Question about Quantum Fireball Lct20 (QML30000LD-A) 30 GB Hard Drive
Paramet cyl = ? head=? sect = ? of QML30000LD-A
    New Friend:
Cyl ? head ? sector ? of SAMSUNG HM500JI
Posted on May 16, 2013
Written on the FireballPlus AS label it says
C/H/S: 16383/16/63 = 16514064
( averages out to 1817 bytes/sector )
LBA's: 58633344
( x 512bytes/Blk = 30,020,272,130Bytes )
Posted on Apr 22, 2009
Unscramble letters to create a word. letters: scsgtlaae
Alga Sects
Gala Sects
Galas Sect
Cage Slats
Cage Lasts
Cage Salts
Glaces Sat
Cages Last
Cages Salt
Cages Slat
Lace Stags
Scale Stag
Scale Tags
Laces Stag
Laces Tags
Scales Tag
Eclats Sag
Eclats Gas
Cleats Sag
Cleats Gas
Castle Sag
Castle Gas
Eclat Sags
Cleat Sags
Castes Gal
Castes Lag
Caste Slag
Caste Gals
Caste Lags
Lac Sagest
Lac Stages
Lacs Stage
Lacs Gates
Class Gate
Talcs Sage
Talcs Ages
Talc Gases
Talc Sages
Casts Gale
Scats Gale
Acts Gales
Scat Gales
Cast Gales
Cats Gales
A Lacs Gets
A Class Get
A Sacs Gelt
A Casts Leg
A Casts Gel
A Scats Leg
A Scats Gel
A Acts Legs
A Acts Gels
A Scat Legs
A Scat Gels
A Cast Legs
A Cast Gels
A Cats Legs
A Cats Gels
A Gal Sects
A Lag Sects
A Slag Sect
A Gals Sect
A Lags Sect
Lac Sag Set
Lac Gas Set
Lac As Gets
Lacs As Get
Sac Gal Set
Sac Lag Set
Sac Sag Let
Sac Gas Let
Sac Stag El
Sac Tags El
Sac La Gets
Sac Las Get
Sac As Gelt
Sac Sat Leg
Sac Sat Gel
Sac At Legs
Sac At Gels
Sacs Tag El
Sacs La Get
Sacs At Leg
Sacs At Gel
Acts Sag El
Acts Gas El
Acts As Leg
Acts As Gel
Scat Sag El
Scat Gas El
Scat As Leg
Scat As Gel
Cast Sag El
Cast Gas El
Cast As Leg
Cast As Gel
Cats Sag El
Cats Gas El
Cats As Leg
Cats As Gel
Cat Sags El
Cat As Legs
Cat As Gels
Act Sags El
Act As Legs
Act As Gels
Gal As Sect
Gal Sat Sec
Gal At Secs
Lag As Sect
Lag Sat Sec
Lag At Secs
Slag At Sec
Gals At Sec
Lags At Sec
Sag La Sect
Gas La Sect
Stag La Sec
Tags La Sec
Tag La Secs
Tag Las Sec
Oct 27, 2016 | Computers & Internet
4 cyl. has water in oil has been running good, wouldn't heat thought thermostat, pulled dipstick,milky, pulled plugs normal, do not smell antifreeze in exhaust ??
You will need to remove the cyl head and check for corrosion and/or cyl head gasket. Best is to take the cyl head to a reputable machine shop for testing and service.
Jan 11, 2016 | 1990 Nissan Hardbody King Cab
I have a t100 that keeps overheating we replaced everything from the water pump timing belt thermostat and it still overheating can you help me
Hi, did you recently skimmed the cyl-head? if so, then cyl-head is skimmed till last capacity, so you need to get the thicker cyl-head gskt. If not skimmed, remove cyl-head and skim it. it might be corroded or wapped.
Jul 20, 2014 | Cars & Trucks
Cylinder head change
tray this
http://partition-magic.soft32.com/download/file/id/130684/?
May 16, 2013 | Samsung Computers & Internet
When you say the vent maybe blocked preventing the cold air from freezer tto reach the fridge, is the vent located in the fridge or freezer?
there are two vents, theres one to let air into the ref. sect. and one to return air to the freezer sect. Both vents should be visible from the ref section. If the return air vent is blocked then no air can come into the ref sect. also some of the inlet vents have an electronic controlled air baffle (simmular to the A/C vent on a car that you van turn on and off. If yours has one of these electronic baffles, you could need to replace the baffle or the thermostat that controls the baffle. Hope this helps.
Mar 05, 2011 | Refrigerators
I purchesed a 2003 engine 3.0fwd online I had it installed the machanic did not change the timeing belt. will this distroy the upper cylinder heads and cause the engine not to start
if the engine jumps time (most likely at start up) it will bend several valves in cyl head. when this happens the engine will not start or run. the effected cyl head or heads need to be removed and reconditioned or replaced. cyl heads probebly ok but valves will be bent.
Mar 27, 2009 | 2003 Saturn VUE
Jumper switch settings
I have the same thing and here is your solution.
http://www.babooforum.com.br/idealbb/files/152532-Maxtor2.jpg
Worked perfect for me afterwards. :)
Sep 16, 2008 | Quantum Fireball Lct20 (QML30000LD-A) 30...
HDD Size Recognition
Hi, 10243MB is 10.02 GB..
You will not get exactly 10.2GB out of the drive, as most HDD makers use the 1000MB = 1GB ratio, as really 1024MB = 1GB.
So the bios is detecting the drive correctly.
Apr 12, 2008 | MSI KM4M-L Motherboard
Quantum Fireball Lct20 (QML30000LD-A) 30 GB Hard Drive Logo
278 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
