Question about ASUS P5P800-MX Motherboard
Usb 2.0 problem
Hello. nik here. there problem with my asus-p5p800mx motherboard.it is not supporting any of the usb devices.
    Sergeant:
  • 302 Answers
Download the drivers and update your bios for your motherboard
Posted on Dec 06, 2008
Asus x55u usb 3.0 driver problem
You can download the device drivers from ASUS WEB site. Select your model motherboard/computer/laptop, and make sure you select drivers that matches your Windows operating system. Please click on this link to their WEB support site : -
http://support.asus.com/download/download.aspx?SLanguage=en-us
May 20, 2013 | ASUS Computers & Internet
Good day i have mother board asus p5800-mx the usb port cannot work theirs no 5 volts in the port, pleas help me to resolve my problem thanks.
Ashley,
A) There are two USB headers on the motherboard.
They are rectangular in shape, and Blue in color.
One is to the immediate Right of the 3 white PCI slots.
Has 4 pins across the Top row, and 5 pins across the Bottom row.
May have USB56 printed on the motherboard next to it.
The second one is at the Bottom of the motherboard, below the Intel 82801EB southbridge chip; which is to the left of the CMOS battery.
May have USB78 printed next to it
http://www.ebay.com/itm/Asus-P5P800-MX-Socket-775-MotherBoard-NEW-865GV-/221041609289?pt=UK_Computing_LaptopMotherboards_CPUs_CA&hash=item33771b4a49
(Turn motherboard photo 90 degrees to the Left, to be as it sits in your computer case)
EACH USB header supports TWO USB ports.
A Card Reader uses ONE USB header, with it's two cables.
Point?
Front Panel USB ports, are connected to one of those blue USB headers.
This USB header you know to be bad.
If the other USB header is not being used, connect to it.
The front of your computer is the Front Panel.
The USB ports in the Front Panel, should be connected by one common cable, and it ends in a plug on connector.
No? Not feasible?
Then suggest using a USB adapter card, in an open white PCI slot,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606148&CatId=511
Product details indicate it has two internal USB headers.
This way you can connect the Front Panel USB ports to it.
http://usa.asus.com/Motherboards/Intel_Socket_775/P5P800MX/#download
Choose ANY O/S, and then download the manual.
Or, here is the direct link to the motherboard manual (PDF file),
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5P800-MX/e2005_P5P800-MX_V2.pdf
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 03, 2013 | ASUS P5V800-MX Motherboard
Xp freezes when usb hard drive pluged in
Hello here is the homepage:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5S800-VM&p=1&s=22
If any drivers is needed.
Try to enter the device manager, and look for faults.
It sounds like the USB ports, in the computer don't provide enough power.
Does the external HDD have its own Power supply ?
Do other USB devices work ?
Maybe the pc`s power supply is running out of power, when you connect the usb harddrive.
How much ram, do you have installed ?
I suggest at least 1 gb of ram, 2 gb is better.
What service pack have you installed ?
You need at least service pack 1, to support the usb function.
Try to run ccleaner:
http://www.piriform.com/ccleaner
And make a registry clean.
A final option could be upgradeing the bios.
If the above does not help.
You just have to be very carefull, when upgrading the bios.
If you don`t have any experience with that, let a expert do this for you.
Good luck
Feb 26, 2013 | ASUS P5S800-VM Motherboard
Does asus p5gc-mmx/1333 support usb booting
Yes, enter the bios by pressing the del key on start up, you will need to have the usb device connected.
Enter the advanced settings tab and your usb device should be selectable as a boot device.
If the bios has no such option, find out what bios revision you are using (on the first blue screen after hitting the del key) and check the asus website for a bios revision that is newer.
Asus website
http://support.asus.com/download/Options.aspx?SLanguage=en&type=1
I hope this has been helpful
Apr 03, 2011 | ASUS P5GC-MX/1333 Motherboard
USB problems, 2x not supported. I am told I need
its hardware does not support USB 2, you have to buy an add-on PCI card with USB 2 ports, something like this:
http://www.startech.com/category/parts/usb-firewire/io-cards/usb-cards/list.aspx
Jan 04, 2010 | EliteGroup K7S6A Motherboard
Asus P4C800-E motherboard: All port USB working very slowly. Any way to fix this problem or usb controler dead? Thank you
hello. update your chipset driver from asus support site....if this does not work for you....you can try buying a new board eh..???
if you have xp ...make sure you have at least service pa ck 2...
if you want to buy this model asus p4c800-e from me in excellant condtion..£25
regards tonster..
wegbergtony@yahoo.com
Sep 15, 2009 | Intel ASUS P4C800-E Deluxe 875P Socket 478...
USB NOT WORKING?IT SAYS DRIVER NOT INSTALL?
Is the usb not working in any port and is it all devices that arent working? Usb drivers have been included since windows 98 SE. If for some reason they got deleted which is very highly unlikely, run a repair install by booting the the windows cd and it will replace them. Make sure though that its all usb devices that arent working, it could be that just the device you are trying to use requres drivers and they are not there. If thats the case post the device manufacturer and model number and we can help you find those drivers.
Jul 12, 2009 | ASUS P4S800-MX Motherboard
Assisstence in choosing mobo for intel 2.8 celeron
Hi im josh in cebu phils. may i help you? Friend since you motherboard dont have the 3d card. you buy a motherboard having avp slot socket 478 to be exact. there are many brands that is good for your processor.like gigabyte, asus, intel,msi or even asrock. i suggest if you buy new motherboard you choose those having higher memory for built in video like 256 or more for nice graphics. good luck !
Feb 14, 2009 | ASUS P5P800-MX Motherboard
Usb 2.0 problem
If you do turn off USB 2.0, you may have two options, "Full Speed" and "HiSpeed". Make sure you use "Full Speed", as it's faster than "HiSpeed". But the real answer is that you need to install the USB driver for your motherboard. If it came with a CD, insert the CD and read the instructions on installing drivers from it; otherwise, check Asus's website under the Support/Downloads section.
Oct 01, 2007 | ASUS A8N-SLI Premium Motherboard
ASUS P5P800-MX Motherboard Logo
99 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
