Question about Acer TravelMate 200T Notebook
Acer 200t Hard Drive adapter
I bought a travelmate 200t with out a hard drive. I need to know if I need a special connector to install a new hard drive?
  • 52 Answers
No, all the notbook hard drive are the same.
Posted on Dec 06, 2008
Hard Drive exchange older sata hard drive {acer brought 3 years ego}and newer system /deferent hard drive
All adapters and cables are available from a computer store or cheaply through fleabay.
Jun 26, 2017 | Acer Aspire One AOA150-1784 Netbook
Hi there , i have an acer travelmate 6592 laptop , the original 80 gig hard drive crashed , and i dont have the recovery disc , the hidden partition wont re install either , i have bought a new 320 gig...
You cannot get the full 320Gb capacity because the BIOS can only support a maximum of 127Gb.
You only hope is a BIOS firmware upgrade that can support 320Gb. Check out the Acer WEB site to see if a BIOS upgrade will solve your problem.
OTHERWISE
Install a 127Gb hard drive in your Acer and put the 320Gb hard drive in an USB hard drive adapter case and use it as an external USB hard drive because it is not affected by the BIOS limitation.
Jun 13, 2011 | Computers & Internet
What hard drive is compatable with an acer laptop travelmate 2200 series model lw80?
Any ATA/IDE 2.5 inch hard drive will do for your laptop. Unfortunately the ATA models have been replaced with SATA hard drives, so it will be difficult to get a new hard drive. Also, expect to pay more per-gigabyte for the old ATA models in comparison to the standard SATA drives.
Jan 19, 2011 | Acer Travelmate 2200 Notebook
Acer TravelMate 8200 recovery and system disks
Your hard drive has a hidden partition that contains the original factory OS and program stored for rescue and recovery.
1 Boot to Windows.
2 Press <Alt> + <F10> to open the Acer eRecovery Management utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery Management window, select Recovery actions and
click Next.
5 In the Recovery settings window, select Reinstall applications/drivers and
click Next.
6 Select the desired driver/application and follow the instructions on screen
to re-install.
Dec 12, 2009 | Acer TravelMate 8200 Notebook
Is it possible to restore data from a dead SATA 120Gb Hard Drive by myself? what tools do I need? From the sounds of the drive, I guess it has mechanical failure. Any cheaper places or ways to restore...
try puting the hard drive in the frezer for 2 to 3 hr and you might be able to get the info off the drive hook it up as a slave hard drive. you should have the restor disk for the new drive, you can go to acer on line to get the drivers you need. hope thats helps. bobg22
Nov 12, 2009 | Acer TravelMate 8200 Notebook
Bios not find hard disk
If the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
1st. Reseat the hard drive and see if the laptop boots up.
2nd. Go into the BIOS configuration and see if the BIOS detects the hard drive.
3rd. If the BIOS can't detect the hard disk, the remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer detects this drive as an external disk drive and you can see the contents of the hard drive, then the hard drive is OK and the fault is in the laptop.
4th. If the hard drive cannot be detected then the hard drive is faulty, you need to replace the faulty hard drive in your laptop and install Windows to get an operating laptop again.
May 24, 2009 | Acer TravelMate 2303LCi Notebook
Startup of laptop
This error means the operating system on the hard disk couldn't load due to possible faulty hard drive or disk controller. The fault could also mean the hard drive needs reseating to make proper connection. Reseat the hard drive and if you still get this error, then you need to determine if the disk controller is faulty.
To do this, remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer see this hard drive as an external drive and you can also see the contents of the drive, then the hard drive is OK and the fault is a faulty disk controller. If the computer cannot detect the hard drive then the hard drive is faulty.
Then get a new hard drive insert it into youe laptop and install Windows to get your laptop operational.
Apr 08, 2009 | Acer TravelMate 281LC Notebook
Locked travelmate 200t
New PC's do not come password protected. Unless you bought it off the shelf at a commercial retail store that does have them password protected. If that is the case, you need to check with them.
Aug 16, 2007 | Acer TravelMate 200T Notebook
Acer TravelMate 200T Notebook Logo
130 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
