Question about True T-49 Side by Side Refrigerator Commercial
Is the True T-49 prone to problems?
I am in need of a commercial refrigerator.  I am looking at the True T-49 unit.  However, I noticed a lot of problems on this discussion board.
1) Is this abnormally high for this model?
2) Would you recommend I should buy this or stay away from it?
3) Do you have a recommendation for a different refrigerator?  I have somewhat of a tight budget.
Thanks
  • 51 Answers
I believe you will be fine if you purchase any True, Trawselson, Delfield, or Hobart reach it. These are all name brand and I have seen them last for years.
Posted on Feb 17, 2009
How do i chage the temperature on a true cooler gdm 49 florial cooler
True GDM-12 Refrigerator... Repair Questions - Fixya
www.fixya.com/support/p22955-true_gdm_12_refrigerator_commercial
Recent True GDM-12 Refrigerator Commercial questions, problems & answers. ...Where is the temp control on the older (14 yrs or so) on GMD-12? True ..
Aug 16, 2014 | True GDM-12 Refrigerator Commercial
Seal Gaskets
Generally if you are using the factory seals you never have a problem unless you've damaged the retainer that holds the dart. After market gaskets wont work as well it has to do with the magnet strength, thickness, etc. call True in St Louis if you have to, to get the supplier. Good luck, hope this helped.
Apr 07, 2014 | True T-49 Side by Side Refrigerator...
Seperating Gaskets
Call True in St. Louis and get a name of a supplier that carries factory parts. After market just doesn't work as well as you've noticed. Hope this helps and good luck.
Oil leaking from fan...True TS-49. Fan stopped...got fan going by spinning it. but frig is not sealing.
It sounds like you need a new fan motor. Is it the fan inside the refrigerator compartment or the very bottom of the unit? And what do you mean by not sealing? Let me know. I can order the parts for you.
Nov 25, 2010 | True T-49 Side by Side Refrigerator...
Hello, experts! My TRUE T-49 side-by-side refrigerator collects water inside. The clear tube at top rear inside appears full. I hope to get some info before I disassemble anything. Help? ...
A lot easier to remove the bottom grill - four screws - two on each side. The drain tube runs down there and is usually strapped to the bottom of the unit over a pan. Doesn't take much pressure to **** or blow into that tube and clear the obstruction. If you haven't looked undedr there clean the condenser coil while you're at it.
Sep 19, 2010 | True T-49 Side by Side Refrigerator...
Hi there, We have 2 T-49 refrigaretors , but
Whoever sold you the refrigerators should have a parts department where they can order certain parts for any unit. If they don't have it or can't get it, I've found that partstown.com has pretty much every part for True refrigeration that is still being manufactured.
Mar 26, 2010 | True Reach-In T-49-2-G-2 Commercial...
We'd like to stop the True T-49 fans from running all the time
You would have to have your fans power supply wired in series with the thermostat.
Jan 06, 2009 | True T-49 Side by Side Refrigerator...
True t-49 refrigerator
Yes it can. You would have to call a service company to recover the refrigerant, remove the oil in the compressor. They would then replace the oil as well as the refrigerant. The metering device would also need to be changed, along with the thermostat.
Aug 17, 2008 | True T-49 Side by Side Refrigerator...
T-49 Relay
hi thanks for the question you gan get the relay at kemet electronics thanks the appliance doc
Jul 30, 2008 | True T-49 Side by Side Refrigerator...
True T-49 side by side is noisey
is unit cooling? if not suspect a deficient compressor. if it likes makes a rattling noise really loud suspect compressor wear hope it can help.
Apr 18, 2008 | True T-49 Side by Side Refrigerator...
True T-49 Side by Side Refrigerator Commercial Logo
185 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
