Question about Epson Stylus Photo R220 InkJet Printer
Need help pn using 4X6 photo paper not sur how to start printing on my R220 I lost my manual Ty Alan
    President:
  • 2,110 Answers
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
When I use my Brother MFC-465 CN printer to print 4X6 photos with the photo paper bypass tray in proper position, it jams sending the photo paper through. Printer is set to 4x6; software set to photo as...
Hi there!
The compatibility of the paper may affect the issue that you are having. I have a brother printer also and prints on 4x6 size what i can suggest is to try turn the photo paper upside down, so facing the tray, 2 sheets at the bottom should have the glossy side up. and the sheet where you need to print the photo should be facing down. So when the paper roller grabbed the photo paper at the top it will smoothly pass thru,
Hope this helps! Vikroks
Mar 06, 2011 | Brother MFC-465CN InkJet Printer
I can not get the 4x6 paper to feed into the printer during the printing process. the paper shoots through and the printer. screen says the paper is incorrect size. i am using kodak ultra premium photo...
Kindly place the paper in the photo paper tray and then place a photo on the scanner glass of the paper and press copy.Correspondingly,if you are printing from computer make sure that you select 4X6 in the printing properties or preferences while printing the pictures. Your issue will be solved.Keep me posted if you are facing any problems.
Dec 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have a photosmart 8250 using iphoto, how do I print 3x5 using 3x5 tray?
Set the default printer driver settings to print 10 x 15 cm (4 x 6 inch) photos
  1. Make sure 10 x 15 cm (4 x 6 inch) photo paper is loaded into the photo tray. NOTE: The Photo Tray light on the printer does not have to be lit when printing from a computer.
  2. Click Start and then click Control Panel .
  3. Click Printers and Faxes .
  4. Right-click the icon for the HP Photosmart 8200 Series and select Printing Preferences .
  5. On the Paper/Quality tab, select 4x6 or 4x6 with tab from the Size is drop-down menu (under Paper Options).
  6. Make sure that the Source is box is set to Photo tray .
  7. Click the Borderless Printing box if borderless prints are desired.
  8. Click Apply and then click OK .
  9. Open the software program you wish to use and set up the pictures you want to print. Make sure to select a 4x6 inch layout for the photos within the software program before you print from the software program.
Oct 11, 2009 | HP Photosmart 8250 InkJet Printer
Epson Stylus R220 Photo InkJet Printer
Check for obstructions (ie tiny pieces of paper and other foreign objects)
Clear the obstructions.
press the paper button
Turn it off then do the self test and check if the printer will printer without using computer
self test (press and hold the paper button and press and release the power button, if you can see the green light is flashing release your hold on the paper button. By the way make sure there is paper on the printer)
If it prints good then you need to check the settings on your computer.
Nov 10, 2008 | Epson Stylus Photo R220 InkJet Printer
I 560--photo printing on 4"x6" paper
You should be able to do this in print preferences. Open up your general printer box by clicking on Print. Select print preferences then page setup then select page size and a list of sizes will appear just select 4x6 and then paper type, press print and you have done it.
You might be able to get a manual from the Canon website or 'google' for the one you want.
Please remember to rate this solution.
Nov 05, 2008 | Canon BubbleJet i560 InkJet Printer
Epson R220 not printing
Sounds like you knocked the vacuum pipe off at the pump cap when you had it apart. Take it apart again and check the vacuum pipe for connection, blockages and being trapped between cases when you reassembled it.
Nov 03, 2008 | Epson Stylus Photo R220 InkJet Printer
Won't print a 4 x 6 print. Paper passes right through printer
Hi-
Double check on printer properties under printers and faxes if 4X6 is selected, then access printer properties as well on the application or program where you are printing the images by clicking File then print option. Make sure Epson is the default printer.
Keep us posted, thanks!
Aug 23, 2008 | Epson Stylus Photo R220 InkJet Printer
Will not go to photo tray to print 4X6 picture
This is why Mac's are EVIL!!!! LOL, anyway try using the software, that comes with the printer, and tell it which paper type, and tray to use. Also try printing on a PC, and see if it works then, as you may have to live with this as the solution.
Feb 22, 2008 | HP Photosmart 3210 All-In-One InkJet...
Printing photos
Of course you can use 4x6 photo paper
you have select the paper size from page setup as 4x6
and put the paper in the tray after adjusting the tray size
Dec 27, 2007 | Samsung CLP 300 Laser Printer
Epson Stylus Photo R220 InkJet Printer Logo
44 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
