Home | Sony | HDR-HC1 Mini DV Digital Camcorder | HDR-HC1 power keeps cyc...
Sony HDR-HC1 Mini DV Digital Camcorder
Problem for Sony HDR-HC1 Mini DV Digital Camcorder
HDR-HC1 power keeps cycling
By edepaolis on Mar 07, 2007
When I turn on my Sony HDR-HC1 it continuously cycles on and off. If I switch it to photo mode (camera mode not video mode) and then switch it back to video mode it sometimes stops cycling. I tried reseting the unit with the reset button and that didn't work either.
Comments:
Dec 30, 2007
- I was able to get the camera working properly by reseting it. I think the cause was using an off brand battery. The rest worked.
I used to be able to use the iLink port successfully then it just stopped working one day. Still trying to figure that issue out.
Same Problem
Mar 12, 2009
-   I also have a dead HDR-HC1.   Won't power on ... LCD panel flashes for a split second when the power switch is put in Camera or VCR mode.
DSJRAPPER:   how are you getting $500 from Sony towards a new camera?  Is this some kind of program they have?   I'd love to pick up an FX7, or FX1000 to replace my HC1.    $500 from Sony would definitely help towards that.
Thanks for any & all info -  Take it easy! Chip-   chipbos
Mar 07, 2009
-   help i have the same problem but with the cycling but it now wont turn on or charge, whats happend? and what should i do?
-   Threll91
Dec 22, 2008
-   same problem i link stopped working power turns on and off, and sony wants $500 to fix it, the camera is great and all. I just wanted to tell you you are not alone, I thought the problem may be caused by hotswapping the I link port.. All I know is sony is giving me $500 towards a new camera, even though I am out of warranty! maybe someone knows why this happens!-   dsjrapper
Best Solution
posted on Dec 29, 2007
Helpful)
marxtone
Rank: Apprentice
Rating: 85%, 1 votes
I had this exact problem, and the cycling would stop after about 30 sec. and then function properly. I believe a circuit was confused, mainly because I used an older battery and let it run out till the batt was dead - accidently - and when I put in a fresh batt, it no longer cycled and works perfectly to this day.
Now if I can get my computer to recognize the camera via firewire, I'd be golden.
Was this helpful?
Yes
No
Popular Solutions for Sony HDR-HC1 Mini DV Digital
Questions and Unsolved Problems for Sony HDR-HC1 Mini DV Digital
Do you recommend Sony HDR-HC1 Mini DV Digital Camcorder?
Answer
Answer
my cannon h8 video camera has flickering pictures when I try to play them on my t.v.
Answer
the lcd panel on my hdr hc1 is not working properly. I am unable to access the menu and the frames... (More)
Answer
circuit board location on sony HDR-HC1 camcorder
Answer
Sorry, people speak spanish? Tengo el mismo modelo de camara en versión pal y el mismo... (More)
Answer
My camera took a hard fall. When in standyby everything works nomally and as it should, zoom, focus,... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony HDR-HC1 Mini DV Digital...:
Top Camcorder Experts
Rank: Guru Guru
Solutions: 589
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Camcorder Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
