Question about Hoover Vacuums
I need instructions for H30 bag and filter installation for Hoover S3332 Telios Canister vac. Where can I find the instructions. I have long since misplaced any instructions which came with the vacucum cleaner purchase
  • jrozier Dec 09, 2008
    The solution resolved the problem, and was provided in a very professional and timely manner.
  • 88 Answers
Go to hoover.com,when the page comes up click on customer service at the top then when that page comes up look on the page for product manuals and info,you will get what you need there.
Posted on Dec 06, 2008
Why does metallic cover keep blowing off when operating?
Hey there! It sounds like your vacuum may be clogged causing it to redirect the air flow which may be causing the cover to blow off. To check the vacuum for clogs disconnect the hose from the cleaner and the wand, use a broom stick to gently loosen and remove any clogs from hose. Also check the wand and the nozzle for blockages. If it is the filter cover that is coming off and there are no clogs, the tabs on the filter cover may be broken. Contact a local service center for information on replacing the filter cover. Reference part 59135033. Or you may contact Hoover Customer Service at 1-800-944-9200. Hope this helps!
Aug 27, 2014 | Hoover S3330 / S3332 Straight Suction...
The hose constantly falls out of the metal tube. Is there any remedy other than taping or glueing it in place?
the complete hose can be bought here for 20.00
http://www.bizrate.com/vacuum-accessories/oid1370892338.html
Feb 16, 2011 | Hoover S3330 / S3332 Straight Suction...
Just picked up this vacuum at a second hand store. Inside I can't figure out how to attach the bag - there doesn't seem to be anything for it to hook on to - I am wondering if a piece is missing.
I have uploaded a parts diagram for your vacuum model that you listed that your repair under, the Hoover model S3330 and S3332 below. It looks like the part diagrammed number 3, which is called the Bag Holder may be missing from your vacuum if you're not able to get the bag in. This is a part that we're able to get for you if you need to purchase it. Please just visit our website, http://www.govacuum.com, and use the contact us link if you need to order this part.
Hopefully that's all it needs, and you'll be good to go! Please feel free to request a clarification if you actually have a different model then this. The model may be found on the bottom or the back of the vacuum, and usually starts with a letter in front on Hoover models. If you found this helpful, please be so kind and rate the repair solution as helpful by clicking the thumbs up icons at the top of the page. I really hope this helped you, thanks again.
Parts Schematic For Hoover Model S3330 & S3332
Chris J.
GoVacuum
Apr 07, 2010 | Hoover S3330 / S3332 Straight Suction...
The hoover keeps switching on and off automatically.
Sounds to me like there is either a loose wiring in the pedal or mains power cord. Check that the plug is secure. Check both filters though - one behind the bag (usually square and slides out) as well as the main exhaust filter at the back between the power on and cord rewind button. I used to own many Telios models but they are known to have cheap shearing cords which can only be replaced by a Hoover repairer. Sometimes the On pedal can be affected as well particularly if it has been stamped on heavily.
Dont forget to rate, ty.
Mar 28, 2009 | Hoover S3330 / S3332 Straight Suction...
Cord rewind
A bit late for the original questioner, but perhaps this will help someone else.
There are many models of the Hoover Telios. This solution applies to the T5603 at least, but perhaps not to all models... sorry, I don't know about the others.
Anyway, this is it. The cover is held to the base by 8 screws. Two are clearly visible near the handle, two are in the bag compartment. They are easy!  The problem is finding the others, because they are concealed by the foot-operated switch plates, and you have to get those plates off without breaking them.
Basically, those plates slide off backwards (i.e. away from the handle end) but you have to release a plastic catch first.  The catch is part of the switch-plate, and is located roughly mid-way along the straight side of the plate, just by the raised bump.  You can just see the catch if you shine a torch light down the gap.  The catch is released by inserting a small screwdriver or other flat blade and levering it away from the centre-line of the machine.  If you apply gentle rearward pressure on the plate while doing this, you will soon feel when it's released.
Once the catch is released, the plate will slide off completely and the remaining four screws are revealed.  After that, it's simple!
Hope this helps someone!
Feb 23, 2008 | Hoover S3330 / S3332 Straight Suction...
My Hoover is picking dust , very poorly
The Telios has a bad design on the handle and it sounds like something has definately got stuck. Unfortunately the nature of the cheap European design means the handle can only be removed by someone who owns a vice in their garage without breaking the removal points. Alternatively find a long bamboo stick or pole to put inside the hose mount which connects normally from the main bin of the Telios (not the other way around up the handle) which has no sharp edges and push up and down vigourously to dislodge any clogged dirt which may have inadverntely got stuck either by the handle or in the hose itself.
Another thing to do is to check the suction from the Telios itself by removing the hose. If there is suction coming from the main dirt bag/bin door with the hose removed then there is no problem other than a clogged hose and handle. Hoover updated the handle and hose in 1999 and spares can be found by looking on Ebay.co.uk for cheaper prices.
Aug 12, 2007 | Hoover S3330 / S3332 Straight Suction...
Vacum
Sounds like on/off switch, but need to meter out to check.
Jul 17, 2007 | Hoover S3330 / S3332 Straight Suction...
Vacuums Logo
136 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
