Question about Acer TravelMate 3012WTMi Notebook
Have a laptop and when i turn it on it turns off imidiately
  • 51 Answers
When you turn the laptop on do you hear the heatsink fan spinning. if not the heatsink fan must have gone. can pick up cheap on ebay
Posted on Dec 06, 2008
My 1998 c200 Mercedes car imported from japan engine fans automatically starts running as soon as I turn ignition key
you should concern with some motor machanic imidiately to avoid having problems to other parts of it.
Sep 22, 2013 | 1998 Mercedes-Benz C-Class
Hi, I am seaman and shortly today I am in New Orleans.Need help for my new Toshiba NB 505,when I try to switch him on got on screen,after minute, "Media test failure,check cable" and on the end...
Sounds like the computer can't detect the hard drive, which means it is most likely bad. If it's a new computer I'd swap it out or return it.
Sep 11, 2011 | Computers & Internet
I was riding my bike running great went to store turned off the key when i turned the key back on no power to the lights or instrument panel. i checked all fuses. it has good battery. i arced the starter...
Locate wire block at ignition switch, using a test light or multimeter check red wire for 12 volts dc, if you have no voltage here, you will have to trace the wire back to the battery and fusebox some models have a circuit breaker on the underside of the battery box, or in the imidiate area, its a 2 wire breaker with a transparrent cover and a red dot in the centre, push at this point to reset, have you checked the fuse at the solenoide 30 amp, if you do have power at the red, turn the ignition switch to the park position as the bike has a seperate live to the rear light, it should light(this will also proove you have power at the ignition)
Sep 05, 2011 | 1999 Suzuki GSX-R 600
In my laptop no audio and video drivers. i want that immidiatly
you should imidiately go directly to your manufacturers web site and download the drivers. :)
Aug 11, 2010 | Computers & Internet
My toshiba satellite a205-s5804 is turning it self off
Check if its overheating underneith, also restart then go to F2 while the laptop is starting to go to BIOS settings and check the settings to the temperature if its set to turn of at a certain temperature then it is probably why it shuts down. If it doesnt turn off all most imidiately after it stated, then it very likely it overheating, this could be caused from number of reasons. Also take the battery out and plug it in the mains see if it is gonna turn of while runing on mains only, another thing you could try is download and flash the bios if theres an update available but only from the manufacturers site ( when flushing the bios you must make sure the lapotp is powered by lid and this coudl go wrong if the laptop is shut unexpectedly, so you might want to let someone with the knoladge to do that for you ) Try using the laptop on a hard surface it might help.
Apr 29, 2010 | Toshiba Satellite 1805-S274 Notebook
My HP LaserJet 1022 is not responding even after I click print. It happens just now. Yesterday morning was fine. Keeps the document in pending and when I try to cancel or click print it says the print...
This seems to be a problem on these printers. I have five of them on my network and I had to use a generic driver to make them stop shutting off the print spooler on my print server. I use the LaserJet III driver which is a good HP generic driver. I found it to be best to uninstall all of the 1022 software and install the printer using the above driver that is part of the windows operation system therefore there is no need to download one.
Apr 10, 2010 | HP LaserJet 1022 Printer
Turn on, make noise and imidiately turnes off.
lens unit is bad,not able to open for normal funtioning is due todamage of gears , guide pins,guides of the barrels of the lens,due to the accumalation of the dust /unwanted pressure on the lens
Mar 06, 2010 | Pentax Optio V10 Digital Camera
I have a poloroid i835 digital camera which tunrs on and imidiately turns off. The zoom lens comes out and then ater few seconds it goes back and turn off the camera.
The batteries are defective please recharge the battery fully then check the issue if the problem persist then replace the batteries.
Feb 19, 2010 | Polaroid Cameras
I don't know my sound card driver.how to fine sound card driver without mother board cd.i install sond max high defination but not work.please slove my problem imidiately
Go here to HP support, choose your operating system, download and install your audio driver >>>>>>
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=uk&prodNameId=3442833&taskId=135&prodTypeId=321957&prodSeriesId=3442832&submit.y=0&submit.x=0&lang=en&cc=uk
Good luck
Jun 28, 2009 | HP Compaq 6720s PC Notebook
I turned my sony ericsson off imidiately turned it back on again, however my mobile would not turn back on. i havent dropped it or got it wet so i do not understand why this happened.
Take the battery and sim out, leave for a couple of minutes then put them back in. Leave the phone switched off and attatch the charger. Leave it charging until the battery shows 'full' then try turning it on again
Nov 24, 2008 | Sony Ericsson Cell Phones
Acer TravelMate 3012WTMi Notebook Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
