I have a fahrenheat electric baseboard heater and it wont work. It barely gets warm. I replaced the thermostat thinking that might be the problem but it still doesnt help. What is wrong with it? We just moved in and there is no manual.
  • 85 Answers
1 888 230 2323 ace hardware superstore. They have parts for your heater, and trouble shoot.
Posted on Dec 06, 2008
Bought a Fahrenheat 5' baseboard heater and a single pole thermostat to replace an old heater. What's the difference between a single and double pole thermostat? Which should I use? I have a 240v line...
Here is a link to the wiring instructions, which has detailed pictures and instructions. This should make it a lot easier. http://www.marleymep.com/en/multimedia-library/pdf/fahrenheat-pdf/products/f2500-series/F2500wiring.pdf
Feb 14, 2011 | Fahrenheat F2545 Electric Baseboard Heater
I'm replacing a non-hydronic electric baseboard heating unit with a Fahrenheat hydronic one. My old unit was 240v using 2 conductors plus bare ground wire. The fahrenheat (PLF series) unit's instructions...
Hello. The red and the black are the hot wires. Therefore, connect one of your conductors to the red and the other conductor to the black. Use wirenuts. The bare ground wire should be solidly attached to the new unit's green wire using a wire nut.
Regards, Joe
PS: please rate my answer. Thank you.
Jan 06, 2010 | Fahrenheat Electric Hydronic Baseboard...
Electric baseboard heater hums while running
is a 60 cycle hum, resonating with the power. check screws that mount it nothing to really worry about
Dec 31, 2008 | Fahrenheat Built-In Baseboard Thermostat...
When my f2548 heater comes on the wall gets too hot touch
This sounds like a short circut! Avoid useing untill it can be looked at!
Dec 15, 2008 | Fahrenheat Electric Convector Baseboard...
Do the Fahrenheat Hydronic Baseboard heaters work well?
No i would not recomend this model ! if you can stay away from baseboard heat alltogether it is an energy waster!,somthing that moves the air would be a much better choise
Dec 10, 2008 | Fahrenheat Built-In Baseboard Thermostat...
Thermostat for baseboard heaters in series
The heaters need to be wired in parallel so they all receive the same voltage. If wired in series the first heater will receive proper voltage and the next heater will receive reduced voltage (Voltage Drop across first heater) and so on (Ohm's Law). You may want to have an electrician help you so you don't get electrocuted or burn up your heaters or your house. Hope this helps!
Dec 03, 2008 | Fahrenheat Electric Convector Baseboard...
How do I wire up a F2544 baseboard heater with a single pole themostat
It sounds like you are not getting the correct voltage for the heating element. If you wired a single pole thermostat, and its a 220v unit, then it will not get hot enough, like you are saying. If its a 220 heater, you need a 2p2t thermostat. The parts supplier will know what this means.
Mar 17, 2008 | Fahrenheat Electric Convector Baseboard...
You need a meter, it will be hard without this! If you have 220v in the wall, then think of it like this; each wire is 120v. Test to each other, you get 220v. The thermostat is a double pole, you said. So think of it like this, its an adjustable temperature controlled switch that lets electricity through at the temp. you set it at. If you have 120v from one wire connected to one end of the element, and the other 120v connected to the other end of the element, then it will work. DO NOT CONNECT THE 120V TOGETHER. IT MUST GO THROUGH THE ELEMENT FIRST. The thermostat should be between the power from the wall and the element, to control the temperature.
Jan 05, 2008 | Fahrenheat FBE15002 Baseboard Heater
How do I wire up my fahrenheat F25408 baseboar heater?
Baseboard heaters are easy to hitch up. You can have a wall mounted thermostat or an integral thermostat. The diagram I have is for the integral thermostat. Follow the diagram and it should work.
Nov 28, 2007 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
80 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
