Question about SanDisk Sansa Clip MP3 Player
How to turn sansa sandisc from radio to playlist?
Call me crazy but I got this on woot/loaded music and pressed some button, which one I dont know but I got FM radio that I didnt even know it had. Great and all but how do you go back and forth from radio and music on playlist????
  • 8,596 Answers
Press the home button to go back and forth between menus - here is a link to the user manual:
http://www.sandisk.com/sansa/assets/English/products/Clip/Clip_userguide_en.pdf
-Tha Mp3 Doctor
Posted on Jan 01, 2009
My Sansa e260 can't read sdhc cards
From what ive found the max expansion card it supports is 6gb they might offer support for higher capacity cards with a firmware update but as of right now no they don't
Nov 05, 2009 | SanDisk Sansa e260 MP3 Player
My sansa clip is stuck on radio, re-setting does not work,
Can you see your screen? If not turn on your player and press the home button. Press up once and play 2 maybe 3 times to get it back on your whole playlist section. It should start playing music then.
Sep 25, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip mp3
You do not need special software - it acts like an external drive. Just drag the files to the proper folders on the Sansa or use Windows Media Player to create playlists and sync your player to WMP. Then everytime you update your playlists, your player will be updated when you connect again.
The larger Sansa's like my 8 GIG has software for converting video to play on it, but the screen is too small - you will go cross-eyed trying to watch a movie.
And the best place to get these things is on Woot.com. I paid $10 for my 1 GIG clip! Yee - Haww!
Feb 03, 2009 | SanDisk Sansa Clip MP3 Player
How to change the time settings in sansa e250R
scrolling down to Settings and select
Date & Time...
after you select it..just change the date and time from there..
I hope that helps..
Please rate accordingly
Thank you
Computerrep..
Should you need the device manual, please click on the link below...
http://www.woot.com/files/sansae200manual.pdf
Dec 16, 2008 | SanDisk Sansa e250 MP3 Player
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
Making playlists
yes you can create playlist using WMP11...
To create playlist using WMP
  1. 1. Click the Library tab. If you need to clear the List pane before beginning to create your playlist, click the Clear List pane button playing_i_clearlistpanebtn.gif.
  2. Drag items from the Details pane to the List pane to add them to the new playlist.
    To select multiple adjacent items, press and hold the SHIFT key while selecting. To select nonadjacent items, press and hold the CTRL key while selecting.
  3. To rearrange items, drag them up or down in the List pane.
  4. To save the list, click Save Playlist at the bottom of the List pane, and then type a name for the playlist.
    By default, playlists are saved with a .wpl extension in the Playlists folder, which is usually located in the Music folder. You can also save playlists with the .m3u or .asx extension. To do so, click the List button at the top of the List pane, click Save Playlist As, and then change the extension in the Save As dialog box. Once you save the playlist, it's added to the Playlists category in the library.
    To play the playlist in the List pane, click the Play button playing_i_playbtn.gif.
  5. To access the playlist in the future, click the Playlists view in the Navigation pane.
I hope that helps
Thank you
Computerrep
Jul 19, 2008 | SanDisk Sansa Connect MP3 Player
I have Sanso m250 2.0gb mobel. Logo screen is appearing when i power on after that i am unable to play the mp3 songs or play FM Radio etc..
Try doing a hard reset on a Sansa m250:
  1. Turn off the Sansa. Just pull the battery out for a second.
  2. Plug the Sansa into a computer4.gif, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC4.gif Specific storage" file.
  4. Right click the "MUSIC Specific storage" file, and press "Format."
This should hard reset the Sansa m250. I do not know if this will work on other Sansa m200 type .mp3 players. You can start over with your playlists. This has worked for me.
Dec 23, 2007 | SanDisk Sansa m250 MP3 Player
Sansa m240
Hi. I'm having the same problem with my m250 and am concerned, since I've only had it for a month. Nothing I do, including removing the battery, hooking it up to my computer again, or holding the power button down for a long period of time works.
Feb 04, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
97 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
