Question about EliteGroup P4VMM2 Motherboard
Nothing appears in the monitor
Even before i install my HDD, the BIOS of my motherboard appears even without the HDD. Just after i've installed it on my system, the monitor doesn't show any details from my motherboard - i mean nothing really appears. My monitor only blinks its light in red and the lights on my CPU appears in red as it is reading something
Try to check your hardware in your computer maybe it loose.try to insert properly the processor or other parts of your computer
Posted on Feb 15, 2007
We have a VS197 monitor, it we get a VGA message saying no signal, we just bought a new VGA cable and when the screen goes black after it is sitting for a bit, it comes back to that message
Hi Penny. Sorry for the delay but I just saw this question now.
In your question you posted that you bought a brand new VGA cable, so I guess this will be use with a PC Desktop.
A lot of time there could be something corrupted in the motherboard. The only way to troubleshoot this is to take the whole computer apart, and install just one piece of hardware at a time. Here is an example:
Take PC apart, memory stick, HDD, Optical drive, etc... Unplug the AC Power, press the power button for 10 seconds.
Take the memory stick and clean the golden edges with a pencil eraser. Once that is done, and if you have 2 memory stick, install just one memory stick, install the HDD. Do not install anything else and turn it on to see if there is any display. If not, swaps the memory stick and try again. If not, turn it on without the HDD. If nothing works, there could be a problem with the BIOS.
To clean or reset the BIOS, you have to look for a jumper in the motherboard. The bridge where the jumper is hook, have 3 pins, but it's connected to only 2 pins, just move the jumper to the other 2 pins and turn on the PC, this will reset the BIOS to factory default.
Also make sure the battery that is in the motherboard is charge, this will also give a headache if it have no charge.
Sep 25, 2015 | Computers & Internet
When i switch on my computer nothing appears on the screen
1.check with a other monitor.
2.check the videocard.
3.if two HDD and set optimal deafaults in BIOS.
bios can change drive to boot from.
Jan 16, 2014 | ASUS P4S800-MX Motherboard
Display Problem with Intel 845GVSR MB : My computer running on Intel 845GVSR MB with 2.4 GHz Intel Pentium 4 Processor and 768 MB RAM and 80 GB HDD . When I start the computer nothing appears on...
Reset the CMOS setup after putting the battery. You have 768MB RAM. So check with the alternate memory module with different slots. If not helpful, check the RAM with another PC. Lastly get the BIOS updated or motherboard repaired from component level motherboard repairer. You may have damaged the motherboard by putting undue pressure while plugging the connectors.
sonsunny
Jul 08, 2011 | Intel D845GVSR Motherboard
Dell inspiron laptop screen colours inverted (negative)
if the same issue occurs in the BIOS your soluton is to have your LCD screnn replace or have your LCD inverte cable checked/replaced ^_^ this has nothing to do with the BIOS vodeo card drivers do not function in the BIOS to be able to do such in the BIOS screen
Jun 04, 2010 | Dell Inspiron E1705 (DNDWGA3) PC Notebook
Doesn't recognize SATA hard drives. BIOS option
Need to install latest bios update go to there website also if you are trying to boot up with usb installed take it out. BIOS ID:15
  1. Fixed the issue where SATA HDD boot up will fail if USB storage device is installed.
  2. Fixed the issue where SATA HDD boot up will fail if "USB keyboard/mouse" setting as "BIOS" section.
  3. Enhance the compatibility of SATA device on WIN98SE/ME.
  4. BIOS compile date: 06/07/2004
Nov 28, 2009 | Abit KV7-V Motherboard
Soyo SY-P4VGA bios. how do i get it and how do i install it without video.
To get the bios you'll need to buy a bios chip from the net, im sure their are site flooding around if you google them. For installing a bios without a video card or a monitor connected. Im not sure if that would be easy. Or even possible if you dont have any certification as a professtional PC tech.
Sep 30, 2009 | Soyo SY-P4VGA Motherboard
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
Intel Desktop D845PEBT2 could not boot up
i,d suggest that the power cut may have been a surge or spike.
This May have blown your power pack, and caused possible motherboard Damage.
** Did you use the same lead for the PSU** and have you checked the (main fuse in the Plug ? )
If the monitor light remains orange, this is a possible graphics card fault, or driver that is not allowing the monitor to come out of standby mode. You could try installing a different graphics card, or swapping the monitor cable to the on-board graphics card if it has 1.
If none of the above works, assume the motherboard has suffered damage.
Mike @ Compurepair.
Jun 12, 2009 | Intel Desktop Board D845PEBT2 Motherboard
Problem with sata HDD probably?
check the bios settings first. if you can see your sata hdd and dvd rom drive then you can install it with no problem. or else try to replace the cables of the hdd if the hdd is not showing up in the bios.
also check that the hdd is set to master drive and dvd also set to master as they are on different connections.
Apr 21, 2009 | EliteGroup ECS 915-A Intel 915GV Chipset...
EliteGroup P4VMM2 Motherboard Logo
70 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
