Question about Intel Motherboard
Pwr switch, hdd led , pwer led
I took the wires out now i cant put it back in
    Scholar:
  • 149 Answers
You'll need good light and a steady hand.....locate on the motherboard a set of between 10 and 18 pins (2 rows) look at the board either directly below or above the pins to find a kind of key or map as to where the pins are located....they'll be in abreviated form and should indicate where and which row the connectors should be located
Regards
Posted on Dec 06, 2008
I have a GA-81865GME-775-RH motherboard, which i put into my box, made all the connections, but have no power once I switch the box on. I suspect it has something to do with the wiring loom running from...
Hello julian_ad681
I will tell you how wire your case front panel, but before that lets test the motherboard to make sure the problem is not the board itself.
Remove all the wire connections to the front panel.
Turn the power on and with a small screw driver or anything that is metal short (touch) the two pins that are the PWR SW. (look at the list of pins I have put at the end)
If the computer turns on then it means the board is ok.
The following information is also availabe in the motherboard manual available from the gogabyte web site download section
On the motherboard next to the battery is the front panel header pins. it looks like
0 0 0 0 0 0 0 0 i also write them as numbers as well to make it easy for you)
0 0 0 0 0
1 2 3 4 0 0 0 0
5 6 7 8
1 and 2 are message LED. you don't need any connection to this.
3 and 4 are the power switch connections no polarity, just connect the wires
5 and 6 are the hard disk LED. 5 is the positive side (usually red)
7 and 8 are the reset switch. no polarity, just connect the wires.
Next to the message LED there is a three pin connection. This is for the power LED.
hope this has helped you.
please leave comment, vote if the helped
Feb 10, 2011 | Intel Motherboard
I have an emachines t2385 and cant figure out what order the pwr switch pwr led and hdd led wires plug into the motherboard. On the motherboard, there are 4 sets of 2 pins and 1 set with 1 pin. Can any one...
There should be a table indicated on the motherboard that says LED+ LED- PWR SWCH etc... You match those up the the descriptions on the cables. Or you may be able to find a possible layout on your supplier's website. You may have to bring it to an expert or trial and error. Personally I would trial and error.
Oct 12, 2010 | E-Machines eMachines Desktop PC
I cleaned my pc, and disconected the wires that are right downside corner. I cant remember how to put them back rightly. Any help? hdd led power led + power led - power switch (sw) reset switch (sw)
H57H-AM2 v2 Motherboard in a Gateway DX4840 wire connections for Front Panel are shown here in Photo. I took them before I disconnected mine so it works.3_3_2012_12_10_44_pm.jpg3_3_2012_12_10_56_pm.jpg
Jun 15, 2010 | EliteGroup ECS L4VXA2 (CDL4VXA2)...
I need the wiring diagram for power,reset,lights
there is no need for the wiring diagram
if you check *********** board properly
you could find written in small font like
PWR SW for power switch
RST SW for rese switch
HDD LED , PWR LED etc
May 05, 2010 | Wintergreen Lindows Webstation (M810L11L)...
I have an emachine W3080 that I unplugged the front panel wiring, power switch, power LED, and floppy LED and dont remember which pins they plug into. Can you help?
their should be some abrevations like pwr led, pwr sw, hdd led by some metal pins in one of the corner of the motherboard
Feb 26, 2010 | Computers & Internet
Power Button wire to mother board power led power sw HDD Led . what pin connects to the three wires from power button. Led Power wire to what pins, HDD Led to what pins and power SW to what pins on the...
There are may motherboards, but most have writing on them as to what is suppose to plug where. For example, for the power switch, the lettering might be "Pwr" or "Power" or "Pwr sw". The pins are usually together and should fit the plug on the end of the wire.
Nov 25, 2009 | E-Machines eMachines Desktop PC
I have an 945gzt-m v 1.0 and dont know were the pwr sw wire goes
Yes.
First, let's orient the view of the motherboard, so we are both looking at it the same way.
The processor is at the top middle, and the Front panel header, is to the very bottom right hand corner.
Right next to the motherboard mounting hole.
The Front Panel header goes across the bottom edge of the motherboard, lengthwise.
Looking at the top row of pins on the Front Panel header, No.2 Pin is at the far left. Pins 2, 4, 6, 8 and 10, go across the top.
Looking at the bottom row, No. 1 Pin is at the far left. Pins 1, 3, 5, 7, and 9, go across the bottom.
The power switch wires go to Pins 6 and 8.
The HDD LED wires go to Pins 1 and 3.
The power LED wires go to Pins 2 and 4.
On the power switch wires, the Positive (+) wire goes to Pin 6. Just in case this wire is marked.
(Doesn't really matter which way it goes, because it's a switch!)
On the HDD LED wires, the Positive (+) wires goes to Pin 1.
On the power LED wires, the Positive (+) wire goes to Pin 6.
Apr 15, 2009 | ECS 945GZT-M (V1.0) Motherboard
Emachines t2865 power led diagram
The header connections that you are looking for are on the edge of the motherboard near the battery. Look for a group of gold contacts sticking straight up at you. The silkscreen tells you which header are for what light or switch. You will see one that says "PWR LED". Another says "PWR SW" Another says "HDD LED". They are printed very small. You will see others in that vicinity that say "SAST1" and "SPKR". Ignore them.Look along the edge where the battery is mounted some are located around the nearby corner but still along the edge. All should be on the edge nearst the front of your machine. Others may be along the edge facing the bottom of your machine.
Jul 28, 2008 | E-Machines eMachines Desktop PC
Pwer led,resetsw,hdd led,pwer sw
It appears your board is made by Jetway.
Heres your link for the manual:-
http://www.jetway.com.tw/jw/downloadshow.asp?productid=V266B#
You can also download drivers et,c. from the same site.
Please don,t forget to rate the Post.
Best wishes mike @Compurepair
Mar 29, 2008 | Intel Motherboard
Need help bigtime
are those all seperate connectors for the button? Or are they all together on one block? Should be something near bottom right hand corner of mobo saying pwr, hdd, sw, snd, led, that kind of thing
Mar 24, 2008 | E-Machines eMachines Desktop PC
Intel Motherboard Logo
37 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
