Question about Air Tools & Compressors
28 gallon compressor....answer to your question about my problem
You asked if the air in the tank was ok. The answer is yes. It registers up over 125. However there is no air to run the tool. The tool side gauge shows no pressure. Turning the knob for more or less tool pressure gives me no different result. Removed the quick connect...no air comes out. Must have a valve stuck somewhere.
  • 65 Answers
Your regulator internal filter could well be blocked ,isuggest that you drain the tank fully and remove you regulator,check that tank is clear of rust or scale if all is clear then strip and clean your regulator
assembly or replace with new,problem should be gone all the best
this might be a silly question but the needle on your pressure guage couldnt be stuck?,have you drained your reciever?
Posted on Dec 08, 2008
I have a older model RMM 3 GALLON Air Compressor I need a pressure control switch do you happen to know where I could get one at and how much
these days you can buy universal 95 psi factory pre set
pressure switches from ebay US $28 up
3 gal tanks should handle that ok with its safety valve set
if lucky you may come across an adjustable pressure switch
Oct 27, 2016 | Air Tools & Compressors
Have a 6.25hp , 28 gallon stand up. It fell over and bent some of the regulator parts. Got that straight but when you plug it in it does not start up. Un plug and try again...it seams like something in the...
It sounds like the problem that you are having is with the unloader if there is only 30 to 40 pounds of air pressure in the tank it would probably start,but if the pressure is around 90 pounds it would be starting underload, the unloader should exhaust the air from the compressor so it does not have to start underload the unloader does two things it works the magnetic switch to turn the compressor on at probably around 90 pounds and off at about 120 it usually uses 120 V to work your magnetic breaker that uses 240 V I hope this helps.
Feb 19, 2011 | Campbell Hausfeld 28 - Gallon Air...
Using a nail gun and nail goes in wood too deeply
lower pressure leaving tank into gun by turning pressure regulating knob if your compressor has one if it doesnt you may need to get one from lowes or hd.30 bucks roughly.
Apr 03, 2010 | Campbell Hausfeld 28 - Gallon Air...
Does not put enough air in tank
You either have a faulty or out of adjustment regulator.
Mike
Jan 06, 2009 | Campbell Hausfeld 28 - Gallon Air...
No air pressure past 60PSI on a 125PSI Campbell Hausfield WL61110
Your comperssor is oilless type and suffers from short cylinder / piston life. When the compressor no longer reaches cycle pressure the cylinder / piston should be replaced. These parts are available at www.chpower.com I believe that the part number is wl210300aj. Not expensive, enjoy.
Dec 13, 2008 | Campbell Hausfeld 26 - Gallon Air...
Tool side has no pressure
if there is sufficient air in the tank the regulator valve is either set to low or is stuck. if its stuck ur better off to buy a new one and replace the one u have.
Dec 04, 2008 | Campbell Hausfeld 28 - Gallon Air...
Air Tools & Compressors Logo
91 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
