Question about Stoves Monessen Variable Thermostat Controlled Forced Air Blower Heater
I have a monessen LPG fireplace and the blower motor has seemed to stop working. it has a variable rotating switch on it. dont know if anyone knows where this problem is on most models like this?
The problem is likely the fan motor for the forced air blower, which means the entire blower needs replaced. The description of the problem is the same problem we had approximately two years ago when our motor was still under warranty (less than a year old). In our case the motor was replaced without charge. However, the same problem has happened this year which is extremely disappointing since we only run the fireplace from December to April intermittently because it is only a supplimental heat source for the house. You can either look up the model number and part number and order a replacement over the web (less expensive if you are DIY and know what you're doing) or see if the local LPG supplier can repair the part or replace. Good luck.
Posted on Dec 08, 2008
Pilot light wont stay lit on gas fireplace
Contact the Monessen site below and they might be able to help you or get you in touch with a dealer in your area to fix the issue. I know there was a recall on the Monessen remote systems a while back and your system might be part of that recall. Get with Monessen directly to find out. Hope this helps. http://monessenhearth.com/customer-care/
Dec 17, 2013 | Monessen MultiFunction Remote for Gas Log...
The heat on my Pyromaster HEF33 Electric Fireplace is not working
This unit was made by Monessen Hearth Systems. The original heater/fan part has been discontinued; however, there is a new part that is compatible with your fireplace. You will need to search for part#10006404 Fan/Heater.
Nov 30, 2012 | Leisure HOMEPRIDE Electric Fireplace...
I have a Pyromaster electric fire place = model HEF33 and I need a motor 12vdc for the flame generator part number 10001978? Can I just find any 12 volt dc motor and use it ? where would I find one...
here is a picture of it. It took me about 4 minutes to put the new one in.
http://www.ibuyfireplaceparts.com/monessen/10001978-motor-variable-speed-12v-dc.html
Jul 08, 2010 | Leisure HOMEPRIDE Electric Fireplace...
Dont know how to start it, dont know what it needs to start, and there is no remote to it
Some units sometimes have a wall switch that has to be turned on.
Usually on the bottom of the fireplace bheind the grille is the control
box a switch to turn on the electric heat and another to control the
electric heat and a possible blower.
Check to make sure the breaker is not turn off.
Feb 10, 2010 | Leisure HOMEPRIDE Electric Fireplace...
My A/C blower is not working. Checked fuse - OK. have +volts at the blower. is a switch a common problem or any way I can test why no worky. If i ground the motor it works but appears it may be a drawing a...
most times the switch is on the ground side of the a/c blower switch,why,I don't know,the variable switch isn't variable,its hooked to a resistor card and different resistances vary the motor speed and the card is behind the dash on most cars
Nov 02, 2009 | 1997 Isuzu Rodeo
Flame goes out Monessen Ventless fire place Model DLX24.
take a needle and put it into the end of the gas pilot hole. Wiggle it around in there, it just might have dust build up in there. Hope this helps ya.
Jan 17, 2009 | Stoves Monessen Variable Thermostat...
Need timer switch for millivolt gas fireplace
These guys are a division of Monessen, a gas fireplace manufacturer, and have a variety of millivolt switches, remotes and thermostats.
http://www.ambienttechnologies.com/
Dec 30, 2008 | Intermatic 600 Watt Low Voltage...
Heater/ Air Conditioner Blower Motor
you should relist under lincoln continental, not refrigerators. If you have electronic temp control, you should not have a resister. You should have a bower motor speed controller.
here's info for 1996 system. I don't have 1995, sorry.
A/C Blower Motor Speed Control
The A/C blower motor speed control (19E624) is located under the A/C evaporator housing, to the left of the blower motor (18527).
  • The function of the A/C blower motor speed control is to convert low power signals from the EATC control assembly to a high current, variable ground feed for the blower motor.
  • A/C blower motor speed is infinitely variable and is controlled by the electronic control assembly software and A/C electronic door actuator motor position.
  • A delay function provides a gradual increase or decrease in blower motor speed under all conditions.
Blower Speed Override Thumbwheel
Rotate the blower speed override thumbwheel more than 10 degrees to turn OFF the AUTOMATIC blower indicator and provide manual control of the A/C blower motor speed.
  • The display will show FAN and a fan symbol.
  • Rotating the wheel fully down against its lower stop locks the blower motor (18527) at its lowest speed.
  • Rotating the wheel fully up against the stop, locks the blower motor at its highest speed.
Press the AUTOMATIC button to resume automatic A/C blower motor control and remove the FAN and fan symbol from the display window.
Jun 27, 2008 | Continental Fish File Refrigerator - 1 Row
Heating & Cooling Logo
190 people viewed this question
Top Stoves Heating & Cooling Experts
Paul Carew
vance jones
ghold1
Level 1 Expert
Are you a Stoves Heating and Cooling Expert? Answer questions, earn points and help others
