Toshiba SD 240E DVD player - No sound
I have a toshiba SD 240E disk player. It plays disk, I get picture but no sound. Tried another cable and tv, same thing happens. How do I fix?
techman
  • 3130 Answers
SOURCE: DVD plays with sound but no picture
Have you checked the unit on another input or another set to eleminate the video input? also try the video cable. If theres sound and no video and you tryed then the video output amp in the player has a problem and the only way to fix this would be with a schematic and a scope to trace out the video signal. Good luck
Posted on May 25, 2006
Benimur
  • 6966 Answers
SOURCE: How to play a DVD on my Toshiba DVD Player
Using the Toshiba's remote, select either Video (1...X, if several) or S-Video depending to what Video INput the DVD was connected to the Toshiba.
Good luck and kind regards.
Posted on Nov 25, 2007
SOURCE: Toshiba SD 3960 DVD player
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
  • 979 Answers
SOURCE: connecting toshiba sd-k860su dvd player to a jvc amp. and comcast cable box
Is the pix black or blue?...accordianman
Posted on Feb 25, 2008
SOURCE: My Toshiba SD-3960 sound does not work.
My Toshiba DVD Player does not work. I can not watch online movies. What I ca do? Please send me if you have any suggestion.
Thank you.
Posted on Aug 30, 2008
I have a Toshiba DVD Video Player Model SD 260. I
Hello, The problem could be dirt on the surface of the lens, you can clean this by removing the cover of the dvd player . Gently use a dry cotton bud to clean the lens because the lens is fragile. Insert the disc plate into the dvd player and press play, if it does not play try the second method. Ensure the cover of the player is open, connect the power plug to the mains socket and observe the lens if it beam a red light, Also check the ribbon cable use to connect the lens to the printed circuit board, then gently clean the lens with a dry cotton bud , insert the disc plate and press play to see if it play. If it does not play the disc, then this require a change of the lens
May 20, 2010 | Televison & Video
Only sound and No picture in Toshiba DVD/VCR combo
maybe your connections are wrong.
The yellow pin is for video, while the white and red pin are for audio left and right.
So, your wires will be connected to video and audio "OUT" from your player and connected to "IN" respectively on your TV.
That's how it gos. Its a input and output law. The Player will be sending out the pictures and sounds (OUT) and the TV will be receiving from the other end (IN).
Its as simple is that. But if there is still no picture, then cross check your video wire (yellow), maybe its bad.
Good luck.
Apr 28, 2010 | Toshiba SD-V392 DVD Player/VCR
My toshiba SD 6100 dvd player is playing only blue screen
just tried with RCA or the hightdef. cables the one with Green bue and red.
Aug 24, 2009 | Toshiba SD6100 DVD Player
I have got sound but no picture on my toshiba dvd player,model number:sd-308kb,have tried various new scart leads,all to no avail,can you help,thanks,andy.
My Toshiba sd-310v required a S-video cable and
input programming at the TV to acquire a video signal. Hope this helps.
Aug 20, 2009 | Televison & Video
Tv built-in dvd player wont play thru surround sound
goto your menue setings and slect sround sound and set up to external sound system.
Jan 10, 2009 | Toshiba LCDTV/DVD Player 19HLV87
We hooked out Toshiba SD-V291 up to our Sony TV through a Direct TV Cable box. We get the sound when we play a DVD but no Video. We hooked it up with an SVideo cable and input/output cables. What are we...
I just had the same problem, and I am using rca blue, red and green cables for video. I unplugged them and plugged them back in again a couple times and it finally worked. I have had this problem before with another dvd player, don't know why. Hope this helps.
Chris
Dec 27, 2008 | Toshiba SD-V291 DVD Player/VCR
May 25, 2006 | Toshiba SD-230 DVD Player
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
