Question about Dell Inspiron 530s Desktop Computer (ddcwfa2_5) IntelPentium dual-core processor E2160 (1MB L2,1.80G
Problem turnining computer power on
For the past several weeks I have had a strange problem with my Inspiron 530S (Intel Core2 Duo): one day I turned it off and then could not turn it on again using the power button on the front. I tried several things and found something that works: I unplug the power cord from the wall outlet, wait about 30 second and plug it back in, at which point the power goes on again and the computer boots up. Also, even when I turn off the computer, using Windows XP menu, several lights including the power button light on the front of the computer stay on. It is only when I remove the power cord from the wall that these lights go off, and then as I said the computer boots up immediately when I plug it into the wall outlet again. Dell techincal support was no help in several phone calls I made. They wanted me to take the computer apart.
    Sergeant:
    Champion:
  • 200 Answers
Hi
Replace the SMPS and then try it..
If u have warranty means then claim it...
Thank you
Posted on Dec 06, 2008
    Sergeant:
  • 302 Answers
Your power supply is going bad, its an easy thing to replace and less than sixty dollars to replace for about a 450 watt power supply
Dell inspiron 530s won't turn on
check cpu.check fuse in plug.
check all what runs your power.
Apr 04, 2014 | Dell Inspiron 580 Desktop Computer (Intel...
Intel core tm duo cpu e4500 motherboard
Intel = Processor (CPU ) manufacturer
Intel Core tm = Trademark. The Intel Core is a Trademark from Intel
CPU stands for Central Processing Unit. Another term used is Microprocessor, or simply - Processor for short.
e4500 is an Intel Core2 Duo processor.
Maximum frequency rate ('Speed') is 2.2GigaHertz.
2MegaByte of L2 Cache. (2MB of L2 Cache)
800MegaHertz Front Side Bus. (800MHz FSB)
Tells me Nothing about the actual motherboard. Look on the motherboard for a Model Number. May be in center of motherboard. May be on edge of motherboard. May be in-between one of the expansion slots, on motherboard.
Post back in a Comment.
Also post what the problem is, in your best description.
Computer does not turn on. (Power Supply does not turn on)
Computer seems to turn on, but get No Signal on monitor, or Sleep Mode on monitor, or Power Saver Mode on monitor.
LED lights light up, and fans spin.
Regards,
joecoolvette
Apr 23, 2013 | Computers & Internet
Would a Intel Core 2 Duo E6600 Dual-Core CPU 2.4GHz Socket LGA775 1066MHz 4MB be compatible with a Dell 530s?
you need to know what motherboard you have. If you download a free program called Belarc and install it it will give you all the information about your pc. Once you know what motherboard you have then just google it and see what cpu's are compatible.
Dec 06, 2012 | Dell Inspiron 530s Desktop Computer
CPU Upgrading Question for Dell Inspiron 530s! Help! In the future, I'm planning to replace the Intel Celeron 440 2.0 ghz processor with a Intel Core 2 Duo E4600 2.4 GHz 2M L2 Chace 800MHz FSB LGA775...
Here is a link for your computer's manual:
http://support.dell.com/support/edocs/systems/insp530s/en/OM/HTML/parts.htm#wp1578680
Follow the procedures outlined and be sure to clean the surface of the heat-sink (alcohol works) and reapply thermal grease compound to the surface of the new processor.
Aug 12, 2011 | Dell Inspiron 530s Desktop Computer
Dg41 is the best
Please get DG41/CN/TX motherboards it the best. this is due to fact that it carries a better graphic resolution card, lates technology DDR3 SD RAM ram, etc.
Intel DG41CN Motherboard
  • Form Factor: Micro ATX
  • Compatibility: PC
  • Chipset: Intel G41 Express
  • Compatible Processors: Intel Celeron, Intel Pentium, Intel Core2 Duo, Intel Core2 Quad
  • Video Interface: PCI Express x16
  • Storage Controller Type(s): Serial ATA II x 4
  • Intel DG41TX Motherboard
    • Compatibility: PC
    • Compatible Processors: Intel Celeron, Intel Pentium, Intel Xeon, Intel Core2 Duo, Intel Core2 Quad
    • Front Side Bus Speed: 1333 MHz
    Regards,
    Pourmoi
    Dec 23, 2010 | Intel DG31PR Motherboard
    I can't get any sound out of the computer. I have the speakers set up an plugged in, but no sound.
    Drivers ... drivers .... also remove it from the device manager and let windows find it after you install correct drivers
    Oct 13, 2009 | Dell Inspiron 530 Desktop Computer...
    Press power button. Green light turns on, fan
    there is power buttom on the keyboard makes it wake up. try it
    Oct 02, 2009 | Dell Inspiron 530s Desktop Computer...
    Mac book says you need to restart your computer . hold down power button for several seconds or ppress the restart button ?
    Pressing and holding the power button will shut down your computer. Then you can restart it. You can also tell the computer to restart with the restart command but that does not alway work depending on the problem.
    Sep 02, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
    Wireless adapter not found on my pc.
    if ur using inspiron 530s,then i believe ur computer is within the warranty,get the wifi card replaced by a different brand of card which fits into ur computer{if it s a slim tower}.it is a common problem with 530s
    May 11, 2009 | Computers & Internet
    Cpu enquiry
    There really is no difference, there are differences in the E numbers though. Those are specificallt about it's GHz's, it L1 and L2 cache.
    Though Intel Core 2 Duo is the same as Intel Dual Core. It's just a different name. This confusion is caused because of Intel changing the names of it's processors series. The Pentium brandname for example is gone. Intel Pentium Dual Core is now called Intel Core 2 Duo.
    I hope this answered your question.
    Greetings,
    DarkNeogen.
    Jan 25, 2008 | Intel Core 2 Duo E6600, 2.4 GHz E6600...
    Dell Inspiron 530s Desktop Computer (ddcwfa2_5) IntelPentium dual-core processor E2160 (1MB L2,1.80G Logo
    143 people viewed this question
    Brian Sullivan
    Brian Sullivan
    mukhtar21 shaikh
    mukhtar21 shaikh
