Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
I have a Plain Hotpoint washer,and it keeps filing with water on large load,but will stop on small load.Will continue to fill even with it unplugged, what could it be?
  • Anonymous Dec 07, 2008
    Yes it does keep filing when it is unplugged,the only way to stop it is turn the water supply faucet off.
  • Frigidaire Master
  • 3,463 Answers
No it will not keep filling when it is unplugged.
The problem is probably due to a sticking water level switch, or a partial blockage in the water level sensing system. \you will probably need to call an engineer.
Posted on Dec 06, 2008
Machine does not seem to be filling properly, then does nothing else.
Sounds like you're fill valves are junk which sadly happens allot. This video is very generic but should give you an idea
Jul 06, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
My washer keeps filling with water. It wont stop filling on small med. Or larg. It just keeps filling.
If the machine keeps filling even when it is off the water valve is defective. If it stops when you shut it off then, You may have a damaged or disconnected pressure hose. This is a clear rubber hose that runs from the side of the wash tub up to the load size switch. Inspect the hose as best you can.
If the hose is in good condition and is connected at both ends then you have a defective pressure switch.
Jun 11, 2010 | Washing Machines
Washing Machine wont recoginze the load amount to fill with water, ex..small, med, it justs keep filling up to the brim??
Sounds like your problem is one of three things. Most common is that you have to "reset" the water level. This is done by turning the water level knob passed the large load size, and then down to small. Any time you want to go to a smaller sized load, you have to do this. Another possibility is that the pressure switch is bad, this is an easy fix (although not as easy as the reset) The switch can be purchased thru a local parts supply house. And the last thing could be a bad water valve. This will leak and continue to fill the washer after it is already full, this however is usually followed with water all over the floor. If it is not the reset, write me back and I'll walk you thru the other repairs. Hope this helps!
Dec 08, 2009 | Maytag Performa PAV2200
Won't stop filling, water just keeps running into washer even after agitation starts have to turn water connection off to stop filling
check to make sure the control knobs are turned to exactly small -med -or large - if it's in the middle of say med and large loads the water will over flow - this happened to us three times (cause of daughter!)
Aug 26, 2009 | Washing Machines
Load size, spin cycle, and other cycles do not work properly
error code f 06 keeps coming up and we cannnot afford to have it serviced at this time we were told it had something to do with the control panel
Mar 22, 2009 | GE Profile WPSR3100W
Hotpoint washer will not stop filing with water
It would appear you have a faulty water inlet valve.
Try turning the water off to the washer. if it stops filling, then that is your problem
Replace valve or valves as required.
Please leave feedback
Dec 06, 2008 | Frigidaire FEX831CS Top Load Stacked...
Water keeps running.......
i assume washer never starts running if not suspect water level switch or connection hose also be sure small hose to switch is not plugged or mashed flat even a small hole in hose may cause it not to get pressure to tell switch drum is full ..if washer does start running suspect bad water valve may not be shutting off
May 19, 2008 | Frigidaire FEX831CS Top Load Stacked...
Overflowing water
If the water comes out when filling, check your water valve by unplugging the washer when it is filling. If the water still runs, replace the valve. If the water stops, check the small tube that goes from the water pressure switch (in the consul) to the bottom of the tub. This must be connected without any holes or obstructions. If this is ok, replace the water pressure switch.
Jan 03, 2008 | GE WBSE3120B Top Load Washer
Hotpoint washer dryer
daidan, If you unplug the washer and it still fills you have a bad inlet water valve. If you post the complete model number we would be able to help you better...Catriver...post back
Aug 21, 2006 | Hotpoint Aquarius WD63 Front Load...
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
55 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
