear
Apr 20, 2008 | Washing Machines
CL on display panel - washing machine will not respond
CL stands for child lock to take it off press and hold TEMP and TIME DELAY at the same time and this should remove it
Dec 11, 2007 | Washing Machines
Washing Machines Logo
88 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
