Question about Goodman CKL30AR30 Air Conditioner
A/h blower will not shut off
The airhandler blower will not shut off unless the breaker is thrown at the panel or the disconnect is pulled at the airhandler. the unit is less than 5 years old and under warranty. T-stat is off and on auto but unit still runs. I replaced the blower control board and the t-stat but the unit still runs continually. Is there a short in the heat package???causing blower to run.
Run new two wire
Posted on Feb 15, 2007
Intertherm MGHA-070ABFC-05 will not run/cool
Multiple problems. Eliminate thermostat first. Remove face from wall and turn on breaker. If fan still runs you have a bad board or bad relay. If fan outside is running compressor should be too. These operate on same contactor. Verify you are getting 24 volts to coil side of contactor. If odf stops working and contactor remains pulled in you have a bad motor. If odf motor stops working the compressor will shut off due to overheating.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 07, 2016 | Intertherm Heating & Cooling
Oven will not shut off
Good Morning Friend,
I understand your Frigidaire oven will not turn off. I also see that when you turn it off, the blower and heating element, stay on. The blower will stay on to help cool down the oven, but the heating element should turn off. I see that you have to turn your oven off at the circuit breaker. I suggest contacting your local authorized dealer for further assistance. They will be able to diagnose your appliance and determine why your oven will not turn off. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire Ovens
Oven will not turn off
-Best Regards-
WP
Main breaker how to shut off
Copy following link:
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
You need to pull meter to replace main breaker.
http://waterheatertimer.org/See-inside-main-breaker-box.html
Pulling meter might require licensed electrician unless you are in rural area. Call local electric provider about a meter pull.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 12, 2012 | Electrical Supplies
How do I turn off my master cool when it won't shut off from the thermostat?
at the master cool there should be a switch either like a light switch or will have a service disconnect just turn switch off or pull the fuse holder out to shut it down. if all that fails go to the breaker panel shoud be a breaker for it unless its wired to a\c unit .
Mar 02, 2011 | Heating & Cooling
Power turns on but nothing else turns on, just the display screen. is there an easy fix ie fuse or something?
CHECK BREAKER AT MAIN BOX , SHUT OFF BREAKER ALL THE WAY OFF AND BACK ON. IF YOU DO NOT HAVE BLOWER WHEN YOU TURN FAN SWITCH TO ON THEN YOU STIIL HAVE NO POWER TO UNIT . GO TO OUT SIDE UNIT ON GROUND AND PULL OUT DISCONNECT FUSES AND TEST THEM OUT OF FUSE HOLDER LIKE AUTO FUSES. IF UNIT IS ON ROOF SHOULD HAVE FUSES UP ON ROOF IN 6  X4 GRAY BOX. SHUT OFF BREAKER FIRST BEFORE FUSE TEST. IF FUSES OK AND BREAKER OK THAN YOU MIGHT HAVE BLOWN TRANSFORMER.
Apr 21, 2010 | Danby DAC9003D Air Conditioner
Replace 200 amp breaker
If this is the Service Disconnect Switch or Main Switch for the panel, this job should probably left for an electrician to perform, as power should be shut off at the meter socket or at the roadside first. If this is not done, the work will be "hot".
Unlike most circuit breakers in electrical panels, Service Disconnect Switches and Main Switches have the power brought to the panel by entering terminal screws. Shutting the Main or Service Disconnect breaker off prevents the flow of current *into* the panel and other circuit breakers. The large wires that are connected to the terminal screws are LIVE, and will remain so until shut off *upstream*.
Working in a panel with two large diameter cables that do not move easily is a hazard and should not be done unless you are very familiar with this work - and of course, have shut the power off.
Please, reconsider doing this work yourself.
Sep 29, 2009 | Computers & Internet
Ruud air handlers
Check the name plate amperage on the air handler. The air handler only has the blower motor as its main current draw. #12 wire is rated for 20 Amp service. If the amp draw by the unit supplied by the disconnect is under 15 amps it should be fine (but) once again check the name plate for ampacity rating.
May 27, 2008 | Ruud UBHC Air Conditioner
Goodman CKL30AR30 Air Conditioner Logo
159 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Paul
Paul
Dennis Boxerman
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
