Question about Kenmore 80809 Microwave Oven
I have a Kenmore Microwave model# 721.80833500. I have a had a continuing problem with the rotating plate, where it seems to jump out of the rototating arms's wheels and then stops moving. It seems that the plate assembly doesnt' match the microwave its in, but I had this installed brand new about 1 1/2 years ago.
  • 1 more comment
  • mjt224 Dec 15, 2008
    Same problem. Is there a replacement part that can fix this?
  • swansonkak Jan 19, 2009
    the power does not come on.
  • thejordans Feb 17, 2009
    i also have a kenmore microwave #721-80833500 and have problems with the rotating plate. it makes cooking very difficult. it starts out ok for a few seconds then stops. i have to be watching it closely if not the food on the outside burns and the inside is cold. i hate this microwave and am so sorry i bought it. if anyone has had this problem and figured out a way to fix it please let me know.
    thanks!!!!!!!!!!
    Novelist:
  • 157 Answers
Chat crashed. Go ahead and give me the serial number and we can get those parts via this message board. Is that okay with you?
Posted on Dec 06, 2008
Microwave makes grinding noise when microwave plate on turntable
check for the roller spider under the plate
small plastic item that has 3 (4) rollers that allows the plate to turn freely
May 25, 2015 | Microwave Ovens
The turntable on my kenmore microwave model number 790.4784 has stopped turning. It is a combined unit with the oven so to replace it means replacing both the microwave and the oven. Is there an eas
Cynthia. Look at this diagram http://www.searspartsdirect.com/Kenmore-Wall-oven-Parts/Model-79047842400/0582/0125400/P0508004/00002.html
The odds are that microwave is going to be a little complicated to fix that problem. You have to pull the microwave out and take it completely apart if you want to change anything. This is a high level job that requires security torx bits. I wouldn't really recommend trying to fix this one yourself because it's a really hard job. If you're gonna take the time out to do this job you're gonna have to uninstall it out of the cabinet and disassemble the entire cabinet off the microwave. I would recommend ordering the door switches, main board and turntable motor and replace them all if you're going through that effort.
Jan 14, 2015 | Kenmore Microwave Ovens
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
Our Kenmore model 721.80833500 tray jumps off its track. This has progressively gotten worse over time and now the little end wheel on the rotating arm has broken off. The microwave still works and still...
Found 2 possible solutions on the net. (1) Check the engineering change at a Sears store. They reengineered the glass tray and the narrow plastic band the tray glides on. Get the new items from Sears. (2) Cut 1/4" out of the narrow plastic band the glass tray glides on. Possible solutions that look promising.
Dec 03, 2009 | Kenmore 80809 Microwave Oven
How do you turn the carousel on/off on a Kenmore Microwave Oven model: 5658932580
Look at the owner's manual of similar Kenmore models there does not seem to be a setting that allows you to turn off the turntable. However if your microwave (sorry but I couldn't find your exact model number online) has the time of carousel that has a lift out glass plate with a notch (hub) in the center of the bottom side then you effectively turn of the carousel my removing this glass plate. (see pg 4 of the manual - above link) You can place a normal microwave safe plate in the microwave in it's place. Make sure to leave the rollers in place...just remove the turntable.
Nov 08, 2009 | Microwave Ovens
Revolving plate no longer rotates . All else works, it continu;es to cook, but we need to move the items of food from time to time
Remove the plate, and check if the square shaped gear that normally spins the turntable is rotating.
If it is rotating, then replace the turntable gear.
If it is not rotating that means that the motor that spins the microwave turntable does not rotate, and must be replaced.
Mar 01, 2009 | Amana Radarange Microwave Oven
Rotating ring/ Glide tray comes off the track -Elite Model 80803
Take your round glass tray and plastic three wheeled hoop to a local Sears store, open up the microwaves on display, find the one that is still using something similar, deftly trade out yours for theirs. The new wheeled plastic hoop wheels are slightly bigger and the glass tray raised guides are a bit longer, since the switch no problems like I had. Don't get caught. They do not have those parts for sale at the local Sears store.
Feb 20, 2008 | Kenmore 80809 Microwave Oven
Kenmore Elite 66469 Turntable "Clunking" Sound
Either the coupler or the turntable support is bad.
You can find an exploded view by entering your FULL model number (3 digits, a dot, then 8 digits) here: http://www3.sears.com (the 3 is correct)
Dec 08, 2007 | Kenmore 66469 / 66462 / 66464 Microwave...
Kenmore 80809 Microwave Oven Logo
147 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
