Mitsubishi WS-65908 TV question
In march of 08 keever answered a problem about a Mitsubishi WS-65908 TV that had a blinking light on the front and would not stay on after a power outage, he suggested replacing the horizontal output transistor
i have pulled my tv apart and there are two parts that match his discription for the H.O.T. i can not figure out if part A or part B (see pics) are the H.O.T.
please help
Slinteriors
  • 8617 Answers
SOURCE: 2002 WS-65908. Timer light is
That model has had some issues with bad capacitors on the DM board going bad. Does the LED blink constantly?
Posted on Mar 08, 2008
Maanita
  • 1142 Answers
SOURCE: Mitsubishi WS-55857 won't turn on
Thank you for posting your concern details however i would be needing few more details from your side if necessary and allow me few mins to come up with the resolution.
Posted on May 19, 2008
  • 9 Answers
SOURCE: i had a power outage and now the tv will not power
You may have a blown fuse. Unplug the TV and remove the back. Look for a small fuse near where the power cord goes in.
If it is blown that may be the problem.
Use a magnifying glass to read the AMP rating.
replace the fuse and plug it in. If the fuse blows again you need expert repair services.
If the fuse doesn't blow then try to turn it on.
If it turns on then check the operation of the TV.
If the fuse blows again or the TV won't work correctly then you need expert repair service to fix your TV.
You may be able to have your household insurance pay if it is damaged by lightening or a power surge.
Lee
Posted on May 02, 2009
leethedeuce
  • 4472 Answers
SOURCE: The power outage went out yesterday and my tv wont turn on
Most likely it is capacitors on the dm board that have gone bad. This is a fairly common problem and has been addressed on fixya many times. If you know someone who is good with soldering and technically incline or even an honest electronics guy then the repair is quite cheap. If you have any other questions please let me know. if its not the capacitors on the DM supply then its a problem with the whole DM assembly that part usually is around 300$. So you may want to consider purchasing a new tv. Trying the 7 caps on the dm supply board shouldn't cost much if it takes anything more then that. I would sell the tv on craigslist or ebay and recoup as much as you can towards your next tv.
thank you,
lee
Thank you,
lee
Posted on Apr 01, 2010
SD Tech
  • 14553 Answers
SOURCE: The Mitsubishi Diamond Series WS-65908 does not
1blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
If it is 2,4 you have a problem in the vertical circuit and I would suggest you first look for any signs of glycol there.
Let me know if you need more information.
SD TECH
Posted on Oct 01, 2011
The on/off relay does not stay engaged
Based on model number listed here:
If set powers up and green light comes on and goes out a few seconds later:
Press and hold menu and input (source) buttons at same time on the front of the set for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks, 2 blinks, pause and repeat it for a total of five times.
If the set has been unplugged you will have to plug it in and turn it on letting it fail (unplugging will clear all errors).
Let me know error code and I will explain--2,2 is most common and most easy one to fix.
Jun 12, 2012 | Mitsubishi WS-65908 TV
Mitsubishi WS-65908 will not stay on
Its a color convergence problem from description:
If green light comes on for a few seconds and goes off:
On the front of the set (not the remote) press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and release both.
Watch power light: it will blink a two digit error code, in your case I suspect it will be 2 blinks, 2 blinks and repeat several times.
Let me know error code and I will help.
Apr 16, 2012 | Televison & Video
The Mitsubishi Diamond Series WS-65908 does not power up. The troubleshooting code is 2-4
SD TECH
Oct 01, 2011 | Mitsubishi WS-65511 65" Rear Projection...
I have a WS 65908........it has the same problum--listed on this site.......power on for 3 seconds...and it said this.... Do the self test this model has: When set shuts off and on front of set power...
Error code 23 on this set means that the Horizontal Deflection circuit of the set has failed. Usually this points to a damaged Horizontal Deflection IC and sometimes the HOT(Horiziontal Output Transistor) as well, not to mention the resistors that are blown when the IC failed. Replacing these parts should resolve the problem.
PS:Note that the Deflection circuit involves certain high-voltage components and prior to repair it is advisable to discharge the high voltage before attempting the repair. You will also need to know how to use a multimeter(to test the HOT and look for blown resistors) and a soldering gun. If you think you can do it yourself, let me know and I will provide you detailed step by step instructions.
Sai.
Sep 15, 2011 | Mitsubishi WS-65908 TV
Power on for 3 seconds then shuts off
When set shuts off and on front of set power light goes out:
Press and hold on the front of the set both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will blink an error code: most common is 2 blinks, 2 blinks a pause and then repeats it several times.
This feature will narrow down where the problem is.
Let me know what error code is found and I will tell you what it means.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Sep 29, 2010 | Mitsubishi WS-65908 TV
I have a ws-65908 that won't power up. When I press the power on button, the green light at the ON button comes on then goes off 3 seconds later. Any ideas on how to fix it?
Have you tried to access the self diagnosis feature by holding in the menu button and the device/input button on the set for five seconds? The led should blink a series of blinks then pause briefly then blink another series of blinks for the 2nd digit let me know what the blink code is an I will assist you.
Jun 25, 2009 | Mitsubishi WS-65809 65" Rear Projection...
My mitsubishi tv model ws55908 will just turn itself off after I have been watching it. It could be as soon as 1 or two hours or 4. it does not happen all the time I can go a month without it happening...
This TV has a self diagnosis feature. When the set fails, push "menu" and "input": buttons at the same time and hold them in for more than 5 seconds. Watch the front panel light. It will blink two numbers five times. Get back to me with the numbers.
Apr 15, 2009 | Mitsubishi WS-65908 TV
Power went out, tv won't come on
If you are lucky, it's only a blown fuse, but with a blinking light on the front, this is doubtful. I would pull the back cover anyway and check the fuse. If fuse is ok, then normally if you have no sound and no picture, you have a blown "horizontal output transistor". Look for the big wire (usually red) coming from the picture tube to the circuit board. The red wire goes to a large object on the circuit board called the "flyback" transformer". Usually very near this transformer you will find the h.o.t. (horizontal output transistor). It will normally be mounted on a silver piece of metal (a heat sink), about 2 or 3 inches square or possibly rectangular. The transistor has three pins coming out of it and is probably the largest transistor you will see that has only 3 pins. The upper portion of the transistor will be clamped (or screwed) into the metal heat sink. You have to desolder the h.o.t. and replace it with a new one. The h.o.t. usually costs only about $10.00. If the fuse and h.o.t. are good, then the "flyback" is probably bad and they run from $25 to $100. If the TV is worth only about $200, then replacing the flyback is not recommended, because there is no guarantee that this will solve the problem. Keever.
Mar 02, 2008 | Mitsubishi WS-65908 TV
Projection red is above other colors
Look in your menu for something called "horizontal static convergence" or just "convergence". Adjusting this will align all three tubes electronically. If physical adjustment is needed, then you have to do this manually inside the Tv. keever
Dec 09, 2007 | Mitsubishi WS-65908 TV
Re:problems
Your TV is probably shutting down due to excessive current draw. Replace the filter capacitor in the power supply and cross your fingers. This will be a large, tall, and round shaped object near the location where your power cord goes into the TV. It has two pins and one is positive and other is negative. Do not get them crosses when installing new part. keever
Oct 22, 2007 | Mitsubishi WS-65908 TV
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
