Question about Roxio Xingtone Ringtone Maker
AcmStreamOpen Failed Code 512
I keep getting this message: make clip smaller Started at 20 sec. ringtone down to 10 seconds and I'm still getting the above message. I tried MP3 amd WMA. Please help!
How can i unlock my tablet
Perform a factory reset instrutions in back of hand book.
Aug 23, 2014 | Tablets & eReaders
The CD player and the CD changer don't work in my 2001 A6. I get the message CD ERR 1. Can you tell me what the error message means? I bought the car used, and never got any manuals. I also have a...
Is there a CD inside the CD player? You could try pulling the fuse for the radio (look at the fuse box panel for the exact fuse) and leave it out for 10 secs, then turn the car to the on position and leave for 20-30 secs.. turn the car off and put the fuse back in and then turn the car on and if you;re lucky, the radio will reset... This works for Volkswagens and since Audi is the same company, it should work
Aug 16, 2009 | 2001 Audi A6
I am getting an error message "S545"
Fuser unit malfunction code.Check the connectors,thermistors and thermofuses.Reset the code :enter in the service mode (press total clear yellow key and pres 1-0-7 press and hold down more 3 sec.the Clear key (red C key)) turn OFF the machine,umplugged the cords wait 10 sec,plugg the cords amd turn ON the copier.
Aug 14, 2009 | Ricoh Aficio 1035 Copier
Does my digital camera shoot video?
yes, and here are your cameras video specs too AVI - 640 x 480 - 6 sec - With 8.3MB built-in memory , AVI - 512 x 384 - 11 sec - With 8.3MB built-in memory , AVI - 320 x 240 - 27 sec - With 8.3MB built-in memory , AVI - 640 x 480 - 600 sec - Max clip duration , AVI - 512 x 384 - 600 sec - Max clip duration , AVI - 320 x 240 - 600 sec - Max clip duration
digital video format =AVI
Jul 22, 2009 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Dell optilex gx270 error message!
I think you should just reload the operateing system. I had the same problem and couldn't fix it
,luke
Jun 22, 2009 | Nokia N81
LG Vu phone-can't make a ringtone be a message tone
you can move a foulder to the message tones but it has to be under 20 sec and 300kb.
Mar 16, 2009 | LG Vu CU920 Cellular Phone
Ringer too quiet
I do apologize for your issue with the quiet ringer. Especially if you have some important calls you are waiting for. Somethings to keep in mind. Everyday, you want to make sure you power down your cellular phone completely for about 10-20 seconds. That way it's refreshed.
Second, check your profile on the phone is on silent,meeting,outdoors,normal,etc? When you highlight either of them you can customize it. Make the volume higher. Also, for testing purposes set only factory made ringtones, which are already on your phone. Test them all out, and see which ones are sufficient. A lot of times if you download ringtones or use MP3's as ringtones, they are not loud enough.
I know this will assist you with your phone and ringers!
Cheers!
Feb 04, 2009 | LG Cell Phones
Making your own ringtones, not using verizon
Any sound, including recorded sounds, that are sent offers the option to save as ring tone upon opening the file. You do not have to send as a picture file.
Highlight the sound under your sounds file, select "send", and send it to your own number. When you receive it, open it and select options. One option (scroll down) is to save as a ringtone.
I do this all the time, so it absolutely works.
Jul 13, 2008 | LG enV VX9900 Cellular Phone
My computer shuts down after 3 secs
Try to separate the power cord of your monitor from your system or maybe if your using UPS(uninterrupted power supply) directly plug the UPS to the wall outlet. either you can use pretty voltage regulator to the regulate the AC power.
if not solve the problem try to examine the your system power supply.
Dec 11, 2007 | Computers & Internet
Problem with the number of rings
Remove the voicemail or extend ring time
don.t know is this code works world wide but you can try otherwise ask the provider to lengthen the ring time to 30 secs
then enter country code IE 61 for australia
* then vmail number IE 321 for optus
**30#
so your code should look something like this
**61*321**30#
then hit call.
remember the 61 and the 321 will vary on country and provider
Nov 09, 2007 | Motorola Mobility RAZR V3
Computers & Internet Logo
306 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
