Question about Philips 60PP9352 60" Rear Projection Television
Philips 60pp935217 when i turn on my tv it just beeps
    President:
  • 1,952 Answers
This could be bad connections around the amplifier chip. Look inside the set close to where the speaker wires connect to the board. There should be a smal chip attached to a heatsink. Resolder the connections for that chip
then
I would guess that the problem is within the tuner. The tuner will take the incoming signal and generate the audio and video from it. It sounds like after warm up, the tuner fails to produce the audio signal. Using the other inputs (AV or S-video for example) bypass the tuner section.
Posted on Dec 07, 2008
  • 586 Answers
    A short circuit occured in the horizental section.Check the components in horizental section and replace the shorted component.
Thanks.
  • AMJAD HUSSAIN Dec 07, 2008
        MOreover if you need a service manual for this tv.Please visit the link below:
    http://www.servicemanuals.net/ServiceMan...
    Thanks.
Philips DPTV 310, 60PP935217 We got this tv. As it was brought, they took out the front glass to transport. Question is. There are 2 glasses. Wich glass, in wich order, and which side has to be Built
The pair taped together usually are the inner and it is possible to put in backwards----should have marked this with masking tape before removal which is rarely needed to transport this set---cover with heavy quilt and face forward in a pickup etc so wind does not **** screens out.
Nov 02, 2012 | Philips Televison & Video
I have a big magnavox tv that all of a sudden the picture went out with only sound. I tried everything possible from changing cables and calling my cable company to see if the problem was there but no
Your flyback has failed most likely...bad new is they are nearly impossible to find, This is a known issue on most of the models below. The site Tv Repair Kits can sometimes get replacements - but its not often.
This repair kit is known to work on Magnavox TV sets with the following Chassis/Model Numbers.
DPTV305 , DPTV305F , DPTV310 , DPTV315 , DPTV330 , DPTV330F , DPTV335 , DPTV340 , DPTV345, MAG01
Model Numbers
( 43PP9202/17 43PP920217 43PP9202/17F 43PP9202/84 43PP920217F 43PP920284 43PP920201 43PP920284F 46PP9302/17 46PP930217 46PP930201 46PP930217F 46PP930284 46PP930284F 46PP9302H17 50PP9202/01 50PP9202/17 50PP9202/84 50PP9202/84F 50PP920201 50PP920217 50PP920284 50PP920284F 50PP920217F 51MP392H/17 51MP3964H/17 51PP9303H/17 51PP9363H17 51PW9303/17F 51PW936317F 55PP9352/17 50PP920217F 51MP392H17 51MP3964H17 51PP9303H17 51PP9363H17 51PW930317F 55PP935217 55PP935201 55PP9363H17 55PP9502/84 55PP950284 55PP950201 55PP950217 55PW936317F 55PW9383/17F 55RW9515/35 60PP9202/17 55PW938317F 55RW951535 60PP920217 60PP920201 60PP920217F 60PP9352/17 60PP935217 60PP935201 60PP9363H17 60PP938317F 60PP9502/17 60PP950217 60PP950201 60PW936317F 60PW938317F 43PP9202/17 43PP9202/17F 43PP9202/84 43PP920217 43PP920217F 43PP920284 43PP920201 43PP920284F 46PP9302/17 46PP930217 46PP930201 46PP930217F 46PP930284 46PP930284F 46PP9302H17 50PP9202/01 50PP9202/17 50PP9202/84 50PP9202/84F 50PP920217F 51PP9303H/17 51PP9363H17 51PW9303/17F 50PP920201 50PP920217 50PP920284 50PP920284F 51PP9303H17 51PW930317F 51PW936317F 55PP9352/17 55PP935217 55PP935201 55PP9363H17 55PP9502/84 55PP950284 55PP950201 55PP950217 55PW936317F 55PW9383/17F 55RW9515/35 60PP9202/17 55PW938317F 55RW951535 60PP920217 60PP920201 60PP920217F 60PP9352/17 60PP935217 60PP935201 60PP9363H17 60PP938317F 60PP9502/17 60PP950217 60PP950201 60PW936317F )
Mar 29, 2012 | Philips Televison & Video
BLUE CONVERGE NOT WORKING
most likely convergence IC's usually 2 of them
Aug 10, 2009 | Philips 60PP9202 60" Rear Projection...
My philips 60 inch 60pp935217 TV showing murky
If your saying the picture looks cloudy then the CRT fluids need to be replaced also known as projection tube coolant.In most cases only the blue and green CRT's need to be serviced.
Apr 30, 2009 | Televison & Video
Philips 60PP935217 60 in. Rear
I would check the regulator transistors and then the horizontal output tarnsistor.
Apr 09, 2008 | Philips 60PP9352 60" Rear Projection...
Phillips 60pp935217
I have a phillips HDTV monitor model 60pp935217, i don't get an hd picture but i do have sound. Please help.
Apr 08, 2008 | Philips 60PP9352 60" Rear Projection...
Hooking up computer to philips 60pp935217 AV5 HDTV connector?
Hi Roger,
Initially, pls try lowering the screen resolution of your PC. This can be done at the Display Properties/Settings tab and then move the slider of the Screen resolution towards the left, Apply OK. In some instances, you need to also lower down the Screen refresh rates in the Monitor tab of the Advanced Properties.
If your concern has not been corrected after completion of the above procedures, then other methods can be considered.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 15, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
