Question about Sony Handycam DCR-TRV250 Digital Camcorder
Tape "sticks "during playback
During playback picture and sound stop and go, like the tape is "sticking" . Happens with all tapes. The same tapes play normally in another (TRV 280) camcorder.Please advice
I was having the same problem and after reading Joe's answer, I decided to see if I could free the drum motor brush of whatever rust or contamination was under it. I recorded for awhile and then fast forwarded and reversed some. It worked!!!! Thanks Joe. Rick
Posted on Aug 20, 2007
    Sniper:
  • 80 Answers
The drum motor in this camcorder has a earth brush assy which makes contact with the lower portion of the motor removing static charges from the video head assy. This brush becomes contaminated and looses contact with the drum motor which causes the "stuttering" effect you're seeing in the video. This problem can only be resolved by a qualified service tech., it requires complete disassembly of the unit too gain access to the drum motor. Hope this explains what is going on. Joe Weibel customelectronics.org
Posted on Feb 16, 2007
Picture Rolls Vertically during VHS playback on EWC19T3?
Hello
If the fault is only with tape play, and not with on air programmes, it is surely either with the tape or with the mechanism. Look at the tape filim for any curl at its bottom edge. If there is curling, rolling will occur becuse, contol signals are recorded at the botton edge of the tape. If top edge hage curling, sound will be effected. If there is no such mistake with tape, the pintch rollar of the VCR mechanism has worn out, and should be replaced. OK.
Jun 30, 2011 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
No picture. Camer drives tape but does not record
Playback no picture? Try to clean the head by inserting cleaning cassette. During camera mode, i don't know if you see anything in your monitor. What you see is what you can record on tape so may be your problem starts from here, please elaborate more.
Jan 05, 2010 | JVC GR-D290 Mini DV Digital Camcorder
I have a blue screen during playback mode on my Sony DCR-HC32. I am not able to see anything I recorded. What should I do?
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
  1. Stop the tape.
  2. Ensure the tape has been rewound to the beginning of the video recording.
  3. Play the tape.
  4. If the issue is not resolved, stop the tape and remove it from the camcorder.
  5. Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
  6. Reinsert the tape into the camcorder.
  7. Play the tape.
  8. If the issue is not resolved, stop the tape and remove it from the camcorder.
  9. Insert a different tape with video footage into the camcorder.
  10. Ensure the tape has been rewound to the beginning of the video recording.
  11. Play the tape.
Aug 06, 2009 | Sony Handycam DCR-HC32 Mini DV Digital...
Picture visible only during fast forward
You have dirty heads, hence the blue screen, either try using a head cleaning tape, although these do not always do a through job, or if you remove the top cover & using a head cleaner fluid, VERY GENTLY wipe the heads at the sides of the round silver drum using either a head cleaner stick with the fluid or a piece of sturdy card. DO NOT put too pressure against the head or you will damage them completly & would need replacement heads. Leave them a few minutes to dry then try playing a tape once more.
Aug 01, 2009 | Panasonic Televison & Video
Colored, pixilated bars appear during playback
It is very common when the magnetic heads got dirty. Buy a Mini DV cleaning tape, follow the instruction clean the heads by playing the cleaning tape for a while. Record NEW video and playback to test.
Please know if you play the old video recorded buy the dirty heads, you may not get clear picture, because here is not correct data recorded on the tape.
Apr 09, 2009 | Canon ZR90 Mini DV Digital Camcorder
My camera does not show what i have taped
Regarding no picture in playback is problem mostly of dirty / clogged video head in Sony handy-cam and can be corrected by using good quality video head cleaning tape.
As far as memory stick picture concern, I think lost pictures (42)would be in other folder on memory stick.
Jan 12, 2009 | Sony Handycam DCR-TRV320 Digital Camcorder
Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Dec 06, 2007 | Video Cameras
No Picture, sound or anything during playback...
cleaning cassette may help - if the picture comes back but soon goes blue screen ? your heads need thorough cleaning or replacement ;
Jul 30, 2007 | Canon ZR100 Mini DV Digital Camcorder
Playback not working
Hai, Clean Video Head with Head cleaning Cassatte & check the picture. udupi M/s.Prathiksha Electronics
Mar 18, 2007 | Canon MV450i Mini DV Digital Camcorder
E04 message
Lisa, E04 is an error code which shows that one or both of the reels has stopped during play or record operation. We find that tapes with liquid contamination can stick to internal parts in the mechanism causing this error. Try another tape, if this does not resolve the problem something is defective in the tape transport. Good Luck to you! Joe Weibel customelectronics.org
Feb 09, 2007 | JVC GR-DVM70 Mini DV Digital Camcorder
Sony Handycam DCR-TRV250 Digital Camcorder Logo
141 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
