Question about Compaq S6020WM PC Desktop
RRor meesages Somehow we started out with a AIO Software error and now we are getting plug in Manager errors, plug in interfaced failed to intialize, Jscript error, exception errors, etc. We tried rebooting the system with our disk and that failed also. Help!
    President:
  • 2,961 Answers
Plug ins' are bits of extra software that are attached to browsers and other forms of software. If you mean AOL then the software has not loaded properly and will require a re install, which is also the same problem as java script. Make sure you have th latest java installed first. http://www.java.com/en/download/index.jsp
Posted on Feb 15, 2007
Kitchenaid microwave error f6e0
1. Unplug oven or disconnect power.
2. Open the back panels and make sure the P6 and P2 connectors are fully
inserted on the appliance manager and on the lower oven user interface board.
- If they are not plugged in, plug in connectors and go to step 6.
- If they are plugged in, go to step 3.
3. Visually inspect all wires between P6 on the appliance manager and P2 on the
lower user interface.
- Make sure wires are not cut or pinched.
- If the wires appear to be intact, perform a continuity check between
P6-1 of the appliance manager and P2-1 of the user interface board.
Complete for P6-2(AM) to P2-2(UI), P6-4(AM) to P2-4(UI) and P6-5(AM) to
P2-5(UI). All the measurements made should be less than 5 ohm . If any of
these measurements exceeds 5 ohm, go to step 5.
4. Replace the appliance manager. Ensure all connectors are properly inserted.
5. Replace the wiring harness (signal). Ensure all connectors are properly inserted.
6. Replace all parts and panels before operating.
7. Plug in oven or reconnect power.
8. Observe for longer than 1 minute to determine if error has been repaired.
9. If error does not appear, initiate a bake cycle. Let the cycle run for at least
1 minute.
- If no error occurs, cancel the cycle, the problem has been repaired.
- If error occurs again, restart the troubleshooting procedure at step 1.
At step 4, replace the lower oven user interface board if appliance
manager has already been replaced.
- If both are replaced the problem has been repaired.
May 15, 2013 | Cars & Trucks
I have a microwave problem. My KitchenAid Convection/Microwave oven is showing error code "F6 E0" on the display screen. This occured after power lose and restore.
Hi Kent:
F6 E0 means that you are having a Lost Communication Error between the appliance; unfortunately this is the worst error code you can get on this model because there is no way to test for which part is definitely bad. You'll need to uninstall the oven and remove the top panel and the left side panel. make sure the wires are secure going from the interface control board to the program manager board on the left side of the oven. If it checks good, you'll need to make a guess and just replace one of the control boards because one of them is bad and you can't test to see which one is faulty.
Here is the actual tech manual instructions for that code:
PROCEDURE: Before proceeding, press OFF, OFF, START to enter Diagnostic mode and verify the error codes. Ensure AM software, UI software and EEPROM CHECKSUM versions appear on the lower text line. If AM software and EEPROM versions do not appear, UI and AM may not be communicating. Verify this for the lower oven UI and for the microwave (upper oven) UI. The lower oven UI will show the AM software version for the lower oven appliance manager, and the microwave UI will show the AM software and EEPROM versions for the microwave appliance manager.
If the lower oven UI is not displaying the AM software version, go to UI IS NOT DISPLAYING AM SOFTWARE VERSION.
If the upper oven UI is not displaying the AM software and EEPROM versions, go to UPPER OVEN UI IS NOT DISPLAYING THE AM SOFTWARE AND EEPROM VERSIONS.
If lower oven UI and microwave UI are both displaying an error, go to LOWER OVEN UI AND MICROWAVE UI ARE BOTH DISPLAYING AN ERROR.
UI IS NOT DISPLAYING AM SOFTWARE VERSION:
A. Unplug oven or disconnect power.
B. Open the back panels and make sure the P6 and P2 connectors are fully inserted on the appliance manager and on the lower oven user interface board.
- If they are not plugged in, plug in connectors and go to step F.
- If they are plugged in, go to step C.
C. Visually inspect all wires between P6 on the appliance manager and P2 on the lower user interface.
- If the wires appear to be intact, perform a continuity check between P6-1 of the appliance manager and P2-1 of the user interface board. Complete for P6-2(AM) to P2-2(UI), P6-4(AM) to P2-4(UI) and P6-5(AM) to P2-5(UI). All the measurements made should be less than 5 ohms. If any of these measurements exceeds 5 omhs, go to step E.
D. Replace the appliance manager. Ensure all connectors are properly inserted.
E. Replace the wiring harness (signal). Ensure all connectors are properly inserted.
F. Replace all parts and panels before operating.
G. Plug in oven or reconnect power.
H. Observe for longer than 1 minute to determine if error has been repaired.
I. If error does not appear, initiate a bake cycle. Let the cycle run for at least 1 minute.
- If error occurs again, restart the troubleshooting procedure at step A.
At step D, replace the lower oven user interface board if appliance manager has already been replaced.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Dec 10, 2011 | KitchenAid Washing Machines
Shortly after end of 1 year warranty, KEMS378SSS04 began displaying F6E0 Lost Communication on lower over UI (not on the microwave). Turning power off/on (multiple times required sometimes) fixes the...
Below is the complete instruction sheet.
You are having a communication error between the appliance. Here is the actual tech manual instructions for that code:
manager.
EEPROM VERSIONS.
P2-5(UI). All the measurements made should be less than 5 ?. If any of
these measurements exceeds 5 ?, go to step E.
1 minute.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 22, 2011 | Ovens
What is error #2200
The 2200 error message indicates a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message.
Printer Reset
1 Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: contact Dell.
No: Continue to step 3.
3 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, contact Dell.
No: Install the color cartridge. If the printer fails, contact Dell. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Mar 23, 2010 | Dell 962 Photo All-In-One InkJet Printer
Error 2200
Power off the AIO and remove the power supply(Power Cord) from the back of the unit.
IF THE ERROR MESSAGE DID NOT COME BACK....
INSERT THE COLOR CARTRIDGE ONLY,
Close the top cover, reinsert the power supply, and power on the AIO.
IF THE ERROR MESSAGE RETURNS.. GET A DIFFERENT COLOR CARTRIDGE AND REPEAT THIS PROCESS....
IF THE ERROR MESSAGE IS GONE,
Power down as before, do all the same to get the carrier to the middle of the unit and RE-INSTALL THE BLACK CARTRIDGE.
Power back up as in previous steps...
If after trying all of the above and the error message does not go away, you unit would need serviced (if it's under warranty, it's worth it; if not, you might want to replace it.)
Feb 06, 2010 | Lexmark P6350 All-In-One InkJet Printer
I get the error 2200 message everytime I try to send a fax
Hello there:
this is a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message2.gif.
Printer Reset
NOTE: The embedded links in the table lead to specific troubleshooting documents.
StepAction1
No: Attempt a test scan. If the error message does not reappear, the error is resolved.2
Power off the AIO and remove the power supply from the back of theunit. Open the scanner cover. Check the scanner glass for cracks andthe scanner casing for cracks. Close the scanner lid. Open the topcover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.3
Power off the AIO and remove the power supply from the back of theunit. Open the top cover of the AIO. Using the carrier belt, move thecartridge carrier to the middle of the unit. Insert the colorcartridge, close the top cover, reinsert the power supply, and power onthe AIO.
Yes: Repeat step 3 with another color cartridge. If the printer2.gif fails again, continue to step 4.
No: Repeat step 3and install the black/photo cartridge. If both cartridges areinstalled, attempt a test scan. If the error message does not reappear,the error is resolved.4
Power off the AIO and remove the power supply from the back of theunit. Open the top cover of the AIO. Using the carrier belt, move thecartridge carrier to the middle of the unit. Remove the color cartridgeand insert the black/photo cartridge. Then close the top cover,reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark.If the error message does not appear with both cartridges installed,attempt a test scan. If the error message does not reappear, the erroris resolved.
Nov 10, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I have a kodak esp9 on win xp wireless connection. Constantly get the 1-2010 error code and kodak aio home center will not open and the printer will not connect any solutions?
  1. From your computer, access Device Manager.
    • For WINDOWS XP OS:
    • Right-click My Computer, then select Properties.
      • Select the Hardware tab, then Device Manager.
  2. Select View > Show hidden devices.
  3. Select Printers.
  4. Select Action > Uninstall.
  5. Select Action > Scan for hardware changes.
  6. Double-click the KODAK AiO Home Center icon. If the error occurs again, go to the next step.
  7. Set administrator rights for the Home Center application:
        • Right-click on the Home Center icon.
        • Click Properties.
        • Click the Compatibility tab.
        • Clear all the check boxes.
        • Click Apply and OK.
    1. Double-click the KODAK AiO Home Center icon. If the error occurs again, go to the next step.
      IMPORTANT: In the next step, before you install the Home Center Software, make sure you disconnect the USB cable. Then, connect the USB cable when the software installation instructions tell you to do so.
    2. Upgrade the software and firmware for your printer:
Jul 17, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Can not get the camera to intialize, it say initialzation error
Try uninstalling the USB devices in the Device Manager. Removing all of them will not hurt your computer. Unplug all of your USB devices and restart. The computer will load fresh drivers for usb. It would be a good idea to uninstall the camera software as well before doing this, and re-installing it after your computer has fresh USB drivers. If that does not work, take it back.
Jun 30, 2009 | Microsoft Life Cam Vx-5000 Webcam
Error 2200 lexmark 6250.
hey ,
Follow the steps :-
Step Action
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved...
Nov 15, 2008 | Lexmark X7170 All-In-One InkJet Printer
What does error 2200 mean
Printer Reset
NOTE: The embedded links in the table lead to specific troubleshooting documents.Step Action
Mar 07, 2008 | Lexmark P4350 All-In-One InkJet Printer
Compaq S6020WM PC Desktop Logo
135 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
