Question about JVC AV-20F476 20" TV
JVC AV-20F476 hi, sir can you help me to my tv jvc av-20f476,they problem is intermitent power.thanks
    President:
  • 1,284 Answers
Intermittant issues are always the hardest to troubleshoot. It could be a loose connection or a component that breaks down under load or thermally.
Posted on Feb 15, 2007
SOURCE:
My JVC model AV-20F476 has a black-out box that covers most of the bottom half of the screen.
Go into menu and under CLOSED CAPTIONS look to see if TEXT is engaged---if it is set to text 1 turn it off or to text 2,3,4, etc
Text was a feature never really used but it is there, some cable boxes also have this setting/feature.
Let me know if you have questions.
Jan 11, 2012 | JVC Televison & Video
Colour wierd in corners of screen
do you have any speakers or magnets on top or near the tv.......if so move them away from the tv...thanks
Jan 04, 2010 | JVC AV-20F476 20" TV
JVC AV-36D502: Input #3 doesn't work
Good day sir, its a different issue, about the capacitor, for as long as your replacement part is correct, it will work, now, there are several things you should check, the I/O device that controls the inputs of the TV, usually an IC, check your schematic diagram to trace the fault. check also the line from the input 3 to the controller IC on your diagram. Measure the voltage across the IC Vcc to ground if the IC is getting the right power, Low voltage can be cause by faulty capacitors, on the power supply line, or the IC itself is faulty, Circuit analysis and voltage measurements are needed to trace the faulty part. hope this helps thanks.
Oct 23, 2009 | JVC AV-36D502 36" TV
JVC AV-32F702 Color TV shuts off after I power it on.
Any malfunction associated with a flashing light usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 12, 2009 | JVC AV-32F702 32" TV
Can't find code for JVC AV-27220 tv remote
Hi Please follow this link and u can get the full manual to fix the problem.
Please review and say if it helped thanx
<a href="http://www.nodevice.com/manual/newmans/AV-27220pdf/get16984.html">Download JVC AV-27220 Service Manual</a>
Apr 19, 2009 | JVC AV-27220 TV
RED BLINKING TIMER TV WONT TURN ON
Page 40 on the PDF link below may help - Ask me if you need further assistance.
Thanks
Len
http://resources.jvc.com/Resources/00/00/99/51798Cien.pdf
Feb 28, 2009 | JVC AV-32230 32" TV
LOOKING FOR OPERATORS MANUAL FOR MODEL AV-32890
http://www.retrevo.com/s/JVC-AV-32D302-TVs-review-manual/id/279ag311/t/1-2/ - 65k -
Feb 13, 2009 | JVC AV-32D305 32" TV
Green picture
Hi
Is the screen permanately green or intermitent ?
If you have taken the back off the set who is the CRT (tube) made by there will be a large lable on the CRT.
Oct 10, 2007 | JVC AV-27D303 27" TV
JVC TV model# AV-32920 No Power
SOUNDS LIKE HORIZONTAL OUTPUT IS GONE
Feb 21, 2007 | JVC AV-32920 32" TV
JVC AV-20F476 20" TV Logo
154 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
