Question about Samsung DVD/VHS/MP3/SVHS Playback
Recording tv from a vhs player
I first put it on channel 3 to record for tv and i select my channel to record from there i choose a channel that is perfectly clear and no fuzz but when i go to record it shows up blue or its all fuzzy is there something wrong with the dvd-vhs player or is it something else? Is there something i can buy to make the channel come clear while im taping? or is there anouther solution tofix this problem thank you noah
    Scholar:
  • 119 Answers
Sound like you have a dirty video head, try cleaning the head with some isopropyl alchol. if it does not fix your problem, then you will have a bad video head. good luck
Posted on Feb 15, 2007
I have a apex tv and a dvd/vhs recorder, with a cable from wall only, how do I install
If you wish to record (VHS) off cable :
First connect the co-ax cable from the wall to the input on the DVD/VHS , then connect a second from the output of the DVD/VHS to the input of the TV.
You will need to match the channel (3/4) output and input. There should be a switch on the back of the DVD/VHS.
Tune the TV to channel 3 or 4 to match, To watch DVD/VHS .
Channel selection will be with the DVD/VHS when it is powered on.
TV will tune to channel when the DVD/VHS is off.
Jul 06, 2012 | Televison & Video
How to record a vhs tape to dvd on a samsung 1080
Hello
1.The VHS/DVD player must have recording capabilities.
2 Connect both players to a television so that you can make sure you are recording the appropriate content. You can also monitor the speed at which the VHS is copying to DVD.
3. Place the VHS in the VHS player and the blank DVD in the DVD recorder. You will need to use your remote and go through the menu options to choose the correct format for recording. The formats should be clearly labeled and outlined in your instruction manual. Choose the option that will read something like "VHS to DVD." You may also have to choose recording speed, which varies per blank DVD that you purchase. Every player is different, and every menu will vary slightly. If you have questions, refer to you individual manual.
4. Select the option that works best for you and hit "Play" on the VHS player and "Record" on the DVD recorder. To play the finished DVD, you will select the playback option.
THANK YOU
Dec 14, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
How to record ditigally on old comb tv/vhs
If you have the box hooked up to your 1996 combo turn or tune on channel 3 if the converter box is selected to channel 3 you should get all your digital reception from the box to your tv/vcr. Select what you want to watch or tape on the box, what you see on your tv will record to your vcr when you select record.
Jan 14, 2009 | Televison & Video
Recording from tv to vhs
I would have the antenna hooked up to the VCR. Then you could select any channel that you wish to record on the vcr without the tv being involved.
Jan 07, 2009 | Zenith XBV243 DVD Player/VCR
I cannot record using a DVD/VHS player.
You can record. From antenna to converter box, from converter box to vcr. From vcr to TV.
TV on Channnel 3 VCR on channel 3, and set channel on converter box. Then Record.
Time recording works the same way, but you can set for only one channel at a time. Tht is the only restriction that I have not overcome. The converter box sets the channel. Gee Whizz
Dec 14, 2008 | Philips Magnavox DVD/VCR Dual Player
Ilo DVDR 05
http://www.retrevo.com/support/CyberHome-DVR-1600MU-DVD-Players-manual/id/534ci862/t/2/e Someone said these were similar. Try the red/yellow/white cables. select that SOURCE. first select your recording length. I usually put mine on 3-4 hours and try to keep it from running to the end or you have problems. I use Rewriteable dvds, if you use reg discs be sure to finalize the disc so it will work in other players. I read if you are copying macrovision vhs to use the antenna input and it will copy it with that input. Just tune it to channel 4 or whatever. Forget trying to set the timer to record from tv. I never have success with that.
Jun 19, 2008 | iLO DVDR05 DVD Recorder
Dvd recorder
Following the instructions on hooking up the cables gave me fits. I finally just put the instructions away and winged it. Got it that way. Bypass your Ilo tuner. Hook the Comcast Cable (outs) up to the A/V input 1 of your ILO. Hook your tv combo A/V outputs, to the ILO A/V inputs. Select the Source and choose the cable source for cable and the combo source to tape from your VHS/dvd combo. Its a pain but you have to select Source everytime you turn the Ilo back on. You could hook your Cable to the ILO but would have to turn on ILO everytime to watch tv. Two remotes is a chore but you have to use tv remote for the volume anyway so it doesn't matter. Hope this helps.
Mar 30, 2008 | iLO DVDR05 DVD Recorder
Owners manual
Turn on power to TV, and DVD/VCR, set TV to channel 3 or 4
Insert video cassette
Select desired channel by using CH/TRK
Set the desired recoring speed (SP or EP)
Press REC once
Press STOP to stop recording.
Timer Recording,
Press Menu and the Main menu will appear.
Use up and down arrows to choose the Timer record menu
Press Select/Enter to go to the Timer Record menu.
Use arrows to choose the program no. (1-8)
Use down arrow to choose Month option
Use arrows to choose the desired month
Use down arrow to choose the Day option
Use arrows to choose the desired day
Use down arrow to choose Start Option
Use arrows to choose the desired start time
Use down arrow to choose the Stop option
Use arrows to choose the desired stop time.
Use down arrow to choose the Channel option
Use arrows to choose the desired channel (Channel, Line1 or Line2)
Cable users: If you have Cable TV and used Cable Box in Connecting Antenna/Cable TV to DVD/VCR using a cable box converter, you must set the channel in this step to match the cable box output channel (usually 3 or 4). Change channels on the cable box instead of the DVD/VCR
Mar 15, 2008 | Sanyo DVW-5000 DVD Player/VCR
Recording from one vhs recorder to another.
If your plan is to copy a VHS movie to a blank VHS tape, the connections would require a 3 wire RCA connector/cable. The unit where the original movie will be played will be the player. Connect the yellow video RCA cable to the VIDEO OUT, the red & white to the AUDIO L/R OUT. On the 2nd unit designated as recorder, slip in the blank VHS tape. Connect the other end of the RCA 3 wire cable to yellow VIDEO IN, the red & white to the AUDIO L/R IN. Connect the RF OUT of the 2nd unit (recorder to the ANT IN of a TV set. Set the TV to either Channel 3 or 4 as the case may be.
If the recorder has a manual selector or via remote, pls verify that it is set to Video and not tuner (or channels) input.
Press Record on the recorder (2nd unit), press play on the 1st unit (player). The TV will serve as monitor to your copying progress.
Hope that this be of some help/idea. Pls post back how things turned out or shoould you need additional information.
Good luck and kind regards.
Nov 11, 2007 | Televison & Video
Samsung DVD/VHS/MP3/SVHS Playback Logo
87 people viewed this question
Jerry Greenberg
Jerry Greenberg
