Question about Panasonic AG-456 Camcorder
Can I use Panasonic AG456 camcorder on PAL system ?
Le istruzioni che ho scaricato parlano di NTCS sistem
Ma in editring si pu? convertire in pal con power director oppure usando un software di conversione anyconverter pal
Posted on Mar 04, 2010
How to switch from pal to ntsc
Camcorders have only one color system to record accordingly, either PAL or NTSC
Sony DCR-HC36 is NTSC camcorder and DCR-HC36E would be PAL camcorder.
Hope this info will help you.
Thanks.
Nov 28, 2009 | Sony Handycam DCR-HC36 Mini DV Digital...
How can i change my panasonic nv-gs230 mini dv
Best
1. Copy the video to your computer with WinDV. No "capturing" involved. The video resolution and PAL/NTSC format will be the same as the source.
2. Then convert to whatever format you like.
You could also use something that copy and converts the video directly from the DV, like convert to dvd with Ulead DVD Workshop.
DV is a fixed standard and comes in 50Hz and 60Hz versions.
50Hz ("PAL" 625/50) 720x576, 25fps interlace (aka 576i)
4:2:0 components, 25Mb/s Video Rate
LPCM audio 2ch 16bit 48KHz or 4ch 12bit 32kHz
60Hz ("NTSC" 525/60) 720x480, 29.97fps interlace (aka 480i)
4:1:1 components, 25Mb/s Video Rate
Meaning, You cannot change the camera. It is either a pal camera or a ntsc camera. Othewise you will have to by a firmware update from the manufacture's website.
Oct 14, 2009 | Panasonic NV-GS230 Mini DV Digital...
Play video on tv
Chnage Color system in Panasonic TV and try again. If your camera is NTSC, select NTSC in TV,... If its PAL, TV must be on PAL system.
Jul 29, 2008 | Video Cameras
Pal to NTSC
try NERO software...you will be able to go back and forth (pal or ntsc)...this might be a project / but you can also make into a very fun thing....(note also the DVD regions)
Jul 19, 2008 | Sony DVDirect VRD-MC3 DVD Recorder
Panasonic ag456
these camera should operate with only the adapter, but they are notorious for having broken solder connections on the rear board where the audio and power connectors are. disassemble the camera and re-solder the connectors on the board; you may need to add a little epoxy glue to help hold the audio connectors.
Sep 25, 2007 | Panasonic AG-456 Camcorder
Urgent - pal ntsc
Pal and NTSC are different formats. If you live in Canada, you?re TV most likely supports NTSC and not PAL. If you bought your TV and it said it is multisystem, so you won?t have problems with if, but i am almost sure this is not you case. If you want it for your PC, you will need to get a program to change your videos from PAL to NTSC. What I would recommend you to do is to buy a miltisystem camera; the format transformation isn't the easiest way. Daniel
Sep 06, 2005 | Panasonic AG-185 Camcorder
Panasonic AG-456 Camcorder Logo
124 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
