Question about KitchenAid Architect Series KEBC208KSS Electric Double Oven
I need to calibrate my kitchenaid double oven model kebc208kss.
How do I do this? It is off by more than 15 degrees
4 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: Oven will not achieve setpoint temperature.
You may not need anything. Most people test their oven with a dial type oven thermometer. They are slow to react and often not very accurate. When I test an oven or install a new thermostat, I use a digital thermometer with a remote temperature probe, hanging from the center of the oven, which shows the temp in tenths of a degree. I let the oven cycle on and off at least three times, then take the high and lower readings on the next cycle and average that out to see what the actual oven temp is. Most of the time, if there is a dial type thermometer in the oven it is very slow to react. After 3 to 5 cycles, they often show close to what the actual oven temp is, but the only way to know for sure is to use the more accurate digital thermometer. Most ranges with digital displays can be adjusted + or - about 35 degrees. Check your users manual for this info, but don't mess with it until you have checked the oven with a digital thermometer! Please don't bother rating this solution, as anything but a Fix-Ya drops my score. Thanks.
Posted on Jan 08, 2009
kachbibi1
  • 979 Answers
SOURCE: Maytag oven needs temp calibration
Take your temp knob off and look in the center of the stem and you should find a small set screw. Using a small precision screwdriver, turn the screw until you see the light come on. (You won't have to turn it far.) Turn it a little at a time, maybe a 1/16 of a turn. Leave your thermometer in the oven with the door closed and at or near the temp probe that is in the oven. This way, you are getting a true reading.
Posted on Feb 15, 2009
  • 6 Answers
SOURCE: KitchenAid Superba double oven: can't set clock.
If you turn the center knob (marked 'time') to the right, it sets the timer; but if you turn it sufficiently far to the left, it goes into clock set mode. When you get to the correct time, press start.
Posted on Jun 30, 2009
My oven turned off by itself
Check power connections may have loose return ground loose beaker in fuse box from home or over heat issue
Jun 30, 2014 | KitchenAid Architect Series KEBC208KSS...
Replacing inner door glass kitchenaid kebc208ss
Click HERE for the service manual and refer page no. 21-22
This will solve your problem.
Goodluck,
Please don't forget to rate me as fixya..
Feb 16, 2008 | KitchenAid Architect Series KEBC208KSS...
We have had nothing but problems with this oven - what a lemon!!!! We have had the computer replaced 5 times in the short time we have had this. Now, our top oven is not heating. The repair man says we...
Absolutly could of course be the EOC (electronic oven control) since it does control both the upper and lower over. Sorry for your luck but just because a part has a high failure rate that manufacture isnt required ti issue a recall as long as thier isnt a saftey issue such as potential fire or what have ye
Jul 23, 2011 | KitchenAid Architect Series KEBC208KSS...
Kitchenaid double oven shut down!
The problem is they overheat because hot air is drawn in by the blower and overheats the outer chamber of the oven where the thermo fuse link is. The one or two fuse links are blown simple replacement but have to remove oven (two person job) remove outer shell and find it (them) in the back of the oven. Also the fuse link wire going into the main processor is probably blown.
Sep 06, 2007 | KitchenAid Architect Series KEBC208KSS...
Rattleing noise when either oven is turned on
It could be a loose screw that has fallen from inside your back panel.... Be sure to turn off all power sorces before you access the panel to avoid electrical shock!
Dec 27, 2006 | KitchenAid Architect Series KEBC208KSS...
KitchenAid Architect Series KEBC208KSS Electric Double Oven Logo
278 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
