Question about HP Computers & Internet
I have an HP Media Center Computer and an HP w2007 monitor. The PC works fine. All I need to know is how to clean the LCD screen. What should I use to clean spots & dust without scratching the surface. I've looked in all the booklets that came with the PC and monitor. No info is provided for this cleaning-maintenance I had read somewhere about using 'rubbing' alcohol and a soft cotton cloth. I'd appreciate an answer.
  • spearl12706 Dec 06, 2008
    Thank you. I got scared away from your website when I saw the sign up page for $19.95. Instead, I called the HP tech support line and was told to use a soft cotton cloth and a small amount of alcohol to remove spots, dirt, & dust.
    Thank you for providing your answer w/o a charge. I suspect that the LCD spray in the wipes you suggested is probably alcohol as well.
    Have a good weekend. Stan Pearlstein
  • 51 Answers
Go to your local computer store whivh you can get some special lcd spray or wipes for around $10.00
Posted on Dec 06, 2008
My hp w2007 turned blue after I moved it how do I access screen display from the monitor menu
Some monitors change colour if there is damage, internally, within the signal cable. Try another cable if you have one.
Alternatively, it might be that the monitor is near an extremely strong magnetic source, such as big loudspeakers?
Mar 11, 2015 | HP W2007 LCD Monitor
White screen on hp w2007 LCD monitor.
Troubleshoot an HP LCD Monitor
HP makes a number of liquid crystal display, or LCD, monitors.
LCD monitors create an image by passing light through a liquid crystal solution that either blocks the light or allows it to pass through to a color filter.
LCD monitors are ideal for use with a computer as they present an excellent still image and cannot suffer pixel burn-in like other flat-screen display technologies.
Even quality monitors run into the occasional problem and need some basic troubleshooting before sending them in for service.
Check the power cord to make sure that it is plugged in securely to both the monitor and the outlet. If you are using a surge protector, remove it and plug the power cord directly into an outlet that you know is working.
Detach and reattach both ends of the cable running from your computer to your monitor.
If your HP LCD monitor has more than one connector, use the other one to make sure that the connector isn't the issue.
Remove any switch or extension cable that may be present between the computer and the monitor.
Restart your computer. A fresh start will correct many software issues.
Check the documentation of your video card to make sure that it supports HDCP, or High Bandwidth Digital Content Protection, since the screen may be blank when you are trying to watch high-definition content through a video card that doesn't support it.
Some older HP LCD monitors also do not support HDCP, so check your monitor documentation as well.
Go to your video card manufacturer's website and install the latest drivers for your video card. Instructions for installing the drivers will vary by manufacturer, but they should be listed with the driver software.
Change your resolution to a preset video mode to make sure that you aren't trying to operate the monitor in an unsupported resolution.
Different models of HP LCD monitors support different preset video modes.
All of the preset video modes for your monitor are listed in your monitor's manual.
Resolutions of 1024 x 768 and lower are supported by almost all HP LCD monitors.
Press the "Auto/Select" button on the front of the HP LCD monitor to correct any images that are dark or blurry.
If this does not correct the image, press the "Menu" button on the front of the monitor to bring up the on-screen display menu, where you can use the "+" and "-" buttons to scroll through the options and "Enter" to select the option that you want to change.
Adjust the brightness and contrast as needed by selecting them and using the "+" and "-" keys. Press the "Menu" button to exit the menu.
Press the "Menu" button to enter the menu, scroll to "Image Control" and press "Enter."
From here you can choose the "Auto-Adjustment" option and the HP LCD monitor will automatically adjust the horizontal and vertical positioning to center the screen.
The ability to adjust these settings is available only if you are using VGA inputs.
Contact your retailer or manufacturer for any additional troubleshooting steps for your particular model of HP LCD monitor.
If your monitor still has issues, you may need to send it in to be serviced.
HP Support
http://welcome.hp.com/country/us/en/support.html
Fix a White Screen on an LCD Monitor
When an LCD screen has turned completely white, there are three normal causes: the screen is defective, the video cable is not connected correctly, or the graphics card on the motherboard of the computer is faulty.
You will need to troubleshoot these possibilities to determine which problem you have.
If you are not experienced in working on computer equipment, you should not attempt to disassemble your LCD screen because you could easily damage it.
Seek professional assistance unless you have experience working on computer hardware.
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot.
If your computer display does not show on the functioning LCD screen, try rebooting your computer.
If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance.
If your computer display shows normally on the working LCD screen, proceed to Step 2.
Unplug the LCD monitor with the white screen.
Disassemble the rear panel of the monitor with the small screwdriver.
Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor.
Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen.
See the References section for photos of the video cable for assistance.
http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/
Unplug the cable, checking for any debris or blockage.
Reconnect the cable firmly.
Reassemble the LCD screen. Plug it in and connect it to your computer.
If the screen is still white, you have a defective LCD screen.
You will need to replace it or take it to a professional repair service for assistance.
Without this test you'll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You'll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1).
After that you connect another working screen and test video.
For this purpose I'm using one of my test LCD screens.
My test screen is cracked and because of that you see a wide white band in the center but it still works fine for this test.
The original screen is white but my test screen works normal (except the crack of course) and I can see the image.
After this test I can tell that the problem must be related to the screen.
After I assembled everything back together and connected the original LCD, it's still white.
CONCLUSION. In my case this problem is related to the LCD screen and it has to be replaced.
Aug 04, 2013 | HP W2007 20.1 Widescreen Monitor
Hp w2007 moniter is on but no light
try connect it to other pc or laptop, sometimes your pc video card won't work replace it
Joel
Apr 20, 2013 | HP W2007 LCD Monitor
My monitor, hp w2007, shows for about 20 seconds when turned on then goes blurry then black how do i fix???
The most common problem that causes the screen to go to a black screen is due to bad capacitors in the screen's power supply board. The bad caps are the cylindrical and will appear to have bulging tops. 66c561df-0d01-416a-ae23-71f3b3965c88.jpg
Oct 24, 2010 | HP W2007 LCD Monitor
Does my HP w2007 have a mircophone
i am pretty sure it doesnt, sorry, most lcd mointers that arnt t.v.s usally dont have built in speakers or a mic, if it does it would have a 3.5 mm port or plug somewhere
Dec 30, 2009 | HP W2007 LCD Monitor
My monitor will not wake up
I wm having this same issue. Dis you ever get this resolved? princess242@comcast.net
Oct 17, 2009 | HP W2007 LCD Monitor
Hp w2007 monitor: Powers on but screen is white - no display at all (no error msg..., just a bright white screen). Blue 'power led' is on. No difference when connected to pc or no connection. Flickers at...
This is an internal problem with the LCD monitor. It is defective and should be returned to the store your purchased it from for a new one. That is the only thing I can really think of if it is not reading properly with a seperate graphics card. It is an internal issue and needs to be repaired.
Oct 03, 2009 | HP W2007 LCD Monitor
HP w2007 LCD monitor goes off Monitor going to
Make sure that everything is connected to the monitor properly. Go to the back of it and make sure the VGA or DVI cables are secured and then check the back of the computer to do the same.
Sep 16, 2009 | HP W2007 Desktop Monitor
My hp w2007 monitor has no sound.
my hp w2007 monitor has no sound
Dec 04, 2008 | HP W2007 LCD Monitor
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
