Question about Honeywell Heating & Cooling
Where can i get a honeywell t7335d tempreture sensor
    Sergeant:
    Champion:
  • 200 Answers
Hi
U can get it from here
Click this
thank you
Posted on Dec 06, 2008
My honeywell cm900 thermostat keeps showing the tempreture as -24 degrees, therefore it keeps working on full power in order to bring the tempreture back up
I would change the battery first. Then try adjusting the temperature to see if that has any affect. From here I would guess the temp sensing thermistor is open or short, causing it to indicate the extreme temperature of it's capability. Test the thermistor and replace, or replacing the thermostat are the only solutions. I hope this helps.
Oct 21, 2013 | Heating & Cooling
F3 error code on Kenmore 911-45569690
Yep F3 I dont even have to look that up fault with oven tempreture sensor. If you perform an ohms test on it at room tempreture should read between 1000-1100 ohms if less then replace. Thanks again
Rick
Nov 24, 2011 | Ovens
Hi my whirpool oven is stating F 03 what do i have to do? Thanks
Usually the F-03 error code means you have a bad oven tempreture sensor. To test the tempreture sensor you would use a multimeter set to ohms. At room tempreture the sensor should read between 1000-1100 ohms any less then this and you would replace the oven tempreture sensor in the unit. If you have any further questions message me back. Please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks
Rick
p.s I also looked afterwards in your service manual and the F-03 error code does refer to the oven tempreture sensor
Sep 13, 2011 | Whirlpool RBS275PD Electric Single Oven
F2 error display on kenmore oven model 911.47869. Bottom element not working but has continuity on ohmmeter. Top element working. Oven sensor has continuity on ohmmeter too. What else to check???
Hello, That is great that the oven tempreture sensor has continuity but you would need to do an ohms test on the sensor itself and it should read at room tempreture between 1000-1100 ohms any less then this and you would replace the sensor. If you did have between the proper amount of ohms on the tempreture sensor you would then look at replaceing the control board but most likely in your unit it is due to a bad oven tempreture sensor. If you have any further questions message me back also make sure you unplug the sensor and the oven before performing this test. Thanks Rick
Aug 31, 2011 | Kenmore Ovens
My washer keeps flashing f24 and wont turn on what does it mean?
Hello, This is a water tempreture sensor error due to if the tempreture sensor value is out of range during the water heating up step during the cycle. Unplug washer or disconnect power, Check the water tempreture sensor and connection to it,check the resistance of the heating element using a multimeter. If you have any further questions message me back this error code diagnosis is for a whirlpool duet washer if you happen to have a different type of washing machine message me back your make and model number of your machine. Please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks
Rick
Aug 18, 2011 | Whirlpool Washing Machines
We are bakeing and every time we set it in a couple it shuts down and F_3 apears what would cause this?thanks 4 help
first thing to do would be to test the oven tempreture sensor by conducting an ohms test on it at room tempreture should be reading between 1000-1100 ohms if it were less then replace it this fixes the f3 error code only 90 percent of the time on other occasions it could be both the tempreture sensor and the control board 10 percent of the time but seeing how the tempreture control sensor is far cheaper test that first and if it fails replace the sensor and also make sure you check the wiring to the sensor and to the control as well it says directly in your service manual this
F3 Open oven temperature sensor Check wiring harness, replace oven temperature sensor if necessary
if you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped it allows me to continue helping others in similar situations Thanks again Rick
May 08, 2011 | Kenmore Ovens
The temperature of the large oven is low by about 75 degrees F to the readout . Can this be adjusted?
check the oven tempreture sensor do an ohms test on it at room tempreture should be reading 1100 ohms if it were less then you would replace the sensor if the sensor is at or around 1100 message me back there are a couple other things that you could also check thanks again
Rick
Dec 18, 2010 | Dacor Epicure ERD36 Dual Fuel (Electric...
The oven is on its highest setting no matter what temp i chose on the dial. we have changed the element and now its as hot as hot.
have you replaced the tempreture sensor? usually faulty tempreture sensor will cause your heat to either be to high or to low
Apr 29, 2010 | Ovens
Heater fan blows out cool air then car over heats then blows hot and cools the car back off. It does this over and over. Changed thermastat and waterpump already.
is your vehicle automat climate control ?
suspect the tempreture sensor in the vehicle is defective and is not giving a true reading of the relationship between the set tempreture and the true air tempreture.
Nov 13, 2009 | 2002 Pontiac Grand Am
The heat control device cannot set needed tempreture
it sounds like a bad thermostate, it culd be easier and cheaper to get a new heater. Check their website for replacement parts and be sure it's a job you think you can tackle.
Dec 22, 2008 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Heating & Cooling Logo
153 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
