Question about Samsung 18.8 Cu. Ft. Bottom-Mount Refrigerator - Black
Cleaning the black surface
Hi, I tried to clean my new Samsung black fridge with a paper towel and some glass cleaner and now there appears to be marks that I don't know how to get off of the surface. Any suggestions on what to clean the shiny black surface with to remove the marks? Thanks for the help.
  • 88 Answers
Try the mr clean magic eraser ,i have cleaned alot of different things with this and it works great.
Posted on Dec 06, 2008
When I feed copies thru top feeder a black lines appears down one side of paper
This type of problem is usually caused by something like white out or lint stuck to the scanner glass. Open the top of the scanner and clean all of the glass surfaces with window cleaner sprayed on a paper towel ( do not spray on the glass) , allow it to dry and then try to scan. Here is a link to some pictures that show what to clean.
http://www.ccl-la.com/blog/index.php/lines-on-scanned-or-copies-pages/
I hope this helps,
BuddyMc
Jul 24, 2012 | Brother DCP-7040 Laser Printer
Good morning we are staying in a house of friends who are on holiday. I would like to clean the Bosch Ceran top but I am not sure which cleaning stuff I can use. Is the use of CIF creamer allowed with a...
Harry -
I would first see if your friend has a special ceramic cleaner in his or her cleaning supplies cupboard. If you can't find a ceramic cleaner, the best thing you can do is use hot water to clean the surface. All-purpose cleaners (like Cif) can damage the ceramic glass so it's best to avoid using them.
Also, look in your friend's cleaning supplies cupboard for a metal razor scraper. Use the razor scraper to scrape off any burnt-on food or spills. Do this by holding the scraper at approximately a 30 degrees angle to the cooktop while wearing an oven mitt to protect your hands. If no scraper is available, don't resort to a knife or abrasive sponge as these could damage the ceramic glass.
When the cooking surface is cool, apply a few dabs of the ceramic cleaner (if you found it) in each burner area and work the cleaning cream over the cooktop surface with a damp paper towel. Then wipe down with water and dry with a clean paper towel.
If no ceramic glass cleaner is available, it is sufficient to wipe down with hot water and a soft sponge. Never use abrasive sponges or scouring pads on ceramic glass cooktops. Also watch out for corrosive cleaners such as over sprays, cleaners containing chlorine or ammonia and stain removers - these will just further damage the surface.
For a list of approved CERAN cleaners see here: www.schott-ceran.com
Oct 28, 2010 | Microwave Ovens
How to clean 55 inch led tv samsung I noticed a child's handprint on the screen and tried to clean with lysol mutipurpose cleaner on a paper towel then windes glass cleaner on a paper towel trying to touch...
these tvs have a thin layer of plastic over the outside of the screen. no chemicals are to be used except for the special screen cleaning solution made for lcd tvs. try purchasing one of those screen cleaning kits from your local electronics retail stores and see if the haze can be removed if not the screen is damaged and there is no fix except to replaced the screen.
Feb 01, 2010 | Samsung 56" Slim-Depth LED DLP HDTV
Black line appears on copies fed through automatic top loader
Clean the scan glass, there is lilely a spot or streak on the glass, use a good glass cleaner and soft cloth or paper towel.
Hope this is of some help.
Ed
Apr 21, 2009 | Konica Minolta DiALTA Di200 Copier
Cleaning glass cooktop
Hi, Any good glass/ceramic cooktop cleaner will do the job. Any grease spots or burned food spots can be scraped off with a razor scraper ( just keep it flat ) Use a couple of paper towels and put a dime sized drop of the cleaner on each burner and with a circular motion buff the top like you would wax a car, when cleaned up, flip the towels over and buff to a shine. I don't endorse any products but there are some that contain everything you need, cleaner , scraper, cloth like Ceramabrite. They can be found at most grocery, diy and some hardware stores. Good Luck!
Feb 06, 2009 | Neff 23 in. T1252 Electric Cooktop
How to remove burnt grease, fix lightly scratched black stovetop?
Hi, I assume we are talking about a flat glass top. First the bad news. using any abrasives will permanently scratch the glass hence the dull spot. You can however make it look a little better. Grease spots and the like can be removed with a flat razor blade scraper which needs to be held flat to avoid the corners making scratches. Use any good glass/ceramic cooktop cleaner ( which is the ONLY cleaner you should ever use ) (available in your local grocery diy store and some hardware stores). The cleaner is a thick liquid, put about a dime size drop on each burner area and use a paper towel to buff out the finish like waxing a car. Once it looks clean flip your paper towel over and shine the top to like new. Good Luck!
Jan 28, 2009 | GE 36 in. Monogram ZEU769 Electric Cooktop
I used kitchenaid cooktop cleaner but cannot remove burnt on stains. what do I use? This is a brand new cooktop-ceramic glass
make sure you are using the cleaner properly.
best way is to put it on like you would wax a car.
put on a heavy coating of cleaner and then let it dry, once it is fully dry, then use a wet towel and wipe it off, then dry with another towel and polish it to a shine. this should allow the stain to be absorbed into the cleaner and then will leave a "wax" on the surface to help prevent any future stains from happening.
if this doesnt work, then put on more cleaner and lay a wet paper towel over the stained area and cleaner. this will allow the cleaner to dry slower and should help to remove any stains.
by the way not all stains will come off the first or second cleaning.
just keep trying and the stain will come off. and if you get a spill again, wipe it off as soon as you can, even if the glass top is hot, it will help.
Jan 06, 2009 | Kitchen Ranges
Line in copies that go thru feeder
Over time the automatic document feeder (ADF) will get dirty, occasionally causing vertical black streaks or lines in scans and copies .
Manual cleaning of the ADF might be necessary. Follow the procedure below to manually clean the ADF .
You will need the following materials:
  • Soft lint-free cloths
  • Glass cleaner
if you look carefully on the left side of ADF ( top feeder ) there is an assembly which u can lift , there wud be a set of rollers if u lift that part there would be a glass strip . u are suppose to clean that strip .
While holding up the inside of the ADF, clean the glass in the location of the vertical streak with one of the cotton swabs. Try cleaning the glass first with a dry cotton swab. If that does not correct the problem, then moisten the swab with glass cleaner .
If the vertical lines or streaks still appear, go through the above cleaning process again, this time cleaning the entire surface of the ADF scanner glass.
and after this try the following steps as well .
CAUTION: Use only glass cleaner. Avoid abrasives, acetone, benzene, and carbon tetrachloride, all of which can damage the scanner glass.
Apr 19, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Samsung 18.8 Cu. Ft. Bottom-Mount Refrigerator - Black Logo
347 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
