Question about Gateway Tabor 3 (4000532) Motherboard
Hooking up an ATA card
I recently replaced my Promise Ultra66 board. My problem is I didn't pay attention to where it plugs onto the motherboard. Can someone please help me Thank you
    President:
  • 2,961 Answers
What ata card have you got? Do you mean PCI or AGP card?
Posted on Feb 15, 2007
64 bit driver promise ultra
There is no official Window 7 driver for the Promise Technology Ultra 133 TX2, but you can use the Vista driver. It should also work for both the Ultra 66 and the Ultra 100 cards.
I found the Vista driver at:
http://www.promise.com/single_page_session/page.aspx?region=en-US&m=722&sub_m=sub_m_9&rsn=144
The file name is: Ultra133 TX2 windows 2.1.0.3 logo driver.rar
This file is compressed in the rar format. I decompressed it using 7-Zip. Folder amd64 contains the 64 bit driver. The amd64 driver worked even though my mother board has an Intel CPU and chip set.
Oct 31, 2013 | Promise Ultra100 ATA/100 Pci (ultra100 tx2...
In bios is the card not by System Windows XP found is the answer no HDD found. please in Germany Antworten, answer help in Germany thank you!!!
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
could be a dirty graphics card you might have remove the graphics card and clean the socket
also check your computer ram to make sure they are securely seated and the
hope this helps you
Sep 01, 2011 | Promise 2PORT Serial ATA/150 Ctlr Plus...
LONG PEEP ,I TRIED ANEW RAM AND NEW VGA BUT NOTHING CHANGE
I am guessing, that you have your board laying flat, and the computer is unhooked from all the cables.
first thing is to make sure that all your sockets are clear of dust by blowing high pressure air to the board (dust is a killer of boards).
ok onto the next step turn the computer over to check for lose screws that might have dropped onto the motherboard
ok next is that all of your cards are clean dust free you can take a static free cloth or high pressure air to clean/clear your cards then replace all the cards and memory sticks
if you have a extra power supply that you know is good or a friend has one thats good try hooking that up first.
If your computer fire's up now then you can try your power supply if dosen't work then you have boiled your problem down to your power supply and that it should be replaced
Dec 26, 2009 | DFI NT70-SC Motherboard
I have a GX 280 and get the mesage ultra 100 is not installed. I do have a promise card installed. I cannot get to bios
ultra ata 100.. ide cable .. may be bad.. or the controller on the motherboard is causing the issue
try to pull the ide cable off the board.. do ya see the bios then???
if so first replace with a different 80pin ide cable.. or buy a new one..
test the drives attached to the ide ribbon gray cable in another chassis... if the all is good.. and you still can not reach the bios..
use the clear cmos or bios directions on the gx280 manual online at dell
else the motheboard has gone bad
Sep 29, 2009 | Dell OptiPlex GX280 PC Desktop
Promise Ultra133TX2 runs at 66MB cannot see beyone 32GB
1) Flash the BIOS to the latest one. It's here.
2) Use this driver which is the newest one. Here.
This should fix your issue.
Nov 21, 2008 | Promise Ultra133 TX2 ATA Controller
Black screen on gateway 450sx4 laptop
sounds like ,audio card went died or mite be screen has shorted out try hooking it up an orther screen and see if it boots up if so either viedo screen card or screen it self
Jun 02, 2008 | Gateway 450SX4 Notebook
Incompatible issues with promise ultra 100 ata
This is the driver that you need. Has both Vista x86 and x64 drivers.
http://www.promise.com/upload/Support/Driver/Ultra133%20TX2%20windows%202.1.0.3%20logo%20driver.rar
Jan 12, 2008 | Promise Ultra100 ATA/100 Pci (ultra100 tx2...
New Motherboard
have you check your bios configuration? if no please do.
Nov 01, 2007 | HP Pavilion Media Center TV m7330n...
Mobo reads less ram than windows
possible that you have incompatible mem installed, the archictecture of the mem could be 32mb x 64bit could mean that the "BIOS" may only be able to see 32Mb x 8 which to me suggests that this is not the correct mem for this Motherboard, is this mem recovered from another system or an old board. Try Kingston.com and use their memory configurator to find the correct mem for your motherboard (enter the MB manuf and model)
Aug 16, 2007 | Promise Ultra100 ATA/100 Pci (ultra100 tx2...
Gateway Tabor 3 (4000532) Motherboard Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
