Question about Whirlpool LER5636P Electric Dryer
My dryer is no heating but everything else is working...
Im not sure where the heating element is located on the dryer. I have the back and top off of the dryer. need a little direction which way to go.
  • 640 Answers
Your in the wrong places,,since you have the top off thats good,,now from front look down inside dryer to the right and left sides you see to 2 screws remove ,,always unplug..remove the lid switch connection,,remove front panel get flash lite..and look in back rite corner..
Posted on Dec 26, 2008
KENMORE DRYER JUST STOPPED HEATING UP WHAT CAN I DO TO REPAIR IT?
Replace the Heating Element. The heating element is usually located behind a panel on the back. To replace you will need to remove the back cover of the dryer, then locate the heating element. The heating element is screwed into place and is easy to unscrew and replace. Be sure to have the dryer unplugged while doing this.
Here is the part for it:
http://www.repairclinic.com/Kenmore-Dryer-Model-11060602990-ID-501912-Heating-Element-Parts
Mar 13, 2013 | Dryers
Tip
Elite and Duet Dryer Heating Element Replacement
This advice explains how to replace the heating element on Whirlpool Duet, Kenmore Elite and Maytag Epic dryers.
1. UNPLUG the dryer before servicing. Dangerous voltage is still present inside the dryer even when it is turned off.
2. Open the door and remove the lint screen. IMPORTANT: You will not be able to remove the air blower cover with the lint screen in place.
3. Remove the lower toe panel directly below the door. The panel comes off by locating and removing the screws under the bottom front edge. With the screws removed, the panel will drop down, then come off. NOTE: Propping the front feet of the dryer up can provide you better access to the screws (a 2x4 works well for this).
4. Disconnect the auto dry sensor plug (usually yellow wires with a white plug to the right of the blower assembly) and any ground wires that may be connected to the front panel.
5. Remove the air blower cover by locating and removing the mounting screws. NOTE: This is a good time to clean the blower fan housing, squirrel cage motor and dryer interior cabinet.
6. Remove the top panel of the dryer by locating and removing the screws holding the panel in place in the rear of the dryer. With the screws removed, the panel will slide back, then come off.
7. Locate the two screws that hold the operator console in place. There should be one on each side under the top panel. Remove the screws and carefully lift the panel straight up. NOTE: You do not need to disconnect the ribbon cables. Carefully lay the console across the top of the dryer out of the way.
8. Disconnect the door switch connector plug and remove the dryer front panel by locating the four screws that hold it in place. Loosen the two screws along the bottom of the panel and leave in place. Remove the top two screws and lift up and turn the whole front panel slightly counter-clockwise to release the drum supports from the dryer drum. NOTE: Make sure the dryer door is closed when removing the front panel to avoid damaging the door hinges.
9. Remove the dryer drum. Reach in behind the air blower with both hands and pull the idler pulley to the right with your right hand to release the tension and remove the dryer belt from the drive motor. With the belt still looped around the drum, you can use it like a handle to lift the entire drum up and out of the dryer.
10. With the drum removed, the heating components can easily be accessed. The TCO and Hi-Limit Thermostat is located on the outside of the heater box on the left hand side. The TCO is located at the back of the dryer, while the Hi-Limit Thermostat is located adjacent to the heating element terminals.
11. The entire heating assembly is removed by disconnecting all the components leads, followed by loosening the heater box mounting screw. With everything disconnected, the entire box and components will come free and lift out of the dryer. NOTE: Make sure you properly label all wiring to ensure they are reinstalled correctly.
12. There are a couple of mounting screws on the side of the heater box that holds the heating element in place. With the screws removed, the heating element will slide out of the box. NOTE: Make sure you take any resistance readings with the component disconnected from the circuit to ensure accuracy. The TCO and Hi-Limit Thermostat will read something close to 0 ohms if GOOD. The Heating Element should read 9 to 13 ohms.
13. Insert new heating element into the heater box and align the screw holes. Replace any other defective components and reinstall heater box.
14. Reinstall dryer drum ensuring the back rim of the drum rests on the rear dryer drum supports. Make sure the belt is looped on to the drum with the ribbed side towards the drum.
15. Reinstall the dryer belt by releasing the belt tension pulley as listed above, then, with your left hand loop the belt over the drive motor pulley. Release the idler pulley making sure the belt rests on the drive motor pulley. You should feel the belt tighten with tension. If you need further clarification on how to properly route the dryer belt you can go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, locate the "Dryer Belt Diagrams" link under the Special Features section. Refer to diagram K.
16. Reinstall the front panel by turning it slightly counter-clockwise and aligning the front drum supports under the front of the drum. Once the supports are under the drum, turn the front panel clockwise and lift up, placing it on the bottom two screws. Reinstall and tighten the top two screws.
17. Reinstall the door switch connector plug and reinstall the operator console. Use caution not to put too much stress on the ribbon cables.
18. Reinstall dryer top panel.
19. Reinstall air blower cover and reconnect the auto dry sensor and ground wire.
20. Reinstall toe panel by inserting the top portion first and pushing up. Push lower portion of the panel in place and reinstall screws.
I know this may seem like a lot, but its actually fairly simple if you follow the steps provided. Read through everything before attempting any repairs. If you have any questions, please let me know. I hope this helps you.
on Dec 20, 2009 | Dryers
The dryer operates but does not produce heat. i think it is the heating element but i can not get in to the back of the dryer to check. i would like to get a service manual so i can check the element
1 Unplug the power cord from the electrical socket.
2 Remove the screws located around the edges of the back panel of the DVLR223 dryer. Move the back panel away from the cabinet.
3 Push the idler pulley away from the belt to loosen the belt tension. Remove the screws on the panel behind the dryer drum. Remove the panel.
4 Remove the four screws located on the underside of the top panel. Lift the top panel off of the cabinet.
5 Lift the drum up through the top of the cabinet and set it aside.
6 Unplug the electrical wires connected to the heating element assembly. Remove the old heating element from the DVLR223.
7 Insert the new heating element where the old one was previously located. Plug the electrical wires into the heating element assembly.
8 Replace the drum inside the dryer cabinet. Replace the top panel and the four screws that go on the underside of it.
9 Replace the panel behind the drum. Replace the screws that hold it in position.
10 Reposition the back panel onto the DVLR223. Replace the sheet metal screws around the perimeter of the back panel.
Jun 19, 2011 | GE DVLR223 Dryers
IM REPLACING HEATING ELEMENT FOR MY CROSLEY DRYER....I DIDNT PAY MUCH ATTENTION TO THE EXACT WIRING....4 RED CONNECTORS...2 HOOK UP TO THEROSTAT..AND 2 TO HEATING ELEMENT....I CONNECTED THEM AND CLOSED...
unplug dryer....if you take the top back panel off, there should be six screws and look in the top left hand corner there should be a schematic for the dryer. All appliances have then located in this area, unless someone has took them out. Hope this helped Tim
Feb 22, 2011 | Crosley CDE6000 Electric Dryer
Changing heat element on a ge 223 dryer
open the door there are twp screws there remove them take top off then the front remove belt and drum the element is in the back
Apr 21, 2010 | GE DVLR223 Dryers
LER4634EQ2 whirlpool electric dryer. heating element,thermal cut-off, and high limit are all getting continuity, but heating element still will not heat up.
I know this might sound stupid but try this. Find your fuse box, locate the breaker that runs your dryer. Flip it off and then back on. If i'm correct, it will work. Everything on your dryer works off of one leg of the 220v. The other leg goes to the other side of the element. If you have a meter. check for 220v at the plug. Everything you listed is what makes the dryer heat other than the thermostats. Check the cycling thermostats like you did the other pieces. They look like the thermal cut off. They have two wires and they are round.
Oct 09, 2009 | Whirlpool LER4634J Electric Dryer
I have model red4440sq0 and it it not heating..
It's the Thermal Cutoff device. Mine stopped working after exactly 1 year. (http://www.appliancepartspros.com/part_details.aspx?part_id=3094244).
Jul 10, 2009 | Roper Dryers
Changing heating element on a frigidaire dyer
If you dryer lint screen is located at the top of your dryer your heating element is going to located at the rear of your dryer. You will need to remove the back of the dryer to get to it. You will see a housing and the element is located in there. If you lint screen is located in the door when you open the door then your heating element is located in the front. This one is easier to get to. Simply remove the bottom panel under the door and you will see the heating element right at the front on the right hand side. Make sure you unplug the dryer before working on it. If you have any other questions feel free to ask and also please let me know if this was helpful for you. Good luck and glad to help.
Jan 22, 2009 | Kenmore 63942 Dryer
Whirpool twin thin no heat
Make sure you have 220 volts first at dryer. Heating element is on back of dryer. You'll need a test meter to see what's wrong unless you can see broken wire in element itself. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | Whirlpool LTE6234D Top Load Stacked...
Dryer doesn't dry
TAKE THE BACK OFF OF THE DRYER AND CHECK AND MAKE SURE THAT YOU HAVE POWER COMING TO THE ELEMENT WITH DRYER RUNNING IF SO THEN CHECK THE ELEMENT WITH A OHM METER AND SEE IF IT IS BROKEN, IF NOT MAKE SURE THAT THE THERMO DISK IS CLOSED WITH THE OHM METER, IF IT IS THERE IS PROBABLY A THERMO FUSE UP ON THE ELEMENT CAN THAT IS BLOWED.
Feb 14, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LER5636P Electric Dryer Logo
44 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
