Question about Logitech S-100 Computer Speakers
Speakers not registerying as a hard ware and is not working
I have a logitech S-100 speaker system which has a 3 year warrenty.after a year my speakers are not working it is not registered in hardware list even though i have tried everything according to the manual given not even microsoft automatic harware reconition dosent reconize it
  • 944 Answers
Try going through this troubleshooting procedure site first: http://logitech-en-amr.custhelp.com/cgi-...*uWZ8vi&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NzgmcF9wcm9kcz04NDQsMTcmcF9jYXRzPSZwX3B2PTIuMTcmcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9Mg**&p_li=&p_topview=1 If you get no solution from this, there are other similar logitech speaker systems that have had similar problems on initial models. it appears that logitech have been very helpful with replacing speakers in the past if design is faulty. Give them a try.
Posted on Feb 28, 2007
How to open/repair Logitech S100 speakers for the power cord replacement?
first open the net over the speaker...top bottom corner there is a hole then in this hole put a strength stick pressure heavy by side..then it will show u crack by this crack u have to open it!!remind there is no screw in s-100 logitech speaker!!Thanx!
Feb 07, 2013 | Logitech S100 Computer Speakers
Altec lansing acs45.1 cannot increase volume level by using arrow buttoms on top of cube speaker...sound does come out but a very low levels......have pret
This is a loose connection between PC and the Sub-woofer. The cables may damaged or it may be a hard ware problem.
Think this is helpful !
Aug 11, 2010 | Altec Lansing ACS 45.1 Computer Speakers
I have the logitech z-2300 just the other day the
mine did the same thing today , i just bought these new 2 weeks ago . the black prong speaker works in both ports ..
the yellow prong speaker is the one with the malfunction .
it works sometimes but when i turn up the volume louder it dies out .
Feb 23, 2010 | Logitech Z-2300 2.1 Computer Speaker...
AFTER 3 MONTHS SPEAKERS COSTING OVER $200 ONE SPEAKER DOES NOT WORK ANYMORE
Logitech equipments are usually pretty good. It should be under warranty so I would not try to fix it yourself.
If you bought your product new from an authorised dealer, your expensive speakers would still be under the normal Logitech 2 yeas sound systems warranty: consult your warranty terms an contact both your dealer and Logitech support.
Hope it helps. let me know how you go.
Dec 31, 2009 | Logitech X-530 Computer Speakers
Logitech x230 speaker system right hand speaker stopped working
speakers do unfortutionly go bad better just to buy another speaker just watch the ohms should not be more than 8 ohm speaker. please make sure you can return if you buy incorrect.
Nov 18, 2008 | Logitech X-530 Computer Speakers
Repalcement Logitech Z5500 Control Center?
My Control center turns on but i can get any sound not even from the test system, Logitech cant help.
I went the a shop and check it on ther system still no sound :(
any ideas
Nov 17, 2008 | Logitech Z-5500 Computer Speakers
Operating with/without the control panel
You could try hooking them up to another speaker that has the input connections. I have done this before with several different speakers and daisy chained the connections with several speaker connections and they worked great. I had surround sound all over the room. You might run into a problem with the main speaker that you plug into not being able to push all of the speakers that you have but you might get lucky. Those speakers say that that carry 550 watts.
I recently bought a set of speakers that stated that they push 100 watts. The sub was putting out 50 watts and the others were only putting out 25 each. I hooked up a 100 watt speaker to it and it worked. You might be able to contact logitech to get the other speaker that you need. That set of speakers looks awesome on the site. This is the specs for the other speakers
I think that this is what you wanted to know. If it was not your solution, let me know. I will help you more. I might not be understanding your question correct. I have referred your question to someone on the site that works with logitech.
Jun 09, 2008 | Logitech Z-5500 5.1 Digital Speaker System...
Logitech Z-680
You need a 2 Amp Slow Blow fuse. 250V. Available from eBay
Aug 01, 2007 | Logitech Z-680 Speakers and DVD218 System
Logitech S-100 Computer Speakers Logo
170 people viewed this question
Top Logitech Audio Players & Recorders Experts
Paul
Marvin
Marvin
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
