Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
My machine is giving me an error 88 and keeps flashing fast when I turn it on.
I have embroidered several things but am not having a problem with my embroidery unit. When I attach it to the sewing maching and turn it on it gives me an error 88 and the start button flashes fast red. Any suggestions?
  • Anonymous Apr 21, 2009
    I have a futura 350 and just turned it on and it is flashing 88 and all the buttins are flashing red! Brand new machine, only used it about 10 times! I hope there's an easy fix!
  • Anonymous Mar 29, 2014
    when the embroidery part is attached the machine light up and the number 88 light up in the display window.
Posted on Aug 29, 2010
    Problem Solver:
  • 7 Answers
Attach the hoop ONLY after you turn on the machine.
Posted on Aug 01, 2007
I had that problem when the machine was not threaded correctly. I now floss the thread back and forth through the tension area everty time I thread the machine, to make sure the thread is in the right place.
Posted on Jul 26, 2007
  • R.A. Ellis
    R.A. Ellis Nov 16, 2017
    Ooh, be careful "flossing" up and down. Thread should only be pulled DOWN between the tension disks. Instead, try RAISING the presser foot when threading. Raising the presser foot releases the tension disk so the thread will seat completely in the tension disk.
Why do I keep getting error C 12 'hoop size is smaller than embroidery data'?
the machine may have a problem with a sensor, if turning it off/on again doesn't clear the machine, you may need to have it checked
Dec 19, 2015 | Sewing Machines
Futura xl 400
try a new needle
try a new bobbin--make sure the bobbin is turned the right way in the bobbin case
check under the needle plate and in the feed dog area for thread
it could also be a problem with the motherboard.
Sep 03, 2013 | Sewing Machines
My HV DD gives a "motor overloaded" code after the power went out in the middle of it embroidering
if there is a reboot option it should be in the instruction manual
if it doesn't show there, contact the one you bought the machine
from to see what they suggest.
you said you had the machine plugged into a serge protector
I also suggest a battery back up you can get them at different stores
like wal mart or best buy, that way if the power goes out the battery
back up will kick in and keep the embroidery project going, the
battery back ups have different time amounts on them, we have 2
battery back up, one for our desk top pc and the other for our
daughters pc for her school work and they do come in handy.
Dec 03, 2012 | Sewing Machines
Error message asking to lower feed dogs before embroidering, feed dogs were lowered
Try raising and lowering the feed dogs a couple times there may be something in there that's tripping the sensor.
Nov 11, 2012 | Janome Memory Craft 10000
I have a Singer Futura 350. I keep getting an error code of "88" which says the machine isn't threaded properly. I've had & used this for nearly 2 years without issue. I've re-threaded many times and...
It ended up being an airhead mistake... my embroidery foot had loosened and became crooked, causing the machine to think that the thread was hung up because the foot couldn't go down properly. Very happy that it wasn't an expensive fix. In fact, it didn't cost me a thing! Yea!!!
Dec 10, 2009 | Singer CE-200 Quantum Futura Computerized...
My Singer 7436 keeps getting an error code 88
I have been having the same thing happen. I just discovered the bobbin winder was in the wind position. I moved it and I am in business again! Hope it works for you!
Apr 11, 2009 | Singer 7436 - INGENUITY
Futura ce-100 embroidering in the wrong place
I decided to simply start from the beginning and start all over. I turned off the machine, detached the embroidery unit and blew into the sensor (where the machine and embroidery unit connect). I'm not sure what the problem was, but it was fine after that! Just goes to show that no matter how frustrating things can be, it pays to just take a moment and start over!!
Feb 18, 2009 | Singer CE-100 Futura Computerized Sewing...
Once I set up my design card and select design, the needle moves
Hi, and welcome to FixYa. If I understand your problem, the needle goes in and out of your fabric, and the embroidery hoop moves, but the machine does not actually start embroidering your design right away....did I get it right? If have time to answer a few questions, I can give more accurate instructions.
  1. How long have you had your machine?
  2. How long have you been doing machine embroidery?
  3. Do you have a manual for your machine?
  4. Look at the back side of your design - do you see lots of bobbin thread, or hardly any?
  5. Have you taken lessons for your machine or for embroidery?
  6. When your design is finished, can you where the machine skipped stitches?
Here a couple of things you can try (if you have already):
  • Make sure you use an embroidery needle, not a universal. In most cases, you should use a size 90. Change your needle after each project. A blunt need can cause your machine to skip embroidery stitches anywhere in the design.
  • Rewind or replace your bobbin. Make sure you use bobbin thread in your bobbin when you embroider - it is thinner and gives you better tension. If pre-wound embroidery bobbins are compatible with your machine, I recommend that you try one and compare the result with designs sewn using the bobbin thread you've been using.
  • Normally, you should loosen your tension a little bit when you embroider. When you look at the back side of your embroidery, you should see more bobbin thread than embroidery thread.
I owned an embroidery business for several years, and I have six different embroidery machines of my own - so with a little more info from you, I think I can help.
Feb 03, 2009 | PfaFF Creative 7570
Singer Quantum Futura CE-200 Problem
My machine did the same thing. I had several frustrated nights ans then it just started to work. Some suggestions that I had was that there may be dust where the units connect. Not sure what I did, but it worked.
Dec 27, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
1,530 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
