Question about Alpine CDA-9847 CD Player
No Amp Power
I have an Alpine CDA-9847 and when I change the source on the deck off of the tunner it turns off my amp. I have checked the wires and all the fuses but I cant seem to find a problem. Can someone help please asap.
    Problem Solver:
  • 14 Answers
You are taked the wrong cable to turn on your amp......alpines have a two blue cables one of theme start the power amplifier and the other one start the electric antenna when you turn the radio,if youre earing the cd or tape and change to the radio this cable have 12 volts to startup the antenna.....solution .....just try change the other blue cable. see you.
Posted on Feb 17, 2007
I hooked up the stereo and when i play cds the sound does not come out of door speakers
Are you using an amplifier? If so, it sounds like you are using the blue wire, which is a power antenna remote turn on, in stead of the blue/white wire to turn the amp on. The blue wire turns off when leaving tuner mode, turning the amplifier off also.
Nov 11, 2011 | Alpine CDA-9847 CD Player
CD WON'T PLAY THE NUMBERS MOVE BUT NO SOUND AND THE TUNER HAS SOUND?
it sounds like you are using an amplifier. if so, make sure you are using the blue/white wire to turn the amp on instead of the blue wire. the blue wire is antenna remote and turns off when leaving tuner mode. the blue/white wire is amp remote.
Nov 01, 2010 | Alpine CDA-9847 CD Player
Radio memory/presets
you need to have the yellow wire going to a constant power source for the radio to retain memory when the key is off.
Mar 12, 2010 | Alpine CDA-9847 CD Player
Model CDA9847, how to set the clock?
Link to a PDF Owners Manual for the Alpine CDA-9847...
http://vault.alpine-usa.com/products/documents/OM_CDA-9847.PDF
"Setting Time" is found on Page 7.
Jan 27, 2010 | Alpine CDA-9847 CD Player
My CDA-9847 will no reconize the SIR-ALP1 tunner.
I am in the same situation.  I have had my sir-alp1 for 4 years and it simply stopped being recognized.  I called Alpine and they said they have no connection to this piece, it is made by "directed electronics" and I need to contact them.  A new one is around $120 whereas this one was 79 on sale in 2004.  I still have he installation guide/owner's manual for it and nowhere inside is there a number to call them.
Mar 08, 2009 | Sirius Satellite Radio Sirius SIR-ALP1...
Screen says searching when iPod connected to Alpine CDA-9847
Check your ipod to see if it is shuffle mode. Alpine doesn't document this but they have a bug that causes the problem that you describe. If the ipod is in shuffle mode the Alpine gets confused.
Aug 15, 2008 | Alpine CDA-9847 CD Player
Alpine amp
You could have damaged the speaker, try another speaker or buy a volt meter and check the speaker ohms. You could also set the meter to read A/C voltage and put each lead to the positive and negative speaker output on the amp and see if the amp is outputing any voltage. Hopefully it is just the speaker and not the amp.
Jan 05, 2008 | Alpine CDA-9847 CD Player
No sound to the in car speakers from my alpine cda-9827 cd player
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go.
Sep 02, 2007 | Alpine CDA-9827 CD Player
Odd Problem
Your amp's remote turn-on wire is connected to the wrong wire at your head unit. Look for a blue/white wire and connect it there.
Feb 13, 2007 | Alpine MRP-M450 Car Audio Amplifier
Alpine CDA-9847 CD Player Logo
110 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
