Question about Honeywell Programmable Thermostat Heater
Furnace kicks on every 15 mins
I have a Honeywell round manual t-stat and my furnace kicks on ,runs 5 mins, kicks off and comes back on again in about 10 mins. Is there a control on the t-stat that I can regulate. The furnace is gas forced air and is in a cold attic.
  • HANK MCNEIL May 11, 2010
    yes, there is an antisipator adjustment in the tstat. What brand and model furnace do you have?
  • dwkcool May 11, 2010
    on the t-stat cross the red and white wire if the furnace runs see how long if it does the same thing it is in the furnace
  • 70 Answers
Fuanace may be oversized and is short cycling it heats up house to fast it is better when they run longer
Posted on Oct 04, 2009
  • Honeywell Master
  • 2,902 Answers
HI it could just be your thermosat try cleaning out could be dusty or try repacing it
Posted on Feb 02, 2010
  • 308 Answers
Older style thermostats have a heat anticipator, which may be set incorrectly. The purpose of the heat anticipator "lie" to the thermostat, taking care of overshoot and lag. The heat anticipator should be set to the amperage listed on your gas valve
Posted on Jun 18, 2009
I have installed a new Honeywell CT87 non-mercury manual thermostat. It runs but the the furnace turns off the room temperature alway at or beloe the furnace setting so the furnace turns back on again and...
Hi, these mechanical thermostats have what is called a heat antcipator on them. If you remove the cover you will see in increments or numbers such as 1.0, o.1, .2, .3, .4 or o.1, 2, 3, 4, . The stat and main gas valve work together and have to draw the same amount of amps to cycle the unit properly. This stat will have a copper arrow pointing at a number. A good place to start is to set it at .4. If the unit does not cycle right, set it at 1.0 and go from there until it cycles. Let it go through several full cycles during each time you adjust it until it is correct. These are good dependable stats as I have many on my service truck. If it doesn't take care of the problem, take it back and return it for one that is not faulty which happens often. Best of luck to you.
Ps, the small manual that comes with a new stat has that information on it, anticipator settings.
Shastalaker7
A/C, & Heating Contractor
Mar 11, 2011 | Honeywell CT87B ROUND HEATING&COOLING...
My honeywell thermostat is asking for heat but the furnace won't turn on.
The first thing i would do is to make sure the t-stat is good.One easy way to do this is to remove stat cover then remove the screws that hold it to the wall. Disconnect t-stat wires making sure you note location. There should be a red and white wire for heat so put these two together and if your furnace comes on then the stat needs replaced. If it does not you need to check further to make sure you have power to your furnace.If the furnace does come on with these two wires together the furnace will run non stop. Hope this helps you. Thank you
Jan 12, 2011 | Honeywell Programmable Thermostat Heater
We have a fairly new furnace. I have the temp set at 65 the furnace only runs for 3 min at a time and comes on every 5 min. This sounds extreme to me?
It depends on the differential that you have programmed into the thermostat. In most of them you can set the temperature you want the thermostat to activate, and then you set the run differential such as three degrees below 65. In other words, the thermostat will activate at 62, and drive the temperature up to 65, cut off and wait for the temperature to drop to 62, where it cuts on again. see:
http://yourhome.honeywell.com/home/Products/Thermostats/
Check http://homeappliance.manualsonline.com/manuals/mfg/honeywell/8000.html to see if you can find the manual if you have lost yours.
Dec 07, 2010 | Honeywell Heat/Cool Thermostat
My new honeywell T87N/T87K round is not turning on my heater
check for voltage then check connections sometimes the wire breaks and no power gets to the stat
Jan 06, 2010 | Honeywell Programmable Thermostat Heater
My honeywell t-stat reaches current temp setting and furnace kicks off...but within 1 minute the t-stat drops 1 degree and the freakin furnace kicks on! This can't be right as it has never happened with...
Your differential is set to close you can go into tstat and change differential setting. Your install manual for your thermostat will tell you how you can set 1.2.3 degrees differential
Dec 13, 2009 | Honeywell Electronic Programmable...
HONEYWELL T87N 1000 ROUND THERMOSTAT
the power for that stat comes from the furnace - if you have no display on the stat you have a furnace problem
Sep 28, 2009 | Heating & Cooling
Heating & Cooling Logo
669 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
