Question about Garmin eTrex Legend GPS Receiver
Screen appears to freeze up
Both units, Etrex Legend and Etrex Venture. Never dropped. Minnesota climate. Used for hunting. Good and clean contacts for batteries. Batteries new. Unit will shut off while in use. Screen will fade out partially and verticle lines will appear across screen. At times, will not be able to search for satallites. Have a clear visibility to sky. Have never downloaded updates.
  • 3 more comments
  • Anonymous Dec 07, 2008
    I have the same problem. Device starts normally, within minutes the scren goes gray with a vertical line on the right or the letf. It is not responsive to any commands after that.
  • race787 Dec 09, 2008
    Same problem since brand new. Starts up normally. Can enter information but just turns off . Thin, blue, verticle line on left hand side appears. If I open the battery compartment remove either battery (new) it goes back on. Can't use it. Thought it was me or bad batteries. NOT this time.
  • mcl3 Dec 10, 2008
    We have several Etrex Legends we use at work. All of them have the same problem now. They will come on for approx. 5 minutes and the screen goes blank with a thin vertical line down the center.
  • zzfwtp Dec 12, 2008
    After using my legend for more than (1) minute.. I lose the screen and get a single line down the middle.
  • Anonymous Dec 12, 2008
    I also have the problem, verticle line
  • Garmin Master
  • 638 Answers
Try updating the unit software. A new satellite was launched this year and has been causing problems. The updates from Garmin fix it. Disable the WAAS in the meantime and see if that solves the problem in the meantime.
Posted on Dec 13, 2008
Garmin etrex 12 channel gps, screen very dim contrast with new batteries
For the Etrex Legend you can click the page (top right hand) button till you get the main menu, select setup then display. Point the click stick down until the bar on the left is highlighted. You can then move the bar up and down until you get the contrast you want. You could first try clicking the square near the top right and selecting restore defaults, but if the default contrast is not to your liking then you can change it using the bar.
It is probably similar on related models such as the Venture or Vista, if in doubt check your manual.
Dec 30, 2010 | Garmin eTrex Legend GPS Receiver
POWER UP
Make sure that your battery contacts are clean, and you are using fresh batteries. I recommend using regular alkaline cells in the Garmin etrex legend pictured(I own two of these).
If the device still doesn't power up, then it is a hardware failure, probably not worth the cost of repair.
Jul 30, 2010 | Garmin eTrex Venture GPS Receiver
My etrex Venture HC will not power up after changing batteries. Unit has been "on the shelf" for some time. HELP
I can only suggest that you insure that you have fresh batteries, and that they are installed properly. If you had batteries sitting in it, and they leaked, you might want to examine the contacts and make sure they are clean, and not corroded.
The Etrex are sealed and water-tight. Opening the unit will make them no longer able to resist water as well, and if there is anything wrong internally, it should be sent back for factory repair.
Nov 06, 2009 | Garmin eTrex Venture HC GPS Receiver
Unit won't Acquire Sattelites
the chip set in it is damaged.you want to go to a servicing center to repair it.
Jul 19, 2009 | Garmin eTrex Legend C GPS by
My garmin etrex legend Cx wasn't used for a few months and now won't aquire satellites. Batteries have been changed to no avail.
Go to the Garmin.com website and download updated drivers/software for the unit. Make sure the drivers are for your specific unit as they are all different.
Jul 04, 2009 | Garmin eTrex Legend GPS Receiver
Etrex legend has stopped picking up satalites.
I have had this problem occasionally and if you use Restore Defaults it appears to fix it. Using the front button go to Main Menu, Setup, System, move left and press the button button. Before I did this I just used to leave it a few weeks and it would suddenly be working again.
HTH
Peter
Mar 04, 2009 | Garmin eTrex Legend Cx GPS Receiver
My etrex legend is also inoperative...
Inoperative as it won't turn on, or is there a line through the screen, or it won't recognize satellites?? We need a bit more information about 'inoperative'.
Have you downloaded and installed the latest software from the Garmin site? That might be a start.
Oct 25, 2008 | Garmin eTrex Legend GPS Receiver
Will not turn on
I contacted Garmin and they had me remove the microchip inside and see if that would fix the problem. It did not. So they instructed me to send it back in for repair. They gave me a return number and then ended up replacing the unit with a new one. My unit was under a year old so it was no charge.
Jun 15, 2008 | Garmin eTrex Legend Cx GPS Receiver
Garmin eTrex Legend GPS Receiver Logo
201 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
