Question about Air Tools & Compressors
CRAFTSMAN NAILER CRAFTSMAN FINISH NAILER,WHEN I PULL TRIGGER WONT NAIL,LIKE IT HAS NO AIR PRESSURE,WAS WORKING THEN NO MORE.IS IT WORTH FIXING?O RING? THANK YOU
  • Anonymous Mar 31, 2014
    i need to know how to load nails into nailer after jam is fixed
I had the same issue with an older craftsman 351-18309 brad nailer and crown stapler. When I pulled off the top of the piston, there was a denigrated o-ring. I took an ear bud for my Bluetooth headset, cut it to size and stretched it to prevent it from holding the spring... And I'll be damned it worked! It both tools!!
CRAFTSMAN NAILER - /uploads/images/9_1_2014_6_12_26_pm.jpg
Posted on Sep 01, 2014
    President:
  • 1,388 Answers
Generally, if your nailer is not leaking air, the orings are probably ok. Remove the head and check for stuck headvalve or stuck driver/piston. Make sure that you can press the headvalve into the head with your thumb and that it returns. If your driver/piston is down when you pull the head, remove the cylinder and check for damage to it or the bumper. Some cylinders have an oring or strip of rubber about med section which acts as a check valve causing the piston to return to top. Check for bent driver or broken tip causing driver to jamb. Use silicone lube to assemble. Enjoy
Posted on Dec 08, 2008
Freeman PFN1564 shoots air when you disengage safety and pull trigger
if you mean it only shoots air when you pull trigger and not a nail , disconect from air supply and open side of nail mag. (two screws on side) look for forign object in front towards head end , sometimes the paper that nails are wrapped in gets stuck in there , also there is a small spring metal clip at front of mag is this broken off and is unusually short ?
Sep 22, 2014 | Freeman 15 Gauge 34 Degree Angle Finish...
I have a bostitch n62fn finish nailer that wont fire. when i pull the trigger, air comes out of the trigger assymbly. the gun is not jammed, and is receiving correct air pressure.
this may sound stupid but are you pushing it against the wood when pulling the trigger. it has a safety switch on the front so it will not work just by pulling the trigger.
Nov 12, 2011 | Stanley Bostitch N62fn Finish Nailer Parts...
Craftsman evolv braid nailer leaks air around the trigger when i try to nail. it does not nail sears no. 00915206000 mfg no. 42081 (for kit) on gun model:6G28/F50
Air leaking from trigger when trying to nail indicates that the headvalve is stuck or headvalve orings are dry and allowing air to pass. Remove the head and pull out the headvalve piston. Examine orings for cuts or broken (replace as needed if orings worn and cannot make seal). If headvalve was stuck/dry, lube with plenty of silicone paste lube (sold at Lowes in the plumbing dept. ). Should be good to go. Good luck
Jun 30, 2011 | Craftsman 184060184070184080 Brad Nailer...
Paslode 16G finish nailer fires intermittently. Fan runs with each trigger pull but nail only fires about 1 out of 10 pulls if I'm lucky. I've installed a new gas canister so I know thats not the...
Clean it and oil it according to directions, then put a dab of dielectric grease on top of the spark plug. If this does not work ...Change the spark plug. I found one spark plug that had broken in half and made good contact intermittently which caused the problem you describe
Nov 27, 2010 | Craftsman Nailer Kit, Palm Air Driver
Air blows thru the trigger on both my finish nailer and staple gu
there is an o ring in the trigger valve referred to as a Purple o ring that is probably split. If you can find a air tool center that has them you will save a lot of money versus replacing the trigger valve. Let me know what you are going to do and I will help you with the removal of the valve.
Sep 30, 2009 | Stanley Bostitch Coil Framing Nailer
Air bypassing when the trigger is pulled, nail gun will not fire
You will need to get a repair kit for that model and brand nailer. It has a leek in the diaphragm or a bad O-ring.
Aug 28, 2009 | Senco 1Y0013N FP35 1 1/4 Inch To 2 1/2...
Pulling the trigger, air is released but nailer is not engaged
Try putting a few drops of light machine oil in the air inlet fitting. If this solves the problem, install an inline air lubricator.
Jun 30, 2009 | Craftsman Nailer Kit, Palm Air Driver
The nailer shoots a nail when the trigger on the handle is pulled irreguardless of the hammer being used to strike the head
I found a broken retainer ring in the head of the nailer. It had the striker head jammed in the down position so when you pulled the trigger to arm the head with air pressure, the flooring nailer shot a nail.
Thanks ..
Apr 18, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
524 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
