Looking how to do a system restore
I cant go on line with my dell insperation 1000 it says low or no connectivity??? my road runner is working fine but I was hoping to do it the quick way with a system reboot
  • mandi1720 Mar 25, 2009
    I cant connect to my internet?
  • tanvierahmed
    tanvierahmed May 11, 2010
    which os you are iuseing???
  • 81 Answers
The easy way would be using the 'system restore" included in MS Windows.
-Click the Start button, point to All Programs→ Accessories→ System Tools, and then click System Restore.
-Ensure that Restore my computer to an earlier time is selected and click Next.
-Click a calendar date to which you want to restore your computer (when everything worked fine)
-Click Next.
The Restoration Complete screen appears after System Restore finishes collecting data and then the computer restarts.
6 After the computer restarts, click OK.
Posted on Dec 06, 2008
My wife rearranged furniture and in the process
The router is OK, do not reset or change any settings.
There is interference between the router and the Dell. Move the router higher and point the antennas in-line with the direction of the Dell.
Look for obtacles such as refrigerator, metal file cabinet, metal desk, many walls, large mirror on wall, etc. The signal reflects and does not pass through metal or metal coatings.
Sep 30, 2009 | NetGear WGR614 Wireless Router
How do you format the hard drive on Dell Inspiron 1000. I have the restore system disk and don't have anything on it worried about losing...just need to format and start fresh..it's got too many issues and...
I'd put ubuntu on it, if it's a inspiron 1000, should run ok. If you have the restore disks from dell, just turn it on, pop in the cd, then reboot, the pc should boot from cd, then just follow the promps, make sure you delete all partitions, format thorough (not quick NTFS), use the whole disk for windows
Apr 06, 2009 | Dell Inspiron 1000 Notebook
Deleted sound
You need to be more specific on ( tried everything ). You cant just DELETE the sound. By delete the sound you mean no sound works at all?
Im asuming the user deleted the drivers and you need to go to www.support.dell.com and enter the model number in help and support and get the drivers. Re-install them and you should be fine.
Let me know what the situation is in more detail of what all you have done and I wil try and help you out.
Jan 29, 2009 | Dell Inspiron 1000 Notebook
Cant go online with my dell insperation 1000 it says low or no connectivity was wondering if there was a way to do a system restore to solve the problem ..getting real frustrated
Sure you can try system restore and restore it to the day before the problem occurred but if it has been a while then it is possible that there may not be a restore point available to restore it to
And if that is the case then open "network connections" in the control panel and "right click" your connection that says limited or no connectivity and select "status" from the drop down menu then click the "support" tab on top and where it says "IP Address" look to see if it starts with a 169.xxx.xxx.xxx number and if it does start with 169 then that means that your computer was unable to acquire an IP address from your router or modem and it assigned itself a default machine address of 169.xxx.xxx.xxx (xxx is just space filler for numbers they could be different numbers) And so if it does say 169 then click the repair button and it will try to acquire a new address and if it is still unable to acquire an address and you end up with a 169 number again then if you have a router go over to the router and unplug the power cord for 10 seconds and plug it back in and then click repair again and it should work.
Most routers assign an IP address that starts with a 192.168
if you don’t have a router and your modem is plugged directly into your computer then try unplugging the modem and plugging it back in but wait for the modem to initialize (boot-up) all the way (you will know when all of the lights on the modem are on) before clicking repair button.
if none of the above helps then let me know and ill take you to the next step in fixing the problem
Dec 06, 2008 | Computers & Internet
I have roadrunner internet and when i connect it directly to the main desktop computer it works fine but when i put it through a linksys router the internert doe snot work and the rest of the computers in...
You need first to configure the linksys router to work with your road runner cable internet, if you have the setup CD for the router you can use to configure the router but if not you need to manually configure the router to work with Road runner cable internet by accessing the router setup page, if you're not aware on how to manually configure the router to work with road runner you can call this number so a Tech can walk you through with the process 1-877-787-8749...
Oct 16, 2008 | Computers & Internet
DELL WILL NOT POWER UP
If the battery is shot, remove it and see if the system will power up on AC only.
If not change, check the output of the AC adapter with a Multimeter set on DC voltage. It should be 15 to 20 Volts DC current at the connection end for the computer. If low or no voltage, replace the AC adapter.
Aug 11, 2008 | Dell Inspiron 1000 Notebook
Computers & Internet Logo
David Payne
David Payne
