Question about Saeco VIA Venezia
Can't Prime Water Circuit
The machine says to have the steamer turned counter clockwise while the machine is on in order to prime the water circuit. I've never used my machine before, have done everything it says, and no water will come out. How long should this take? And what could I be doing wrong?
  • Anonymous Dec 26, 2008
    I have a brand new Saeco Talea touch. Only very limited water output. It takes in coffee as it shall but there is a problem. It says prime water circuit. I do not know what is wrong.
  • Anonymous Apr 28, 2009
    Can't get a stream of water to come out while "priming water circuit."  Tried advice below...still nothing.
Hi You need to switch Steam ON so it heats up and then turn Steam button OFF (no light) and then turn steamer knob counter clockwise you will hear the pump start up and then water will stream out. This is when it's primed. Turn steamer clock wise to close. You must do this everytime you use the steamer.
Posted on Dec 12, 2008
I had this same issue with my brand new Talea Touch. The first time I plugged it in and it was stuck on the "Prime Water Circuit" screen. I tried turning it on and off a few times and I noticed that the "replace brew group" screen showed up for a split second so I turned off the machine, pulled out the bre group, replaced the brew group and turned on the machine. It worked perfectly. The pump is pretty loud and starts immediately, so it is pretty obvious when it is working.
Also, when I brewed the first cup the water came out almost clear. I dumped it out and brewed again and got a perfect cup of coffee! Mmmmm.
- RareBlueMonkey
Posted on Jan 03, 2009
What to do when prime water curcuit comes on
When prime water circuit comes on turn on the steam/water valve may need to select hot water the machine will run water until primed
Nov 16, 2014 | Saeco Talea Touch 14-Cup Coffee Maker
Tip
Saeco, Gaggia, Spidem VENTILATE, Prime what is mean, how to perfrom
Ventilate or priming or else loading all means the filling the machine system full with water, like pump, piping and boiler. This must perform first time of starting up the machine.
It will also appear if the water system in not full of water especially after the steam preparation some steam can be blocked in the system and the machine recognized it by luck in the pressure.
Another reason that ventilate it appears on screen is because air have been insert and blocked in the water system usually from water filter or water softener located in water tank.
So here how you Ventilate or Priming or loading:
Place a container beneath the steam tube.
Turn the knob counter clockwise to start loading the circuit.
Wait until a steady stream of water flows out from the nozzle.
Turn the knob clockwise
to terminate the circuit loading process.
Remove the container. The machine is warming
up; lights are flashing.
Note: You must load the circuit before starting up
the machine for the first time, if it has been inoperative
for a lengthy period or if the water tank has
been completely emptied. The circuit must also be
loaded each time the light flashes
on Aug 28, 2010 | Coffee Makers & Espresso Machines
What does Prime water circuit mean for a Gaggia Platinum Vision?
You need to draw hot water from the machine in order to prime the machine after the masage leave you can us the machine normaly. If the masage apears very often then you will need to descale the machine.
Mar 04, 2012 | Krups Coffee Makers & Espresso Machines
What is message "prime water circuit" not in
Fill the water tract with the water. For example - swith the steamer to hot water dispence and run water for several seconds (untill it goes smoothly).
Mar 18, 2011 | Saeco Talea Touch 14-Cup Coffee Maker
Hello The lights on the front of the machine wont stop flashing so I can't press the cup symbols to make coffee. The hot water is coming out though through the steamer spout. Thanks!
Circuit Priming
When the machine operates for the first time and when
all the water has been dispensed, the machine circuit
needs priming. In this case, the 4 buttons of the control
panel will flash at the same time.
• Press the ON/OFF button . The 4 buttons will
flash.
• Place a container under the cappuccinatore.
• Open the "hot water/steam" knob by turning
it anticlockwise.
• Press the hot water button.
• Wait for water dispensing to stop.
• Close the "hot water/steam" knob by turning it
clockwise. Remove the container.
When the first priming ends, the warming up
starts. Before brewing coffee, water and steam,
please wait for lights 15 and 16 to be permanently on.
The machine is now ready to brew coffee and dispense
steam. Please see related sections for operating details.
Note: if priming is not completed, the 4 buttons
will keep on fl ashing. The machine cannot be
used.
Jan 14, 2011 | Saeco Nina Bar Espresso Machine
Gaggia trevi exclusive - one of the old black machines. We've not used it for a while and have just switched it on, it grinds the beans but no water comes out of the spouts or steamer. Chrissie
Hi
This might work. Its for a Saeco Vienna.
First off, don't leave the machine on for a long time if you don't have any water flow.
If its been setting for a long time you might have a stuck check valve in the pump.
The best way to prime the pump is to put in test mode.
Turn the machine off. Push and hold the 2 right buttons at the same time. While holding them down, turn the machine on.
Release the buttons and turn the dial counter clockwise till it stops.
This will keep the machine from heating.
If you push the center button the pump will activate.
Open the steam knob.
If you don't have your old priming pump, you can use a bulb aspirator.
Remove the water tank and fill the bulb with water. Insert the bulb into the hole on top of the machine where the tank was.
Push and hold the center button and squeeze the bulb to force water into the hole. Sometime it takes 2 people to prime the machine easier.
If the bulb squeezes easily and water flows, you did it. If not keep trying. You may have to remove the pump and blow some air through the small end (intake side) with an air hose.
Nov 28, 2009 | Coffee Makers & Espresso Machines
The machine lights don't turn on
sounds like you need to prime the machine. check the manual for those instructions. if (like us) nothing happens, then read on:
johnshami had this solution on another post, and it worked for us when the manual's instructions to "prime" the machine resulted in no water leaving the tank to enter the machine:
  1. make sure the water in the tank is stone cold -- which is a no brainer since it will not heat h2o unless it's primed.
  2. take off steamer wand cover, turn the steamer knob clockwise till pump starts.
  3. then s*ck (as you would on a straw, with your lips sealed around the end of the steamer wand) the tip of the end of the metal tip hard until pump stops
  4. may need to do it a couple of times. yes this seems crazy, but it works! you are flushing out the vapor lock in the pump.
Sep 05, 2009 | Saeco Starbucks Sirena Espresso Machine
The blue light is blinking, the water tank is full, but the water isn't heating up at all. should we return it? Or is there something that we missed? We followed the instructions and are getting no where.
Aug 09, 2009 | Saeco Starbucks Sirena Espresso Machine
Blinking blue light won't shut off even when the water is full
you need to prime the machine. if the instructions for priming don't work (as they didn't for us), then try this:
Jul 14, 2009 | Saeco Starbucks Sirena Espresso Machine
Saeco VIA Venezia Logo
2,567 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
eyecam
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
