Windows explorer When I double click on a folder it automatically goes to a search window vice opening the window. How do I get it to open by default?
    Novelist:
    Scholar:
  • 85 Answers
Ok click run and type "regedit" in the run box (this will open registry editor)
goto this key:
HKEY_CLASSES_ROOT\Directory\shell
"Double click" on the word "default" and set the value to the word "none" (without the quotes"")
then close registry editor
Also if you are having this problem when clicking on a drive then type this in the run box:
"regsvr32 /i shell32.dll" (without the quotes"")
that should fix the problem.
hope this info helps
Posted on Dec 06, 2008
Cannot create folder
Use Windows Explorer to open the folder in which you wish to create the new folder.
The "My Documents" folder is a good choice if you are new to Windows.
Look at the left side of the Explorer Window for an area marked "File and Folder Tasks."
Click on the link that says "Make a new folder."
Click on "File" on the menu bar to begin creating a new folder in a different way.
Select the "New" menu item and click on the "Folder" submenu item.
Move the mouse cursor to a blank area of the folder area and right click to bring up the context menu to begin creating a new folder in a third way.
Select "New" and click on the "Folder" submenu item.
5
Utilize a fourth method to create a folder directly on the desktop.
Right click on a blank area of the desktop.
6
Type a name for the new folder in the highlighted area after using any of the methods described in Steps 2 through 4.
Press the "Enter" key or click in a blank area of the folder window to complete the process.
also you might just open your drive right click inside select new folder and name it.
Restore Folder Options in Windows XP
Windows XP has several viewing options that you can modify for folders in Windows Explorer. These include being able to customize whether you activate items by clicking them once or twice, whether Windows displays hidden and protected files and several other options.
If you have played with these options in an attempt to determine how you prefer to use your computer, you may accidentally reach the point where you have changed so many items that you are unsure of how to revert to the original configuration.
For this reason, Windows XP allows you to restore the folder options to their defaults by clicking a button.
Open Windows Explorer.
Two of the fastest ways to do this are by clicking the "Start" button and then clicking "My Computer" and by double clicking the "My Computer" icon on the desktop.
Click the "Tools" drop-down menu and select "Folder Options."
Click the "General" tab, and then click the "Restore Defaults" button if you would like to restore the default settings for the "Common Tasks" bar on the left side of folders, whether new folders open in the same window or a new window and whether items open with a single click or double click.
Click the "View" tab, and then click the "Restore Defaults" button if you would like to restore any advanced view settings to their defaults, such as whether Windows displays hidden and protected files.
Click the "Reset All Folders" button if you would like to restore the default viewing option to all folders, such as the detailed view or list view.
Click "OK" to save your changes.
http://support.microsoft.com/kb/812003
Aug 14, 2013 | Western Digital Passport Computers &...
Tip
Drive can,t open on double-click
hi there,
many times user face this type of problem.
first ,of all open -my computer > open tools tab > then folder option >then view tab click on "show hidden files"and uncheck "hide protected oprating system files" then ok
second , click on folder button (standred button) "it is up to address bar or next to search button"
now click on drive in left side explorer window now you can see folders in drive "delete" autorun.inf file in drive.
third, go in drive properties by right click on drive in explorer window,
click on "tools" tab click on "check now"
mark on automatically fix file system error and click start
it will start checking file system and fix it or it will ask fix it on next restart (it checkdsk command in windows gui mode )
after restart chkdsk start and your drive will again open on double-click.
on Jan 27, 2010 | Computers & Internet
Tip
Set a new Windows Explorer launch folder When you run Windows Explorer, it...
Set a new Windows Explorer launch folder When you run Windows Explorer, it always opens to the Libraries folder. That's fine if you use Microsoft's default file organization, which designates Libraries as the overall container for your folders. But what if you don't? You might prefer to have Windows Explorer open to Computer or any other folder you choose. Here's how to do it:
1. Right-click the Windows Explorer icon on the taskbar (it's the one that looks like a folder), and then right-click the Windows Explorer icon from the context menu that appears and select Properties. The Windows Explorer Properties dialog box appears.
2. You'll have to edit the Target field on the Shortcut tab of this dialog box in order to change the default location at which Explorer opens.
If you want Explorer to open to a specific folder, simply enter the name of the folder, substituting your folder name for Folder, below, like this:
%windir%\explorer.exe c:\Folder
So to open Explorer to the folder named Budget, you would type this in the Target field:
%windir%\explorer.exe c:\Budget
If you want Explorer to open to special, pre-set locations, such as Computer, you'll need to enter special syntax in the Target field. Following is a list of three common locations and the syntax to use, followed by the syntax for the Libraries folder in case you ever want to revert to the default.
  • Computer: %windir%\explorer.exe ::{20D04FE0-3AEA-1069-A2D8-08002B30309D}
  • My Documents:%windir%\explorer.exe ::{450D8FBA-AD25-11D0-98A8-0800361B1103}
  • Network: %windir%\explorer.exe ::{208D2C60-3AEA-1069-A2D7-08002B30309D}
  • Libraries: %SystemRoot%\explorer.exe
3. After you've changed the Target field, click OK. Next time you launch Windows Explorer, it will open to the new location you've designated.
on Jan 12, 2010 | Computers & Internet
When i click on new folder option it does nothing
Which operating system ?
May 18, 2013 | Compaq CQ56-219WM Intel Celeron 900...
Internet explorer is not visible on desktop
Find a Missing Internet Explorer Icon in Windows XP
  • Step 1 Click the "Start" button. Click on "All Programs." Look for an icon called "Internet Explorer." Right-click the icon. Select "Copy" from the menu.
  • Step 2 Find a blank space on your Desktop and right-click on it. Select "Paste" from the menu. You should see a new icon called "Internet Explorer." Double-click it to make sure that it works.
  • Step 3 Open "My Computer" on your Desktop if you were unable to find the Internet Explorer icon in "All Programs." Double-click the "C:" drive. Double-click "Program Files." Open the folder named "Internet Explorer."
  • Step 4 Select the "iexplore.exe" icon and right-click on it. Choose "Create Shortcut" from the menu. Scroll down to the bottom of the window. Right-click the "Shortcut to iexplore.exe" icon. Click "Copy."
  • Step 5 Paste the icon to your Desktop. Open it to make sure it works.
  • Step 6 Click the "Start" button and select "Search" from the menu if you are unable to find the "iexplore.exe" icon in your Program Files folder. Search for "iexplore.exe." Locate the file. Right-click it to create a shortcut. Paste the shortcut to your Desktop.
  • Find a Missing Internet Explorer Icon in Windows Vista
  • Step 1 Click the "Start" button. Select "Run." In the "Run command" box, type "regedit.exe."
  • Step 2 Look for the key ""HKEY_CURRENT_USER." Click twice to open it.
  • Step 3 Navigate to "Software" and open it. Open "Microsoft," "Windows," "CurrentVersion," "Explorer," "HideDesktopIcons" and "NewStartPanel."
  • Step 4 Open the "{871C5380-42A0-1069-A2EA-08002B30309D}" key on the right side of the screen. Change the value to "0" to show the icon on your Desktop.
  • Jul 14, 2010 | Microsoft Internet Explorer 8
    Changing how to open drives
    2 things...go into ur Control panel and in the MOUSE area change the way ur mouse clicks to run things..then save those settings.
    OPen Real Player options or preferences. Look for an option to how it handles running things. then uncheck it. save those settings.
    May 24, 2009 | Microsoft Windows XP Home Edition
    I have a problem with my computer. whenever i open any folder in any drive, the search window opens. what should i do in order to solve this?
    This type of problem normally occurs because some virus called ‘PET32.exe’ , or it can also occur due some other virus which disrupt the windows registry.
    . Open Start >> Run or press Window Key + r , this will open the run prompt.
    2. Type “regedit” ( without quotes )and press Enter.
    3. Navigate to key
    4. Double the registry key named Default and set the value to none.
    This will restore the normal windows explorer behavior of opening a folder when you double click a folder rather than opening windows search.
    If search opens when you double click on any windows drive, then try this
    1. Open Start >> Run or press Window key + r
    2. Type “regsvr32 /i shell32.dll” ( without quotes )and press Enter
    After the command run successfully, you will see a message saying DllRegisterServer and DllInstall in Shell32.dll succeeded.
    I hope this will help to fix the trouble.
    Jan 17, 2009 | Microsoft Windows XP Home Edition
    How Do I Remove My Web Search?
    hi Crazzymandy,
    Thanks for your posting in FixYa.
    Please do the following:
    First, uninstall the My Web Search option from Add/Remove Programs
    1) Click on Start, Settings, Control Panel
    2) Double click on Add/Remove Programs
    3) Find "My Web Search" in the list of installed programs and click on Change/Remove to uninstall it. You may also want to uninstall any of the following items associated with FunWebProducts.
    · My Web Search (Smiley Central or FWP product as applicable)
    · My Way Speedbar (Smiley Central or other FWP as applicable)
    · My Way Speedbar (AOL and Yahoo Messengers) (beta users only)
    · My Way Speedbar (Outlook, Outlook Express, and IncrediMail)
    · Search Assistant - My Way
    4) Reboot your Computer and run HijackThis
    5) With HijackThis, scan for and fix any of the entries shown above that may be remaining.
    6) Next, open My Computer, Drive C, and double-click on the Program Files folder
    7) Right-click and delete the folders for:
    · FunWebProducts
    · MyWebSearch
    8) MyWebSearch should now be completely uninstalled from your computer.
    9) There will be some minor registry entries left behind by the uninstall, however these can be cleaned up by running SpyBot Search and Destroy or Ad-Aware SE or left alone.
    If unable to remove from control panel, then try to remove them after rebooting PC in Safe mode..
    Hope this would help you a lot.
    Dont forget to rank me up.
    Have a nice day.
    Best of Luck & Regards
    ELLIN
    Sep 21, 2008 | Microsoft Windows XP Professional for PC
    Computers & Internet Logo
    32 people viewed this question
    David Payne
    David Payne
