Our washing machine vibrates and walks all over the floor. i have checked it with a level front to back and side to side and all is level. when you open the lid the tub is leaned to one side and not centered.
  • Washing Mach... Master
  • 3,463 Answers
Possibly a suspension leg or spring has failed or broken, causing the drum to go off center.
This will cause it to move about.
Posted on Dec 06, 2008
Washer vibrates and walks during spin cycle. Washer is on a vinyl floor
check to make sure the washer is level, and double check to make sure the shipping bolts have been removed from the back of the washer.
Feb 12, 2011 | Maytag MAH8700A Front Load Washer
Vibrates then starts walking across floor
LG washing machines are very finicky with being leveled, they must be 100% level, and squared up on all sides. Be sure to lock the nuts in place, once you level it, to where it needs to be. They are also finicky with certain floor surfaces, more leveling may be required.
Mar 30, 2010 | LG WD-16115FD Front Load Washer
Maytag walking
Hello. I have a few ideas for you.
1. Tilt the machine forward so the back feet are 3 to 4 inches (7.5 to 10 cm) off the ground, then set it back down. The back feet usually are self-leveling--just raising and lowering the machine like this will cause the feet to re-level themselves.
2. Place your level perpendicular to the front of the machine and check to see if the washer is level in this direction. If it is off, readjust each front foot by the same number of turns until you reach level.
3. Go to the carpet store and buy a remnamt which is the size of the washing machine lengthxwidth. Place this under the machine with the four legs all resting on the carpet.
Regards, Joe
PS please rate my answer. thank you.
Dec 20, 2009 | Maytag MAT13MN Top Load Washer
Washing machine walks
The problem MAY be fixed. I went to http://www.fixya.com/support/t14304-washing_machine_walks_across_floor , made sure shipping bolts were out, then discovered nuts that clamp the feet were loose. They are now tight with unit re-leveled. Testing is in progress.
Oct 28, 2009 | Kenmore HE2 Plus Front Load Washer
Vibration during spin cycle - "walking" across floor
dear sir/mam
please check the floor level of your washer by using the spirit level,if there is difference please adjust the level by screwing the legs of the washer,then vibration will be stopped.
Jun 01, 2009 | Whirlpool Inglis IP4400 Washer
Washer is "walking" during the spin cycle
I have the same Duet that vibrates heavily during spin cycle. Leveled the unit with no success (our unit is mounted on the high base). Long story short, I went to Lowes and purchased a package of 4"X5" self stick foam rubber pads called Grippers by Wasman Consumer Group and paid a low price of $3.50. Since the washer walked forward, I cut one of the two Pads in the package in half, removed the sticky side paper protector and centered a half, sticky side to washer pad, to each front washer pad. The problem was solved.
I made sure the round floor pads of the washer were tight and the unit was level before attaching the Grippers. Hope this helps.
Jan 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag front loader MAH-3 vibrates. Level & on concrete floor.
THERE ARE SHOCK ABSORBERS IN THIS UNIT,SOUNDS LIKE ONE OF THEM IS BROKEN.HOPE THIS HELPS
Nov 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Walking Washer
due to weight and normal motion during wash/spin a very sturdy floor is necessary under front loads also some floors are a little slick and sliding may occur ck for weak floor and maybe some kind ok rough cushion under feet to reduce sliding also if on pedistals even more vibration may occur be sure all screws in pedistal are secure usually 4 from top onto bottom of washer also adj legs to lower unit as close to floor as possible and tighten lock nuts
Apr 25, 2008 | LG WM-2277HW Front Load Washer
Unbalance
You problem may a simple leveling issue. Check your machine front to back and side to side to ensure it properly level. Also, most top-loaders have "self-leveling" feet on the rear legs. If you walk up to your washer and it looks like the back is sitting lower than the front, you may only have to follow a few simple steps to re-level it. If your machine is equipped with this type of leveling system all you have to do is to lift the rear legs of the floor about two-inches by rocking the machine (empty of water, of course) towards you: 1. Lift the lid. 2. Place one hand under the rim of the front casing (not the wash tub). 3. Place your foot at the center of the front base to keep it from sliding. 4. Pull towards you to lift the back feet off the floor. 5. You should hear clicking noises as the feet re-level. 6. Slowly lower machine back to the floor. This should take care of most leveling problems that cause your machine to vibrate and shake during the spin cycle. These legs periodically become unlevel due to vibration and need to checked from time to time. I hope this may help you.
Apr 09, 2007 | Magic Chef CAV4000 Top Load Washer
A walking machine
ADDITIONALLY,CHECK AND MAKE SURE TRANSPORT BARS ARE CORRECTLY REMOVED.NOTICED ON MANY OCCASIONS TO THAT IF WASHER IS IS USED ON TYLED FLOOR, IT WILL SLIP AND SLIDE REGARDLESS. ON A MORE SERIOUS NOTE, CHECK IF STABALISER BLOCK HASNT POSSIBLY WORKED ITSELF LOOSE.
Jan 18, 2006 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
