Question about Panasonic DVD-RV30 DVD Player
Vidio colour darkens and lightens
On playing a DVD, the colour fluctuates between dark and original colour. The whole track fades in and out like blinking every 30 seconds. What could be the problem.Please suggest any advice thanks
Are you, by any chance running the video output through a VCR? If so, you are seeing the copy protection (Macrovision). If this is the case, your DVD player is fine.
You either need to get a video 'stabilizer' or stop running the DVD's video output through your VCR.
Posted on Oct 24, 2009
    Genius:
  • 1,074 Answers
Get a lens cleaner and clean the lens if that does not work take it to a tech to have him check it out if its one of the latest dvd player the whole board will need to be change.if not check your wire connections maybe you need to replace them they might have a short this could cause serioue problem
Posted on Mar 10, 2007
SOURCE:
I need to lighten print on my richo2210L fax machine
To adjust the contrast, Press Darkness. Each time you press the button, the LED labeled with the selected mode turns on. You can choose from the following darkness modes:
1>Lighten: works well with dark print.
2>Normal: works well with standard typed or printed documents.
3>Darken: works well with light print or faint pencil markings.
Dec 07, 2011 | Office Equipment & Supplies
We purchased a Samsung LN46C630 less than a year ago. Within four months we noticed that the speakers would fade away and return at sporadic intervals, some quite long. Since then it seems to getting...
THE PANEL THAT DARKENS IS A DEFECTIVE PANEL TRY LIGHT PRYING TWO OPPOSED DIAGONAL CONERS OF THE TV WILL ITS DARK IF YOU MANADGE TO GHANGE THE IMAGE QUALITY PANEL IS DEFECT FOR AUDIO EITHER ITS THE SOURCE THE MAIN BOARD OR SPEAKERS
Mar 27, 2011 | Samsung LN46C630 TV
To whom it may concern, The screen is very dark. How can I fix it? Also, how can I change the brightness? thank you for your time!
To adjust the screen contrast (to lighten screen or to darken it)
  1. Press the [2nd] key and RELEASE it.
  2. Press and HOLD the UP Arrow to darken screen, or
  3. Press and HOLD the DOWN Arrow to lighten it.
Keep pressing the UP or Down arrows (whichever you need to press) until the screen contrast is adequate.
In your case, the screen is too dark, so you must press the DOWN arrow to lighten it.
Aug 12, 2010 | Texas Instruments TI-83 Plus Calculator
When powered on, the LCD screen is dark blue.
Press and hold the Control key marked with a green diamond, then press the minus key (above the + ) to lighten the screen. If you lighten the screen contrast too much you can darken it as follows:
To darken the screen press and hold the diamond key and press the + key.
May 29, 2010 | Texas Instruments TI-92 Plus Calculator
How do i lighten the screen ...it is so dark i can hardly read the print
If your screen is that dark when it boots up, you may have lost the inverter that supplies the increased voltage to run the screens backlight. The commands for the lightening and darkening the screen are as follows.....
<Fn> and up-arrow key Increases brightness
<Fn> and down-arrow key Decreases brightness
May 24, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
Won't power on even though i've installed new batteries. There is no corrosion on the battery terminals.
Check that the terminals in the battery compartment are clean and shiny. Remove any powder left after battery leakage. Insert fresh batteries in calculator. Make sure you respect the polarity diagram. +-+- (Many malfunctions come from incorrectly placed batteries).
After replacing batteries, calculator is restored to defaults and screen display may be too loght or too dark
To adjust the screen: Darken or lighten display
To darken screen
Press [2nd] key and release it.
Press and hold [UpArrow] until screen is dark enough.
To lighten screen
Press and hold [DownArrow] until screen is light enough.
Hope it helps.
Nov 14, 2009 | Texas Instruments TI-86 Calculator
When i try to graph something on my TI-83 Plus, the screen fades to pitch black and then it says INVALID DIM
Reset the RAM to clear old settings that interfer with your new problem
[2nd][MEM][7:Reset][1:All Ram][2:Reset][ENTER].
Press [CLEAR] to clear the screen.
After a memory reset you may have to adjust screen contrast.
To increase contrast (darken the screen)
1. Press [2nd] key and release it.
2. Press [UpArrow] key and release it.
3. Repeat sequence until screen darkens enough.
To lighten the screen
2. Press [DownArrow] key and release it.
3. Repeat sequence until screen lightens enough.
Hope it helps.
Oct 07, 2009 | Texas Instruments TI-83 Plus Calculator
Screen too dark
Try holding CTRL down and pressing F6 to lighten and F5 to darken screen...
Sep 11, 2009 | Acer AL2016WBbd Monitor
Screen darkness
Just fixed mine.Remove the back of the TV on my model there in a small pwer supply turn the bottom of the two pots this will darken or lighten the screen. Fine tune with the settings on the remote
Jul 04, 2008 | Televison & Video
Panasonic DVD-RV30 DVD Player Logo
88 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
