Question about Hoover HCA390FFK Bottom Freezer Refrigerator
Fridge compartment is freezing in my Hoover upright fridge-freezer. Any advice greatfully recieved. Thanks, Owen
  • 1 more comment
  • oggy2 Dec 06, 2008
    I did turn setting down to 1 (normally set at ~2.5) for last couple of days, with no effect (Only one control with setting from 0 to 5 and at 5 "Super Frezze" is activated). I have turned setting to 0 about 5 hours ago but no differnce observed yet.
    Thanks in advance for youe help.
  • Anonymous Jan 14, 2009
    i have a large build up of ice on the inside of the fridge, and even when its set on 1 the ice doesnt seem to reduce,and the fridge is really cold and freezing drinks and food
  • suzi-red Feb 21, 2009
    my fridge keeps freezing food and drink and my freezer is not freezing as good as it should be example icecream is very soft.ive turned the nob down to 1 and ive switched it of for 24 hours and it still seems to be freezing at the back,my bulb has gone in the fridge and i cant see that being the problem plaese help me thanks
    Sergeant:
  • 302 Answers
Have you tried turning down the temperature for the freezer or fridge? The fridge gets its cold power from the freezer, it is siphoned into it. So turning down the freezer temp may help but a sensor may have gone bad in the motherboard of your freezer and not closing off the vent into your fridge
Posted on Dec 06, 2008
My fridge freeze is excessively freezing in the freezer compartment and not chilling in the fridge compartment Any help would be greatly apprieciated Brian
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | Microwave Ovens
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Fridge compartment is freezing food/milk etc
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 06, 2009 | Hoover HFA270K Bottom Freezer Refrigerator
Freezer not freezing!
I am sorry, your question is posted in the Vacuum Cleaner section.
Jul 05, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Frostfree hoover fridgefreezer
If its freezing at the back that indicates refrigeration is good. it sounds like you have a thermostat control problem. Replace the thermostat.
Jan 12, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
FRIDGE COMPARTMENT FREEZING
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
Dec 06, 2008 | Refrigerators
i had the same problem the sensor starts at the back of the pcb and snakes its way dow the back of the fridge into the freezer conpartment i ordered a new sensor thinking it was a temp sensor but turned out to be a defrost sensor compleat and utter hassel to fit due to the expanding foam i had to eventualy cut the block off that conects to the pcb and then reconecting it once i got the cable through the foam first 2 days seamed to work fine while there was nothing in it as soon as i put food in it again the fridge started to freeze everything again then about a week later it still ices up at the back the fridge but doesnt seam to freeze the food so much now so still unsure about it all
btw it was the exact same model and before i changed the sensor the light and the super light used to flash on and off
Dec 02, 2008 | Hoover HCA390FFK Bottom Freezer...
Hoover HCA390FFK Bottom Freezer Refrigerator Logo
857 people viewed this question
Top Hoover Refrigerators Experts
Charles T Nevin
Charles T Nevin
Jim Goldsmith
Jim Goldsmith
JONFRIDGEDOC
Level 1 Expert
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
